    2318 commits behind...
    17 Posts 8 Posters 9.9k Views 7 Watching
      savona @savona
      @bastilimbach Any help?
        bhepler Module Developer @savona
        @savona - Would it make sense to build from image, rename the git files, pull, update and then upload the fixed image as a PR?
          savona @bhepler
          @bhepler maybe.
          but I saw that the originator of the docker image said it was updated daily with a cronjob on this post:
          https://forum.magicmirror.builders/topic/5316/automatic-docker-build/2
          • idoodlerI Offline
            idoodler Module Developer @savona
            @savona Both package-lock.json can just be deleted. Did you intentionally change the files in the default directory?
              savona @idoodler
              @idoodler No I did not change the default directory at all. That is why this is so odd to me.
              idoodlerI 1 Reply Last reply Reply Quote 0
                rummyr
                I got a message saying my MM was out of date, so I pulled the new docker image and now have the 2318 message also.
                The top of my CHANGELOG.md reads “## [2.5.0] - 2018-10-01”
                Though the “image date” as reported by Portainer is “Created 2019-01-01 15:08:22”
                Do we need to wait for bastilimbach?
                • idoodlerI Offline
                  @savona OK, you may have a corrupt git directory then. You may try to clone it again.
                    savona
                    I just blew away the docker image and did a new pull and it is fixed and on 2.6.0.
                    grep version package.json
                    “version”: “2.6.0”,
                    • T Offline
                      Thelonius
                      I was able to proceed past this error by using the command ‘git stash’. This worked for two Magic Mirrors.
                      • CyruS1337C Offline
                        CyruS1337 Project Sponsor
                        Hello everybody
                        I have three MagicMirrors in use. On two mirrors he shows me that I’m 2318 and 124 behind the master respectively.
                        If I enter git pull in the MagicMirror folder, error occurs
                        Aktualisiere 6db61b4..de57daa
                        error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                        überschrieben werden:
                                package-lock.json
                                vendor/package-lock.json
                        Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                        Abbruch
                        What do I have to do to bring the MagicMirror up to date?
                          you can erase those two files, then git pull again
                            @sdetweil said in 2318 commits behind...:
                            Ok, can you tell me how to delete and reload? Sorry, but unfortunately I do not understand so much of the matter :(
                              sdetweil @CyruS1337
                              @cyrus1337
                              rm package-lock.json
                              rm vendor/package-lock.json
                              then
                              git pull
                              as before
                              then probably reinstall npm modules
                              from MagicMirror folder
                              npm install
                                Thank you for your quick help. Everything works :)
