    Start without internet connection and restart with, make modul work?
    13 Posts 3 Posters 4.5k Views 3 Watching
      robiv8
      Prehistory:
      I’ve been trying for weeks to switch pages with Real Buttons. This works quite well with MMM Page Selector.
      Now I wanted to press the button to display the Tagesschau 100sek with the module Podcast2.
      For days I try to integrate and it just does not start.
      Today:
      By a stupid coincidence, I discovered something.
      I went to work and took my Raspi to test by the way. Raspi started, desktop stays black! Aaaah! OK No internet. I put F11 so that I come to the desktop, then Turn on the W-LAN because otherwise no Internet possible. Terminal opened and MM restarted. “pm2 restart mm”
      MM comes. I think I’ll push the 2 buttons if the two sides are still changing, and YES it still does. Wy not ;-) Press the 3 button and behold! Podcast starts to run. I’m amazed. But why? What the hell is going on.
      I think, and do some tests.
      The following, if I start the computer without Internet, then shrink MM to get to the wi-fi switch ,. Turn on W-Lan and restart MM, the button works and podcast starts.
      But if I restart MM now it does not work anymore. So i must Start without Internet connection then restart MM and its Going.
      Very Strange!
      Now I’m not sure why that is and where to ask for help?
      MMM-Buttons
      MMM-Page-Selector,
      MMM-Podcast2
      or
      on the MagicMirror itself
        start the mirror without internet, but open the dev console (npm start dev),
        select the console tab… look for errors…
        most of the modules do not recover from system issues like this from startup… they might AFTER successfully starting, if the internet were to go out and come back…
          robiv8
          Thanks for the tip.
          I am going now home and will try it.
            robiv8
            So I have do it and here is the log file.
            main.js:450 Initializing MagicMirror.
            translator.js:201 Loading core translation file: translations/de.json
            translator.js:224 Loading core translation fallback file: translations/en.json
            loader.js:182 Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js
            module.js:469 Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.1.0 - Current version: 2.6.0
            module.js:471 Version is ok!
            module.js:477 Module registered: MMM-Remote-Control
            loader.js:152 Bootstrapping module: MMM-Remote-Control
            loader.js:157 Scripts loaded for: MMM-Remote-Control
            loader.js:197 Load stylesheet: modules/MMM-Remote-Control/remote-control.css
            loader.js:159 Styles loaded for: MMM-Remote-Control
            loader.js:161 Translations loaded for: MMM-Remote-Control
            loader.js:182 Load script: modules/MMM-Buttons//MMM-Buttons.js
            module.js:469 Check MagicMirror version for module 'MMM-Buttons' - Minimum version:  2.1.0 - Current version: 2.6.0
            module.js:477 Module registered: MMM-Buttons
            loader.js:152 Bootstrapping module: MMM-Buttons
            loader.js:157 Scripts loaded for: MMM-Buttons
            loader.js:159 Styles loaded for: MMM-Buttons
            loader.js:161 Translations loaded for: MMM-Buttons
            loader.js:182 Load script: modules/MMM-Page-Selector//MMM-Page-Selector.js
            module.js:469 Check MagicMirror version for module 'MMM-Page-Selector' - Minimum version:  2.1.0 - Current version: 2.6.0
            module.js:477 Module registered: MMM-Page-Selector
            loader.js:152 Bootstrapping module: MMM-Page-Selector
            loader.js:182 Load script: modules/MMM-Page-Selector/resources/numConvert.js
            loader.js:157 Scripts loaded for: MMM-Page-Selector
            loader.js:197 Load stylesheet: modules/MMM-Page-Selector/MMM-Page-Selector.css
            loader.js:159 Styles loaded for: MMM-Page-Selector
            loader.js:161 Translations loaded for: MMM-Page-Selector
            loader.js:182 Load script: modules/default/alert//alert.js
            module.js:477 Module registered: alert
            loader.js:152 Bootstrapping module: alert
            loader.js:182 Load script: modules/default/alert/classie.js
            loader.js:182 Load script: modules/default/alert/modernizr.custom.js
            loader.js:182 Load script: modules/default/alert/notificationFx.js
            loader.js:157 Scripts loaded for: alert
            loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
            loader.js:159 Styles loaded for: alert
            translator.js:172 alert - Load translation: translations/de.json
            /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure protocols. This exposes users of this app to unnecessary security risks. Consider loading the following resources over HTTPS or FTPS.
