Start without internet connection and restart with, make modul work?
13 Posts 3 Posters 3.5k Views 3 Watching
    robiv8
    Prehistory:
    I’ve been trying for weeks to switch pages with Real Buttons. This works quite well with MMM Page Selector.
    Now I wanted to press the button to display the Tagesschau 100sek with the module Podcast2.
    For days I try to integrate and it just does not start.
    Today:
    By a stupid coincidence, I discovered something.
    I went to work and took my Raspi to test by the way. Raspi started, desktop stays black! Aaaah! OK No internet. I put F11 so that I come to the desktop, then Turn on the W-LAN because otherwise no Internet possible. Terminal opened and MM restarted. “pm2 restart mm”
    MM comes. I think I’ll push the 2 buttons if the two sides are still changing, and YES it still does. Wy not ;-) Press the 3 button and behold! Podcast starts to run. I’m amazed. But why? What the hell is going on.
    I think, and do some tests.
    The following, if I start the computer without Internet, then shrink MM to get to the wi-fi switch ,. Turn on W-Lan and restart MM, the button works and podcast starts.
    But if I restart MM now it does not work anymore. So i must Start without Internet connection then restart MM and its Going.
    Very Strange!
    Now I’m not sure why that is and where to ask for help?
    MMM-Buttons
    MMM-Page-Selector,
    MMM-Podcast2
    or
    on the MagicMirror itself
      start the mirror without internet, but open the dev console (npm start dev),
      select the console tab… look for errors…
      most of the modules do not recover from system issues like this from startup… they might AFTER successfully starting, if the internet were to go out and come back…
        robiv8
        Thanks for the tip.
        I am going now home and will try it.
          robiv8
          So I have do it and here is the log file.
          main.js:450 Initializing MagicMirror.
          translator.js:201 Loading core translation file: translations/de.json
          translator.js:224 Loading core translation fallback file: translations/en.json
          loader.js:182 Load script: modules/MMM-Remote-Control//MMM-Remote-Control.js
          module.js:469 Check MagicMirror version for module 'MMM-Remote-Control' - Minimum version:  2.1.0 - Current version: 2.6.0
          module.js:471 Version is ok!
          module.js:477 Module registered: MMM-Remote-Control
          loader.js:152 Bootstrapping module: MMM-Remote-Control
          loader.js:157 Scripts loaded for: MMM-Remote-Control
          loader.js:197 Load stylesheet: modules/MMM-Remote-Control/remote-control.css
          loader.js:159 Styles loaded for: MMM-Remote-Control
          loader.js:161 Translations loaded for: MMM-Remote-Control
          loader.js:182 Load script: modules/MMM-Buttons//MMM-Buttons.js
          module.js:469 Check MagicMirror version for module 'MMM-Buttons' - Minimum version:  2.1.0 - Current version: 2.6.0
          module.js:477 Module registered: MMM-Buttons
          loader.js:152 Bootstrapping module: MMM-Buttons
          loader.js:157 Scripts loaded for: MMM-Buttons
          loader.js:159 Styles loaded for: MMM-Buttons
          loader.js:161 Translations loaded for: MMM-Buttons
          loader.js:182 Load script: modules/MMM-Page-Selector//MMM-Page-Selector.js
          module.js:469 Check MagicMirror version for module 'MMM-Page-Selector' - Minimum version:  2.1.0 - Current version: 2.6.0
          module.js:477 Module registered: MMM-Page-Selector
          loader.js:152 Bootstrapping module: MMM-Page-Selector
          loader.js:182 Load script: modules/MMM-Page-Selector/resources/numConvert.js
          loader.js:157 Scripts loaded for: MMM-Page-Selector
          loader.js:197 Load stylesheet: modules/MMM-Page-Selector/MMM-Page-Selector.css
          loader.js:159 Styles loaded for: MMM-Page-Selector
          loader.js:161 Translations loaded for: MMM-Page-Selector
          loader.js:182 Load script: modules/default/alert//alert.js
          module.js:477 Module registered: alert
          loader.js:152 Bootstrapping module: alert
          loader.js:182 Load script: modules/default/alert/classie.js
          loader.js:182 Load script: modules/default/alert/modernizr.custom.js
          loader.js:182 Load script: modules/default/alert/notificationFx.js
          loader.js:157 Scripts loaded for: alert
          loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
          loader.js:159 Styles loaded for: alert
          translator.js:172 alert - Load translation: translations/de.json
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure protocols. This exposes users of this app to unnecessary security risks. Consider loading the following resources over HTTPS or FTPS.
