    Office365 Calendar load error
    4 Posts 2 Posters 2.1k Views 2 Watching
    • F Offline
      fennemaj
      I’m trying to configure MagicMirror and everything is working pretty well except I can’t get my Office365 calendar do load. I can confirm that the ICS is accessible and the link works with other similar solutions like Dakboard, but it’s not working with MagicMirror. Below is the response I get. I can get the default Holiday calendar working without any issue. Also, I’ve modified the link below slightly so my calendar isn’t broadcast to the world so the ICS link will most likely not work if you try and download it, but the actual link I’m using does work and downloads a functional ics file.
      Starting MagicMirror: v2.6.0
      Loading config …
      Loading module helpers …
      Module helper loaded: MMM-Wallpaper
      Module helper loaded: MMM-3Day-Forecast
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Starting module: newsfeed
      Connecting socket for: MMM-Wallpaper
      Starting node helper for: MMM-Wallpaper
      Connecting socket for: MMM-3Day-Forecast
      MMM-3Day-Forecast helper, started…
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: https://outlook.office365.com/owa/calendar/b518cb52b20249fda5231010ae758fd2@shop.com/fd2ad49bc3094612b60b2aad2874b0cc16806628755154814078/calendar.ics - Interval: 300000
      Create new news fetcher for url: http://feeds.feedburner.com/TechCrunch/ - Interval: 300000
      Whoops! There was an uncaught exception…
      TypeError: curr.exdates[i].toISOString is not a function
      at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:44:44)
      at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:267:41)
      at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:308:20)
      at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:24)
      at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
      at emitTwo (events.js:126:13)
      at Request.emit (events.js:214:7)
      at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1157:10)
      at emitOne (events.js:116:13)
      at Request.emit (events.js:211:7)
      • N Offline
        Nilnik Project Sponsor
        Hello, look at this link: https://github.com/MichMich/MagicMirror/wiki/Apple-Google-MicroSoft-Calendar-Support
        • F Offline
          fennemaj
          Thanks for that reference. That worked. Basically use Microsoft Flow to sync your O365 calendar to a Google Calendar and then tie the Google Calendar into MM. It would be great if at some point in the future we could find a way to sort out the date format issue so the ICS link direct from O365 could work.
          Thanks again for the response and the tutorial!
          • N Offline
            Glad to help, have a nice day
