    Strip Down Guide for BenQ 28" VA Monitor GC2870H
    61 Posts 10 Posters 75.8k Views 10 Watching
    • Y Offline
      yep_DD @Daniel3490
      @daniel3490 hi Daniel, it is bit hard to take down the mirror by myself, i have to wait until I have a friend over to help me. I don’t really see the edges of my monitor unless it is really really dark.
        bachoo786
        Hi @yep_DD
        Fantastic Work !
        May I ask how did you connect your rcwl0516 sensor and what module did you use to integrate it with MM? Are there any instructions I can follow?
        Thanks.
        M Y 2 Replies Last reply Reply Quote 0
          MadScientist @bachoo786
          @bachoo786 The sensor should have three pins: VCC, GND and signal out. You connect them the same way you connect a PIR sensor and it should also work with the same MM module MMM-PIR-Sensor.
          • Y Offline
            yep_DD @bachoo786
            Hi @bachoo786
            thank you so much. As @MadScientist pointed out the three pins are connected directly to the Raspberry. For evaluating the state I use a small http server (see below). The important parts are where the you can find anything with
            monitorStatus
            If you want I can reduce the code to what is important for you. This is the complete server which allows control of
            • ARD Livestream
            • ARD Tagesschau
            • Lowering / Increasing volume
            • Radar Sensor (just the last couple lines of code (search for: GPIO.add_event_detect)
            • Powerin On / Off Monitor by http Request (used if no one is at home / and at night)
            For me the radar sensor is just a backup. I use the power control mainly like this:
            • If someone is at home and it is between sunrise / sunset, turn on the monitor(1)
            • If someone is at home but it is night and all lights are off, turn off the monitor(1)
            • If someone is in front of the monitor turn it on by radar
            (1) is done via FHEM (a home automation running on another raspberry, it calls my mirror like this: 10.0.1.49/on (monitor on) 10.0.1.49/off (monitor off) 10.0.1.49/up or /down (for volume) and so on.
            #!/usr/bin/python3 -u
            host_name = '10.0.1.49'  # Change this to your Raspberry Pi IP address
            host_port = 8000
            proc = ''
            monitorstatus = 'unknown'
            import RPi.GPIO as GPIO
            from pathlib import Path
            import os
            import subprocess
            import signal
            from subprocess import call
            from time import sleep
            from http.server import BaseHTTPRequestHandler, HTTPServer
            SENSOR_PIN = 24
            GPIO.setmode(GPIO.BCM)
            GPIO.setup(SENSOR_PIN, GPIO.IN)
            class MyServer(BaseHTTPRequestHandler):
                def monitor_on(channel): #define initial status of Monitor
                    if monitorstatus!="on":
                        status='Monitor on by Radar Sensor'
                        #monitorstatus='on'
                        subprocess.Popen(["/usr/bin/vcgencmd", "display_power", "1"], preexec_fn=os.setsid)
                def do_HEAD(self):
                    self.send_response(200)
                    self.send_header('Content-type', 'text/html')
                    self.end_headers()
                def do_GET(self):
                    global proc
                    global monitorstatus
                    html = '''
                       <html>
                       <body style="width:960px; margin: 20px auto;">
                       <h1>Magic Mirror Control</h1>
                       <p>Current GPU temperature is {}</p>
                       <p>Podcast: <a href="/play">Play</a> <a href="/stop">Stop</a></p>
                       <p>ARD Livestream: <a href="/ard">Play</a> <a href="/stop">Stop</a></p>
                       <p>Volume: <a href="/down">down</a> <a href="/up">up</a></p>
                       <p>System: <a href="/shutdown">Shutdown</a> <a href="/restart">Restart</a></p>
                       <p>Monitor: <a href="/on">On</a> <a href="/off">Off</a></p>
                       <div id="podcast-status"></div>
                       <script>
                           document.getElementById("podcast-status").innerHTML="{}";
                       </script>
                       </body>
                       </html>
                    temp = os.popen("/opt/vc/bin/vcgencmd measure_temp").read()
                    self.do_HEAD()
                    status = ''
                    if self.path=='/':
                        #GPIO.setmode(GPIO.BCM)
                        #GPIO.setwarnings(False)
                        #GPIO.setup(17, GPIO.IN)
                        status='nothing'
                    elif self.path=='/play':
                        if proc=='':
                            my_file = Path("/home/pi/MagicMirror/video.mp4")
                            if my_file.is_file():
                                statinfo = os.stat('/home/pi/MagicMirror/video.mp4')
                                if statinfo.st_size > 0:
                                    proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/home/pi/MagicMirror/video.mp4"], preexec_fn=os.setsid)
                                    status='Playing Podcast'
                                else:
                                    proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/home/pi/MagicMirror/Loading.mp4"], preexec_fn=os.setsid)
                                    status='Not yet available'
                            else:
                        else:
                            status='Stopping Podcast'
                            os.killpg(os.getpgid(proc.pid), signal.SIGTERM)
                            proc=''
                    elif self.path=='/ard':
                        if proc=='':
                            proc = subprocess.Popen(["livestreamer", "hlsvariant://daserste_live-lh.akamaihd.net/i/daserste_de@91204/master.m3u8", "best", "-vnp", "omxplayer -o alsa:hw:ALSA --no-osd --timeout 20"], preexec_fn=os.setsid)
                            status='Playing ARD Livestream'
                        else:
                            status='Stopping Stream'
                            proc=''
                    elif self.path=='/stop':
                        if proc!='':
                            proc=''
                        else:
                            status='Nothing to stop'
                    elif self.path=='/shutdown':
                        status='Shutdown'
                        subprocess.Popen(["sudo", "shutdown", "-h", "now"], preexec_fn=os.setsid)
                    elif self.path=='/restart':
                        status='Restart'