          - http://0.0.0.0:8080/css/main.css
          - http://0.0.0.0:8080/fonts/roboto.css
          - http://0.0.0.0:8080/socket.io/socket.io.js
          - http://0.0.0.0:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
          - http://0.0.0.0:8080/js/defaults.js
          - http://0.0.0.0:8080/config/config.js
          - http://0.0.0.0:8080/vendor/vendor.js
          - http://0.0.0.0:8080/modules/default/defaultmodules.js
          - http://0.0.0.0:8080/js/logger.js
          - http://0.0.0.0:8080/translations/translations.js
          - http://0.0.0.0:8080/js/translator.js
          - http://0.0.0.0:8080/js/class.js
          - http://0.0.0.0:8080/js/module.js
          - http://0.0.0.0:8080/js/loader.js
          - http://0.0.0.0:8080/js/socketclient.js
          - http://0.0.0.0:8080/js/main.js
          - http://0.0.0.0:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
          - http://0.0.0.0:8080/translations/de.json
          - http://0.0.0.0:8080/translations/en.json
          - http://0.0.0.0:8080/modules/MMM-Remote-Control//MMM-Remote-Control.js
          - http://0.0.0.0:8080/modules/MMM-Remote-Control/remote-control.css
          - http://0.0.0.0:8080/modules/MMM-Buttons//MMM-Buttons.js
          - http://0.0.0.0:8080/modules/MMM-Page-Selector//MMM-Page-Selector.js
          - http://0.0.0.0:8080/modules/MMM-Page-Selector/resources/numConvert.js
          - http://0.0.0.0:8080/modules/MMM-Page-Selector/MMM-Page-Selector.css
          - http://0.0.0.0:8080/modules/default/alert//alert.js
          - http://0.0.0.0:8080/modules/default/alert/classie.js
          - http://0.0.0.0:8080/modules/default/alert/modernizr.custom.js
          - http://0.0.0.0:8080/modules/default/alert/notificationFx.js
          - http://0.0.0.0:8080/modules/default/alert/ns-default.css
          For more information and help, consult https://electronjs.org/docs/tutorial/security.
          This warning will not show up once the app is packaged.
          warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:128
          /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:188 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security Policy set or a policy with "unsafe-eval" enabled. This exposes users of this app to unnecessary security risks.
          warnAboutInsecureCSP @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:188
          translator.js:174 alert - Load translation fallback: translations/en.json
          loader.js:161 Translations loaded for: alert
          loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
          module.js:477 Module registered: updatenotification
          loader.js:152 Bootstrapping module: updatenotification
          loader.js:157 Scripts loaded for: updatenotification
          loader.js:159 Styles loaded for: updatenotification
          loader.js:161 Translations loaded for: updatenotification
          loader.js:182 Load script: modules/default/clock//clock.js
          module.js:477 Module registered: clock
          loader.js:152 Bootstrapping module: clock
          loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
          loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
          loader.js:157 Scripts loaded for: clock
          loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
          loader.js:159 Styles loaded for: clock
          loader.js:161 Translations loaded for: clock
          loader.js:182 Load script: modules/default/currentweather//currentweather.js
          module.js:477 Module registered: currentweather
          loader.js:152 Bootstrapping module: currentweather
          loader.js:237 File already loaded: moment.js
          loader.js:157 Scripts loaded for: currentweather
          loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
          loader.js:197 Load stylesheet: modules/default/currentweather/currentweather.css
          loader.js:159 Styles loaded for: currentweather
          loader.js:161 Translations loaded for: currentweather
          loader.js:182 Load script: modules/MMM-Podcast2//MMM-Podcast2.js
          module.js:477 Module registered: MMM-Podcast2
          loader.js:152 Bootstrapping module: MMM-Podcast2
          loader.js:182 Load script: modules/MMM-Podcast2/MMM-Podcast-xml2json.js
          loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
          loader.js:157 Scripts loaded for: MMM-Podcast2
          loader.js:197 Load stylesheet: modules/MMM-Podcast2/MMM-Podcast2.css
          loader.js:159 Styles loaded for: MMM-Podcast2
          loader.js:161 Translations loaded for: MMM-Podcast2
          loader.js:182 Load script: modules/default/newsfeed//newsfeed.js
          module.js:477 Module registered: newsfeed
          loader.js:152 Bootstrapping module: newsfeed
          loader.js:157 Scripts loaded for: newsfeed
          loader.js:159 Styles loaded for: newsfeed
          loader.js:161 Translations loaded for: newsfeed
          loader.js:197 Load stylesheet: css/custom.css
          MMM-Remote-Control.js:21 Starting module: MMM-Remote-Control
          MMM-Buttons.js:25 Starting module: MMM-Buttons
          alert.js:153 Starting module: alert
          updatenotification.js:10 Start updatenotification
          clock.js:40 Starting module: clock
          currentweather.js:96 Starting module: currentweather
          MMM-Podcast2.js:38 Starting module: MMM-Podcast2
          newsfeed.js:59 Starting module: newsfeed
          main.js:468 All modules started!
