    2318 commits behind...
    17 Posts 8 Posters 10.0k Views 7 Watching
      savona
      I recently installed MM with docker using this image:
      https://github.com/bastilimbach/docker-MagicMirror
      It ran fine for a couple of days then yesterday I received this meesage:
      MagicMirror2 update available.
      The current installation is 2318 commits behind on the master branch.
      My current version is:
      grep version package.json
      "version": "2.5.0"
      I have done a lot of searching. I have read that there is a cron job that updates the image for docker, but I have rebuilt several times and still no luck and I don’t see any changes on the docker git.
      I have tried git pull and get error after error.
      error: Your local changes to the following files would be overwritten by merge:
      	package-lock.json
      	vendor/package-lock.json
      Please commit your changes or stash them before you merge.
      error: The following untracked working tree files would be overwritten by merge:
      	modules/default/clock/clock_screenshot.png
      	modules/default/compliments/compliments_screenshot.png
      	modules/default/currentweather/weather_screenshot.png
      	modules/default/newsfeed/newsfeed_screenshot.png
      	modules/default/weather/README.md
      	modules/default/weather/current.njk
      	modules/default/weather/current.png
      	modules/default/weather/forecast.njk
      	modules/default/weather/forecast.png
      	modules/default/weather/providers/README.md
      	modules/default/weather/providers/darksky.js
      	modules/default/weather/providers/openweathermap.js
      	modules/default/weather/weather.css
      	modules/default/weather/weather.js
      	modules/default/weather/weatherobject.js
      	modules/default/weather/weatherprovider.js
      	modules/default/weatherforecast/forecast_screenshot.png
      Please move or remove them before you merge.
      Aborting
      Any help?
      D idoodlerI 2 Replies Last reply Reply Quote 0
        dazza120 @savona
        @savona rename those folders then got pull, then you can delete once MM is working on the new version
          savona @dazza120
          @dazza120 But then if I rebuild the docker container wouldn’t it just put me back 2318 commits?
          UPDATE: Yes, I rebuilt the docker container and it reverted right back.
            savona @savona
            @bastilimbach Any help?
              bhepler Module Developer @savona
              @savona - Would it make sense to build from image, rename the git files, pull, update and then upload the fixed image as a PR?
                savona @bhepler
                @bhepler maybe.
                but I saw that the originator of the docker image said it was updated daily with a cronjob on this post:
                https://forum.magicmirror.builders/topic/5316/automatic-docker-build/2
                • idoodlerI Offline
                  idoodler Module Developer @savona
                  @savona Both package-lock.json can just be deleted. Did you intentionally change the files in the default directory?
                    savona @idoodler
                    @idoodler No I did not change the default directory at all. That is why this is so odd to me.
                    idoodlerI 1 Reply Last reply Reply Quote 0
                      rummyr
                      I got a message saying my MM was out of date, so I pulled the new docker image and now have the 2318 message also.
                      The top of my CHANGELOG.md reads “## [2.5.0] - 2018-10-01”
                      Though the “image date” as reported by Portainer is “Created 2019-01-01 15:08:22”
                      Do we need to wait for bastilimbach?
                      • idoodlerI Offline
                        @savona OK, you may have a corrupt git directory then. You may try to clone it again.
                          savona
                          I just blew away the docker image and did a new pull and it is fixed and on 2.6.0.
                          “version”: “2.6.0”,
                          • T Offline
                            Thelonius
                            I was able to proceed past this error by using the command ‘git stash’. This worked for two Magic Mirrors.
                            • CyruS1337C Offline
                              CyruS1337 Project Sponsor
                              Hello everybody
                              I have three MagicMirrors in use. On two mirrors he shows me that I’m 2318 and 124 behind the master respectively.
                              If I enter git pull in the MagicMirror folder, error occurs
                              Aktualisiere 6db61b4..de57daa
                              error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                              überschrieben werden:
                                      package-lock.json
                              Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                              Abbruch
                              What do I have to do to bring the MagicMirror up to date?
                                you can erase those two files, then git pull again
                                  @sdetweil said in 2318 commits behind...:
                                  Ok, can you tell me how to delete and reload? Sorry, but unfortunately I do not understand so much of the matter :(
                                    sdetweil @CyruS1337
                                    @cyrus1337
                                    rm package-lock.json
                                    rm vendor/package-lock.json
                                    then
                                    git pull
                                    as before
                                    then probably reinstall npm modules
                                    from MagicMirror folder
                                    npm install
                                      Thank you for your quick help. Everything works :)
