    first installation on RPi3 failed
    6 Posts 2 Posters 1.7k Views 2 Watching
    • L Offline
      lkthomas
      Folks, this is my first time to install MM, and I never had any prior experience on this.
      This is the error I am getting, anyone have idea why?
      pi@raspberrypi:~/MagicMirror $ npm install
      (node:6315) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN package.json current-week-number@1.0.7 license should be a valid SPDX license expression
      npm WARN package.json rrule-alt@2.2.8 No license field.
      npm WARN package.json valid-url@1.0.9 No license field.
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm ERR! Error: Method Not Allowed
      npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR! at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this entire log,
      npm ERR! including the npm and node versions, at:
      npm ERR! http://github.com/npm/npm/issues
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command “/usr/bin/node” “/usr/bin/npm” “install”
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      • lavolp3L Offline
        lavolp3 Module Developer
        @lkthomas said in first installation on RPi3 failed:
        npm -v 1.4.21
        your npm version is very old.
        Try to first update npm via
        npm install -g npm@latest
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L Offline
          Also try to upgrade node, e.g. via the small program “n”
          npm install -g n
          n stable
          • L Offline
            lkthomas
            @lavolp3 said in first installation on RPi3 failed:
            n stable
            doesn’t help:
            pi@raspberrypi:~/MagicMirror $ sudo npm install -g npm@latest
            (node:6358) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
            npm WARN package.json path-is-inside@1.0.2 No README data
            npm WARN package.json sorted-object@2.0.1 No README data
            npm WARN package.json config-chain@1.1.12 No license field.
            npm WARN package.json cyclist@0.2.2 No license field.
            npm WARN package.json json-schema@0.2.3 No license field.
            npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
            npm WARN package.json qrcode-terminal@0.12.0 No license field.
            npm WARN package.json string_decoder@1.1.1 string_decoder is also the name of a node core module.
            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
            npm@6.5.0 /usr/local/lib/node_modules/npm
            /usr/bin/n -> /usr/lib/node_modules/n/bin/n
            • n@2.1.12
              added 1 package from 4 contributors in 1.974s
              pi@raspberrypi:~/MagicMirror $ sudo n stable
              install : node-v11.6.0
              mkdir : /usr/local/n/versions/node/11.6.0
              fetch : https://nodejs.org/dist/v11.6.0/node-v11.6.0-linux-armv7l.tar.gz
              ######################################################################## 100.0%
              installed : v11.6.0
            (node:6481) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
            npm ERR! code E405
            npm ERR!
            • lavolp3L Offline
              better reboot after installing new npm and node versions
              • L Offline
                lkthomas
                looking okay after reboot, thanks