                        subprocess.Popen(["sudo", "reboot"], preexec_fn=os.setsid)
                    elif self.path=='/down':
                        status='Volume down'
                        subprocess.Popen(["amixer", "set", "Master", "8%-"], preexec_fn=os.setsid)
                    elif self.path=='/up':
                        status='Volume up'
                        subprocess.Popen(["amixer", "set", "Master", "8%+"], preexec_fn=os.setsid)
                    elif self.path=='/on':
                        if monitorstatus!="on": #switch on Monitor if status was off (by httpRequest NOT Radar)
                            status='Monitor on'
                            monitorstatus='on'
                    elif self.path=='/off':
                        if monitorstatus!="off": #switch off Monitor if status was on  (by httpRequest NOT Radar)
                            status='Monitor off'
                            monitorstatus='off'
                            subprocess.Popen(["/usr/bin/vcgencmd", "display_power", "0"], preexec_fn=os.setsid)
                    self.wfile.write(html.format(temp[5:], status).encode("utf-8"))
            if __name__ == '__main__':
                http_server = HTTPServer((host_name, host_port), MyServer)
                print("Server Starts - %s:%s" % (host_name, host_port))
                try:
                    GPIO.add_event_detect(SENSOR_PIN , GPIO.RISING, callback=MyServer.monitor_on) #detect radar sensor and enable Monitor
                    http_server.serve_forever()
                except KeyboardInterrupt:
                    http_server.server_close()
            GPIO.cleanup()
              bachoo786
              @MadScientist @yep_DD Thanks for the replies. Is there anyway to limit the distance that the radar sensor senses? I have my magic mirror in the bath room and it faces the wooden door which I believe will be detecting motion through it and I don’t want that.
                MadScientist
                I have a sensor that allows changing the sensitivity but for me the lowest was still to much as it got triggered when somebody walked by outside my house. I am using a PIR-Sensor now.
                • Y Offline
                  yep_DD @bachoo786
                  @bachoo786 apparently it also depends on the quality of the sensor, I ordered a batch on ebay and got lucky with one where I have to get really close to the glass to trigger it. at first I thought I would change it, but now I am satisfied because it fits the purpose of just activating in case the mirror is off and the other power-on / off logic didn’t work (guests at home). But if I had to redesign I would not use a sensor at all as my other ways of powering the mirror seem far more integrated, e.g. I do not want to see the mirror turn on and / off as this disturbs the design.
                    bachoo786
                    @MadScientist is your pir visible near your mirror?as it wouldn’t work behind the mirror.
                    @yep_DD are you talking about the rcwl0516? I have read that using a low value resistor can decrease the range of detection up to 5cm. Trouble is I don’t where to connect the additional resistor and the low value of it too.
                      MadScientist
                      I have it incorporated in the frame. I drilled a 2 or 3mm hole in the front of the frame and a 8mm hole from the back which only goes half way through. The 8mm are perfect to mount the PIR sensor without the lense. The mirror only activates when you are directly in front of it and it’s hardly visible.
                        bachoo786 @MadScientist
                        @madscientist is it possible to share a photo please?
                          MadScientist
                          View from the back:
                          View from the front:
                          PIR sensor without IR lense and the inside-8mm-hole:
                            @madscientist very well done and looks neat thanks for that
                              secdude @yep_DD
                              @yep_DD
                              What mirror thickness did you choose? 4mm or 6mm? And why?
                              • Y Offline
                                yep_DD @secdude
                                @secdude I chose 4mm glas because it is already heavy enough to mount the mirror like that.
                                • floF Offline
                                  flo
                                  @Adrien Do you have already cut the wires of the backlight? Does it work now without HDMI logo? Whats the delay?
                                  • Y Offline
                                    yep_DD @flo
                                    @flo actually I have not, I power the monitor via my relay and my presence dedection makes me never see the logo so so far there was no need to do that
                                    floF 1 Reply Last reply Reply Quote 0
                                    • floF Offline
                                      flo @yep_DD
                                      @yep_DD So you would see the logo if you only rely on the PIR? Can you share a picture of the final mirror design? I really like your frame and thinking of buying one myself.
                                      • Y Offline
                                        yep_DD @flo
                                        @flo no, the “big” Benq logo is disabled via the developer menu of the monitor. You would only see a small “HDMI1” in the lower right. Yeah, I will post a a few pics in an hour when it is a bit darker outside. Hold on :D.
                                        • Y Offline
                                          yep_DD
                                          That’d be the final result. The wire on the first picture I was just too lazy to hide. Just needs to be pushed down.
                                          Second picture shows the news podcast as an ovelay. No unnecessary buttons, PIR sensors or anything else that’d destroy the design.
                                          Side note: I added an automatic Wifi Setup Feature which plays a video when it isn’t connected to a WiFi network and creates a hotspot for initial setup.
                                          @MichMich thanks for the amazing project you created. I have had some people at my home being absolutely amazed by the mirror. I always refer them to the spirit of open source and this great community.
                                          • floF Offline
                                            flo @yep_DD
                                            @yep_DD it looks really neat - congratulations! A little bit too big for my taste, but I like the clean design. How much does it weight? I have only a plaster wall…
                                            • 3 / 4