          module.js:156 MMM-Buttons received a system notification: ALL_MODULES_STARTED
          module.js:156 clock received a system notification: ALL_MODULES_STARTED
          newsfeed.js:340 newsfeed - received notification: ALL_MODULES_STARTED
          newsfeed.js:391 newsfeed - unknown notification, ignoring: ALL_MODULES_STARTED
          module.js:198 MMM-Remote-Control is suspended.
          module.js:198 MMM-Buttons is suspended.
          module.js:198 alert is suspended.
          module.js:198 MMM-Podcast2 is suspended.
          module.js:156 clock received a system notification: MODULE_DOM_CREATED
          newsfeed.js:340 newsfeed - received notification: MODULE_DOM_CREATED
          newsfeed.js:391 newsfeed - unknown notification, ignoring: MODULE_DOM_CREATED
          module.js:156 MMM-Buttons received a system notification: DOM_OBJECTS_CREATED
          module.js:156 clock received a system notification: DOM_OBJECTS_CREATED
          newsfeed.js:340 newsfeed - received notification: DOM_OBJECTS_CREATED
          newsfeed.js:391 newsfeed - unknown notification, ignoring: DOM_OBJECTS_CREATED
          module.js:198 MMM-Page-Selector is suspended.
          module.js:198 clock is suspended.
          module.js:198 newsfeed is suspended.
          module.js:198 updatenotification is suspended.
          module.js:198 currentweather is suspended.
          currentweather.js:338 GET https://api.openweathermap.org/data/2.5/weather?id=2825297&units=metric&lang=de&APPID=mypersonalid net::ERR_INTERNET_DISCONNECTED
          updateWeather @ currentweather.js:338
          (anonymous) @ currentweather.js:499
          setTimeout (async)
          scheduleUpdate @ currentweather.js:498
          start @ currentweather.js:112
          startModules @ loader.js:55
          (anonymous) @ loader.js:40
          stylesheet.onload @ loader.js:203
          currentweather.js:330 currentweather: Could not load weather.