            - http://0.0.0.0:8080/css/main.css
            - http://0.0.0.0:8080/fonts/roboto.css
            - http://0.0.0.0:8080/socket.io/socket.io.js
            - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
            - http://0.0.0.0:8080/js/defaults.js
            - http://0.0.0.0:8080/config/config.js
            - http://0.0.0.0:8080/vendor/vendor.js
            - http://0.0.0.0:8080/modules/default/defaultmodules.js
            - http://0.0.0.0:8080/js/logger.js
            - http://0.0.0.0:8080/translations/translations.js
            - http://0.0.0.0:8080/js/translator.js
            - http://0.0.0.0:8080/js/class.js
            - http://0.0.0.0:8080/js/module.js
            - http://0.0.0.0:8080/js/loader.js
            - http://0.0.0.0:8080/js/socketclient.js
            - http://0.0.0.0:8080/js/main.js
            - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
            - http://0.0.0.0:8080/translations/de.json
            - http://0.0.0.0:8080/translations/en.json
            - http://0.0.0.0:8080/modules/MMM-Remote-Control//MMM-Remote-Control.js
            - http://0.0.0.0:8080/modules/MMM-Remote-Control/remote-control.css
            - http://0.0.0.0:8080/modules/MMM-Buttons//MMM-Buttons.js
            - http://0.0.0.0:8080/modules/MMM-Page-Selector//MMM-Page-Selector.js
            - http://0.0.0.0:8080/modules/MMM-Page-Selector/resources/numConvert.js
            - http://0.0.0.0:8080/modules/MMM-Page-Selector/MMM-Page-Selector.css
            - http://0.0.0.0:8080/modules/default/alert//alert.js
            - http://0.0.0.0:8080/modules/default/alert/classie.js
            - http://0.0.0.0:8080/modules/default/alert/modernizr.custom.js
            - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
            - http://0.0.0.0:8080/modules/default/alert/ns-default.css
            For more information and help, consult https://electronjs.org/docs/tutorial/security.
            This warning will not show up once the app is packaged.
            warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128
            /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:188 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security Policy set or a policy with "unsafe-eval" enabled. This exposes users of this app to unnecessary security risks.
            warnAboutInsecureCSP @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:188
            translator.js:174 alert - Load translation fallback: translations/en.json
            loader.js:161 Translations loaded for: alert
            loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
            module.js:477 Module registered: updatenotification
            loader.js:152 Bootstrapping module: updatenotification
            loader.js:157 Scripts loaded for: updatenotification
            loader.js:159 Styles loaded for: updatenotification
            loader.js:161 Translations loaded for: updatenotification
            loader.js:182 Load script: modules/default/clock//clock.js
            module.js:477 Module registered: clock
            loader.js:152 Bootstrapping module: clock
            loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
            loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
            loader.js:157 Scripts loaded for: clock
            loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
            loader.js:159 Styles loaded for: clock
            loader.js:161 Translations loaded for: clock
            loader.js:182 Load script: modules/default/currentweather//currentweather.js
            module.js:477 Module registered: currentweather
            loader.js:152 Bootstrapping module: currentweather
            loader.js:237 File already loaded: moment.js
            loader.js:157 Scripts loaded for: currentweather
            loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
            loader.js:197 Load stylesheet: modules/default/currentweather/currentweather.css
            loader.js:159 Styles loaded for: currentweather
            loader.js:161 Translations loaded for: currentweather
            loader.js:182 Load script: modules/MMM-Podcast2//MMM-Podcast2.js
            module.js:477 Module registered: MMM-Podcast2
            loader.js:152 Bootstrapping module: MMM-Podcast2
            loader.js:182 Load script: modules/MMM-Podcast2/MMM-Podcast-xml2json.js
            loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
            loader.js:157 Scripts loaded for: MMM-Podcast2
            loader.js:197 Load stylesheet: modules/MMM-Podcast2/MMM-Podcast2.css
            loader.js:159 Styles loaded for: MMM-Podcast2
            loader.js:161 Translations loaded for: MMM-Podcast2
            loader.js:182 Load script: modules/default/newsfeed//newsfeed.js
            module.js:477 Module registered: newsfeed
            loader.js:152 Bootstrapping module: newsfeed
            loader.js:157 Scripts loaded for: newsfeed
            loader.js:159 Styles loaded for: newsfeed
            loader.js:161 Translations loaded for: newsfeed
            loader.js:197 Load stylesheet: css/custom.css
            MMM-Remote-Control.js:21 Starting module: MMM-Remote-Control
            MMM-Buttons.js:25 Starting module: MMM-Buttons
            alert.js:153 Starting module: alert
            updatenotification.js:10 Start updatenotification
            clock.js:40 Starting module: clock
            currentweather.js:96 Starting module: currentweather
            MMM-Podcast2.js:38 Starting module: MMM-Podcast2
            newsfeed.js:59 Starting module: newsfeed
            main.js:468 All modules started!
            module.js:156 MMM-Buttons received a system notification: ALL_MODULES_STARTED
            module.js:156 clock received a system notification: ALL_MODULES_STARTED
            newsfeed.js:340 newsfeed - received notification: ALL_MODULES_STARTED
            newsfeed.js:391 newsfeed - unknown notification, ignoring: ALL_MODULES_STARTED
            module.js:198 MMM-Remote-Control is suspended.
            module.js:198 MMM-Buttons is suspended.
            module.js:198 alert is suspended.
            module.js:198 MMM-Podcast2 is suspended.
            module.js:156 clock received a system notification: MODULE_DOM_CREATED
            newsfeed.js:340 newsfeed - received notification: MODULE_DOM_CREATED
            newsfeed.js:391 newsfeed - unknown notification, ignoring: MODULE_DOM_CREATED
            module.js:156 MMM-Buttons received a system notification: DOM_OBJECTS_CREATED
            module.js:156 clock received a system notification: DOM_OBJECTS_CREATED
            newsfeed.js:340 newsfeed - received notification: DOM_OBJECTS_CREATED
            newsfeed.js:391 newsfeed - unknown notification, ignoring: DOM_OBJECTS_CREATED
            module.js:198 MMM-Page-Selector is suspended.
            module.js:198 clock is suspended.
            module.js:198 newsfeed is suspended.
            module.js:198 updatenotification is suspended.
            module.js:198 currentweather is suspended.
            currentweather.js:338 GET https://api.openweathermap.org/data/2.5/weather?id=2825297&units=metric&lang=de&APPID=mypersonalid net::ERR_INTERNET_DISCONNECTED
            updateWeather @ currentweather.js:338
            (anonymous) @ currentweather.js:499
            setTimeout (async)
            scheduleUpdate @ currentweather.js:498
            start @ currentweather.js:112
            startModules @ loader.js:55
            (anonymous) @ loader.js:40
            stylesheet.onload @ loader.js:203
            currentweather.js:330 currentweather: Could not load weather.
            weatherRequest.onreadystatechange @ currentweather.js:330
            XMLHttpRequest.send (async)
            setTimeout (async)
            MMM-Podcast-xml2json.js:65 Uncaught TypeError: xmlStr.replace is not a function
                at cleanXML (MMM-Podcast-xml2json.js:65)
                at xml2json (MMM-Podcast-xml2json.js:11)
                at Class.socketNotificationReceived (MMM-Podcast2.js:88)
                at module.js:246
                at r.<anonymous> (socketclient.js:25)
                at r.emit (index.js:83)
                at r.onevent (index.js:83)
                at r.MMSocket.self.socket.onevent (socketclient.js:19)
                at r.onpacket (index.js:83)
                at r.<anonymous> (index.js:83)
            cleanXML @ MMM-Podcast-xml2json.js:65
            xml2json @ MMM-Podcast-xml2json.js:11
            socketNotificationReceived @ MMM-Podcast2.js:88
            (anonymous) @ module.js:246
            (anonymous) @ socketclient.js:25
            r.emit @ index.js:83
            r.onevent @ index.js:83
            MMSocket.self.socket.onevent @ socketclient.js:19
            r.onpacket @ index.js:83
            (anonymous) @ index.js:83
            r.ondecoded @ index.js:83
            a.add @ index.js:83
            r.ondata @ index.js:83
            r.onPacket @ index.js:83
            n @ index.js:83
            e.decodePayload @ index.js:83
            r.onData @ index.js:83
            i.onData @ index.js:83
            i.onLoad @ index.js:83
            hasXDR.n.onreadystatechange @ index.js:83
            i.create @ index.js:83
            i @ index.js:83
            o.request @ index.js:83
            o.doPoll @ index.js:83
            r.poll @ index.js:83
            i @ index.js:83
            i @ index.js:83
            i @ index.js:83
            i @ index.js:83
            r.doOpen @ index.js:83
            r.open @ index.js:83
            r @ index.js:83
            r @ index.js:83
            r.open.r.connect @ index.js:83
            r @ index.js:83
            r @ index.js:83
            r @ index.js:83
            MMSocket @ socketclient.js:11
            socket @ module.js:241