          weatherRequest.onreadystatechange @ currentweather.js:330
          XMLHttpRequest.send (async)
          setTimeout (async)
          MMM-Podcast-xml2json.js:65 Uncaught TypeError: xmlStr.replace is not a function
              at cleanXML (MMM-Podcast-xml2json.js:65)
              at xml2json (MMM-Podcast-xml2json.js:11)
              at Class.socketNotificationReceived (MMM-Podcast2.js:88)
              at module.js:246
              at r.<anonymous> (socketclient.js:25)
              at r.emit (index.js:83)
              at r.onevent (index.js:83)
              at r.MMSocket.self.socket.onevent (socketclient.js:19)
              at r.onpacket (index.js:83)
              at r.<anonymous> (index.js:83)
          cleanXML @ MMM-Podcast-xml2json.js:65
          xml2json @ MMM-Podcast-xml2json.js:11
          socketNotificationReceived @ MMM-Podcast2.js:88
          (anonymous) @ module.js:246
          (anonymous) @ socketclient.js:25
          r.emit @ index.js:83
          r.onevent @ index.js:83
          MMSocket.self.socket.onevent @ socketclient.js:19
          r.onpacket @ index.js:83
          (anonymous) @ index.js:83
          r.ondecoded @ index.js:83
          a.add @ index.js:83
          r.ondata @ index.js:83
          r.onPacket @ index.js:83
          n @ index.js:83
          e.decodePayload @ index.js:83
          r.onData @ index.js:83
          i.onData @ index.js:83
          i.onLoad @ index.js:83
          hasXDR.n.onreadystatechange @ index.js:83
          i.create @ index.js:83
          i @ index.js:83
          o.request @ index.js:83
          o.doPoll @ index.js:83
          r.poll @ index.js:83
          i @ index.js:83
          i @ index.js:83
          i @ index.js:83
          i @ index.js:83
          r.doOpen @ index.js:83
          r.open @ index.js:83
          r @ index.js:83
          r @ index.js:83
          r.open.r.connect @ index.js:83
          r @ index.js:83
          r @ index.js:83
          r @ index.js:83
          MMSocket @ socketclient.js:11
          socket @ module.js:241
          sendSocketNotification @ module.js:378
          sendConfig @ MMM-Buttons.js:49
          start @ MMM-Buttons.js:27
          setTimeout (async)
          weatherRequest.onreadystatechange @ currentweather.js:334
          setTimeout (async)
          setTimeout (async)
          setTimeout (async)
          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: PAGE_SELECT from sender: MMM-Buttons
          MMM-Page-Selector.js:116 Uncaught TypeError: Cannot read property 'haupt' of undefined
              at Class.setUpPage (MMM-Page-Selector.js:116)
              at Class.changePage (MMM-Page-Selector.js:174)
              at selectPage (MMM-Page-Selector.js:187)
              at Class.notificationReceived (MMM-Page-Selector.js:191)
              at sendNotification (main.js:95)
              at Object.sendNotification (main.js:498)
              at Class.sendNotification (module.js:368)
              at Class.sendAction (MMM-Buttons.js:88)
              at Class.buttonUp (MMM-Buttons.js:77)
              at Class.socketNotificationReceived (MMM-Buttons.js:120)
          setUpPage @ MMM-Page-Selector.js:116
          changePage @ MMM-Page-Selector.js:174
          selectPage @ MMM-Page-Selector.js:187
          notificationReceived @ MMM-Page-Selector.js:191
          sendNotification @ main.js:95
          sendNotification @ main.js:498
          sendNotification @ module.js:368
          sendAction @ MMM-Buttons.js:88
          buttonUp @ MMM-Buttons.js:77
          socketNotificationReceived @ MMM-Buttons.js:120
          a.add @ index.js:83
          ws.onmessage @ index.js:83
          setTimeout (async)
          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: BUTTON_PRESSED from sender: MMM-Buttons
          module.js:154 clock received a module notification: BUTTON_PRESSED from sender: MMM-Buttons
          MMM-Podcast2.js:72 Uncaught ReferenceError: streamurl is not defined
              at Class.notificationReceived (MMM-Podcast2.js:72)
              at module.js:246
          notificationReceived @ MMM-Podcast2.js:72
          a.add @ index.js:83
          setTimeout (async)
          module.js:205 currentweather is resumed.
          main.js:275 Will not show currentweather. LockStrings active: module_2_MMM-Page-Selector
          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: CURRENTWEATHER_DATA from sender: currentweather
          module.js:154 MMM-Buttons received a module notification: CURRENTWEATHER_DATA from sender: currentweather
          module.js:154 clock received a module notification: CURRENTWEATHER_DATA from sender: currentweather
          newsfeed.js:340 newsfeed - received notification: CURRENTWEATHER_DATA
          newsfeed.js:391 newsfeed - unknown notification, ignoring: CURRENTWEATHER_DATA
          a.add @ index.js:83
          MMM-Page-Selector.js:116 Uncaught TypeError: Cannot read property 'zweite' of undefined
          a.add @ index.js:83
          MMM-Podcast2.js:76 Uncaught ReferenceError: streamurl is not defined
              at Class.notificationReceived (MMM-Podcast2.js:76)
              at module.js:246
          notificationReceived @ MMM-Podcast2.js:76
          a.add @ index.js:83
          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
          module.js:154 MMM-Buttons received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
          module.js:154 clock received a module notification: MAX_PAGES_CHANGED from sender: MMM-Page-Selector
          newsfeed.js:340 newsfeed - received notification: MAX_PAGES_CHANGED
          newsfeed.js:391 newsfeed - unknown notification, ignoring: MAX_PAGES_CHANGED
          MMM-Remote-Control.js:36 MMM-Remote-Control received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
          module.js:154 MMM-Buttons received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
          module.js:154 clock received a module notification: PAGE_CHANGED from sender: MMM-Page-Selector
          newsfeed.js:340 newsfeed - received notification: PAGE_CHANGED
          newsfeed.js:391 newsfeed - unknown notification, ignoring: PAGE_CHANGED
          module.js:205 MMM-Page-Selector is resumed.