            sendSocketNotification @ module.js:378
            sendConfig @ MMM-Buttons.js:49
            start @ MMM-Buttons.js:27
            setTimeout (async)
            weatherRequest.onreadystatechange @ currentweather.js:334
            setTimeout (async)
            setTimeout (async)
            setTimeout (async)
            MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: PAGE_SELECT from sender: MMM-Buttons
            MMM-Page-Selector.js:116 Uncaught TypeError: Cannot read property 'haupt' of undefined
                at Class.setUpPage (MMM-Page-Selector.js:116)
                at Class.changePage (MMM-Page-Selector.js:174)
                at selectPage (MMM-Page-Selector.js:187)
                at Class.notificationReceived (MMM-Page-Selector.js:191)
                at sendNotification (main.js:95)
                at Object.sendNotification (main.js:498)
                at Class.sendNotification (module.js:368)
                at Class.sendAction (MMM-Buttons.js:88)
                at Class.buttonUp (MMM-Buttons.js:77)
                at Class.socketNotificationReceived (MMM-Buttons.js:120)
            setUpPage @ MMM-Page-Selector.js:116
            changePage @ MMM-Page-Selector.js:174
            selectPage @ MMM-Page-Selector.js:187
            notificationReceived @ MMM-Page-Selector.js:191
            sendNotification @ main.js:95
            sendNotification @ main.js:498
            sendNotification @ module.js:368
            sendAction @ MMM-Buttons.js:88
            buttonUp @ MMM-Buttons.js:77
            socketNotificationReceived @ MMM-Buttons.js:120
            a.add @ index.js:83
            ws.onmessage @ index.js:83
            setTimeout (async)
            MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: BUTTON_PRESSED from sender: MMM-Buttons
            module.js:154 clock received a module notification: BUTTON_PRESSED from sender: MMM-Buttons
            MMM-Podcast2.js:72 Uncaught ReferenceError: streamurl is not defined
                at Class.notificationReceived (MMM-Podcast2.js:72)
                at module.js:246
            notificationReceived @ MMM-Podcast2.js:72
            a.add @ index.js:83
            setTimeout (async)
            module.js:205 currentweather is resumed.
            main.js:275 Will not show currentweather. LockStrings active: module_2_MMM-Page-Selector
            MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: CURRENTWEATHER_DATA from sender: currentweather
            module.js:154 MMM-Buttons received a module notification: CURRENTWEATHER_DATA from sender: currentweather
            module.js:154 clock received a module notification: CURRENTWEATHER_DATA from sender: currentweather
            newsfeed.js:340 newsfeed - received notification: CURRENTWEATHER_DATA
            newsfeed.js:391 newsfeed - unknown notification, ignoring: CURRENTWEATHER_DATA
            a.add @ index.js:83
            MMM-Page-Selector.js:116 Uncaught TypeError: Cannot read property 'zweite' of undefined
            a.add @ index.js:83
            MMM-Podcast2.js:76 Uncaught ReferenceError: streamurl is not defined
                at Class.notificationReceived (MMM-Podcast2.js:76)
                at module.js:246
            notificationReceived @ MMM-Podcast2.js:76
            a.add @ index.js:83
            MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
            module.js:154 MMM-Buttons received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
            module.js:154 clock received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
            newsfeed.js:340 newsfeed - received notification: MAX_PAGES_CHANGED
            newsfeed.js:391 newsfeed - unknown notification, ignoring: MAX_PAGES_CHANGED
            MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
            module.js:154 MMM-Buttons received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
            module.js:154 clock received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
            newsfeed.js:340 newsfeed - received notification: PAGE_CHANGED
            newsfeed.js:391 newsfeed - unknown notification, ignoring: PAGE_CHANGED
            module.js:205 MMM-Page-Selector is resumed.
            module.js:205 clock is resumed.
            module.js:154 clock received a module notification: PAGE_SELECT from sender: MMM-Buttons
            newsfeed.js:340 newsfeed - received notification: PAGE_SELECT
            newsfeed.js:391 newsfeed - unknown notification, ignoring: PAGE_SELECT
            MMM-Page-Selector.js:83 Uncaught Module was selected, but not found in the DOM. Make sure that a position for the module is set in the config.js!
            getModuleRef @ MMM-Page-Selector.js:83
            MM.getModules.enumerate.module @ MMM-Page-Selector.js:143
            (anonymous) @ main.js:433
            enumerate @ main.js:432
            setTimeout @ MMM-Page-Selector.js:137
            setTimeout (async)
            setUpPage @ MMM-Page-Selector.js:136
            a.add @ index.js:83
                at module.js:246
            a.add @ index.js:83
            setTimeout (async)
              @robiv8 yep, as I said… lots of errors… most not recoverable due to the modules individual designs…
              MMM-Podcast-xml2json.js:65,    dies as no xml came back.. oops..
              MMM-Page-Selector.js:116 ,   oops.. the target page doesn't exist (cause the prior module failed to build it..)
              MMM-Podcast2.js:72,
              etc
                robiv8
                Thanks for the information,
                That means I can only hope and ask that the makers of the modules fix that? If that’s even possible!
                  sdetweil @robiv8
                  @robiv8 right. In many cases the authors hope that users will jump in and modify the code and submit it back… as this is all volunteer work.
                  welcome to open source
                    robiv8
                    OK i understand! :winking_face:
                    That leaves us mortals, only hope.
                    So bleibt uns Sterblichen, nur noch die Hoffnung.
                      robiv8
                      I experimented a lot and read a lot.
                      This “streamurl is not defined” has made me curious.
                      So i put a new entry in the MMM podcast2.js under line 12 with:
                      var streamurl = '';
                      then it will work after a reboot, but not right after the first press.
                      You have to press again and next time it will come.
                      So page is set up, then Press Button for Play, Press Button for Stop, Press Button for Play and then comes the video. Very Strange.
                      Server started ...
                      Connecting socket for: MMM-Remote-Control
                      Starting node helper for: MMM-Remote-Control
                      Connecting socket for: MMM-Buttons
                      Starting node helper for: MMM-Buttons
                      Connecting socket for: MMM-Page-Selector
                      Connecting socket for: MMM-Podcast2
                      Launching application.
                      Initialize button Hauptseite on PIN 17
                      Initialize button Podcast on PIN 24
                      Starting node helper for: MMM-Podcast2
                      Create new news fetcher for url: http://www.stuttgarter-nachrichten.de/stuttgart.rss.feed - Interval: 300000
                      Use existing news fetcher for url: http://www.stuttgarter-nachrichten.de/stuttgart.rss.feed
                      The site has now fully built up.
                      Now i press the button:
                      MMM-Podcast2 PLAY: < -- Nothing! Also do not wait for a longer time
                      MMM-Podcast2 STOP:
                      MMM-Podcast2 PLAY: < -- now comes the Video
                      MMM-Podcast2 STOP:
                      Does anyone have a tip what this can still be?
                      For that I have no idea about the programming I am proud that I have managed it so :-) lol
                        go back to the dev console, npm start dev, or ctrl-shift-i, then select console tab, and see if there is an error on the browser side, where the video will actually play…
                        looks like its state is out of sync… (thinks its neither playing nor stopped)…
                        getting stop fixes it…
                          robiv8
                          OK i do my best
                            AxLed Module Developer
                            @robiv8
                            I guess i found the solution of your problem, it is the combination of MMM-Page-Selector and MMM-Podcast2 the way you used it in your config.js
                            Details see MMM-Podcast2/issues
                            AxLED
                              robiv8
                              Werde ich gleich morgen Nachmittag testen, das wäre ja der große Knaller.
                              Danke fürs recherchieren.
                              Ich werde auf jedenfall Rückmelden.
                              Will I test the same tomorrow afternoon, that would be the big bang.
                              Thanks for researching.
                              I will definitely confirm.