          module.js:205 clock is resumed.
          module.js:154 clock received a module notification: PAGE_SELECT from sender: MMM-Buttons
          newsfeed.js:340 newsfeed - received notification: PAGE_SELECT
          newsfeed.js:391 newsfeed - unknown notification, ignoring: PAGE_SELECT
          MMM-Page-Selector.js:83 Uncaught Module was selected, but not found in the DOM. Make sure that a position for the module is set in the config.js!
          getModuleRef @ MMM-Page-Selector.js:83
          MM.getModules.enumerate.module @ MMM-Page-Selector.js:143
          (anonymous) @ main.js:433
          enumerate @ main.js:432
          setTimeout @ MMM-Page-Selector.js:137
          setTimeout (async)
          setUpPage @ MMM-Page-Selector.js:136
          a.add @ index.js:83
              at module.js:246
          a.add @ index.js:83
          setTimeout (async)
            @robiv8 yep, as I said… lots of errors… most not recoverable due to the modules individual designs…
            MMM-Podcast-xml2json.js:65,    dies as no xml came back.. oops..
            MMM-Page-Selector.js:116 ,   oops.. the target page doesn't exist (cause the prior module failed to build it..)
            MMM-Podcast2.js:72,
            etc
              robiv8
              Thanks for the information,
              That means I can only hope and ask that the makers of the modules fix that? If that’s even possible!
              S 1 Reply Last reply Jan 14, 2019, 10:42 PM Reply Quote 0
                sdetweil @robiv8
                @robiv8 right. In many cases the authors hope that users will jump in and modify the code and submit it back… as this is all volunteer work.
                welcome to open source
                  robiv8
                  OK i understand! :winking_face:
                  That leaves us mortals, only hope.
                  So bleibt uns Sterblichen, nur noch die Hoffnung.
                    robiv8
                    I experimented a lot and read a lot.
                    This “streamurl is not defined” has made me curious.
                    So i put a new entry in the MMM podcast2.js under line 12 with:
                    var streamurl = '';
                    then it will work after a reboot, but not right after the first press.
                    You have to press again and next time it will come.
                    So page is set up, then Press Button for Play, Press Button for Stop, Press Button for Play and then comes the video. Very Strange.
                    Server started ...
                    Connecting socket for: MMM-Remote-Control
                    Starting node helper for: MMM-Remote-Control
                    Connecting socket for: MMM-Buttons
                    Starting node helper for: MMM-Buttons
                    Connecting socket for: MMM-Page-Selector
                    Connecting socket for: MMM-Podcast2
                    Launching application.
                    Initialize button Hauptseite on PIN 17
                    Initialize button Podcast on PIN 24
                    Starting node helper for: MMM-Podcast2
                    Create new news fetcher for url: http://www.stuttgarter-nachrichten.de/stuttgart.rss.feed - Interval: 300000
                    Use existing news fetcher for url: http://www.stuttgarter-nachrichten.de/stuttgart.rss.feed
                    The site has now fully built up.
                    Now i press the button:
                    MMM-Podcast2 PLAY: < -- Nothing! Also do not wait for a longer time
                    MMM-Podcast2 STOP:
                    MMM-Podcast2 PLAY: < -- now comes the Video
                    MMM-Podcast2 STOP:
                    Does anyone have a tip what this can still be?
                    For that I have no idea about the programming I am proud that I have managed it so :-) lol
                      go back to the dev console, npm start dev, or ctrl-shift-i, then select console tab, and see if there is an error on the browser side, where the video will actually play…
                      looks like its state is out of sync… (thinks its neither playing nor stopped)…
                      getting stop fixes it…
