    MMM-AssistantMk2
    421 Posts 61 Posters 804.1k Views 57 Watching
      Jmh474
      Sorry this is my first post, are there any guides for helping me install the MMM-assistantMK2 I’m a total beginner With the raspberry pi any help would be much appreciated
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @Jmh474
        @jmh474 Follow the link in the first post that bring you to GitHub.
        Once there follow CAREFULLY the step-by-step installation & configuration.
        Only then if there’s still anything not clear or not working ask here. ;)
        J 1 Reply Last reply
          Jmh474 @Cr4z33
          @cr4z33 OK thanks mate
            reddyman @Guest
            For second issue; Are you using other module to control to hide and show modules? Maybe it makes to show specific module by force. There is no way to prevent force revealing by other module.
            https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#visibility-locking
            No luck here, I ended up doing a fresh install with no other modules installed and it still happens. Can’t figure why it only applies to the default weather app, even if I move the position.
            I can’t figure out why no one else has this issue. Oh well, I guess I can just not use the “hide all” command though. Thanks!
            citizendevpiC 1 Reply Last reply
            • citizendevpiC
              citizendevpi @reddyman
              @reddyman my mirror also pops up the default weather after hide all , I got use to it
              ? 1 Reply Last reply
                A Former User @citizendevpi
                @citizendevpi @reddyman
                I’ll check it as soon as possible.
                W 1 Reply Last reply
                • W
                  wearable9083 @Guest
                  @sean
                  Thank you always for your complete modules.
                  I have some questions about YouTube. The YouTube video screen is always full. Is there a way to reduce the size of a pop-up window?
                  And one more thing: can’t I stop or give another command while watching the video?
                    A Former User @wearable9083
                    @wearable9083
                    For Resizing Video Player; add this into your css/custom.css and adjust the values;
                    #ASSISTANT_YOUTUBE {
                      position:fixed;
                      top:20px;
                      left:20px;
                      width:400px;
                      height:300px;
                    And you can stop playing video by hotword waking with option pauseOnYoutube:false.
                    • W
                      wearable9083 @Guest
                      @sean
                      Thank you very much for your kind answer.
                      But, ;(
                      Detects hotword during video playback and stops video, but then fails to perform any of the following commands…
                        @wearable9083 If you failed, just try again. I think it might be caused by some lack of resource performance but that might not be the fatal problem. Or, Did you mean AssistantMk2 not working after youtube playing?
                        • W
                          wearable9083 @Guest
                          @sean
                          After assistant-mk2 has detected hotword, no voice command has been recognized. (during video playback)
                          [Voice commands are well recognized when the video is played through without stop.]
                            @wearable9083
                            Only after closing video, you can order to assistant.
                            If command be allowed during video playing, Assistant will be activated by sounds of video. So during playing, Assistant is disabled.
                            • W
                              wearable9083 @Guest
                              @sean
                              Thank you so much. ♥♥
                              I’ll make the most of the information you’ve given me. Thank you. :)
                              Have a nice day!
                                costascontis
                                @Sean at last got MMM-AssistantMk2 up and running with MMM-Hotword.I have only one little problem,when i ask something i lose the first word of the answer.It is like hdmi sound channel is down and needs 1 sec to wake so i cant hear the first word of the answer.I add to /boot/config.txt the line “force_hdmi_open=1” but didnt help.At my standalone raspberry google assistant installation i had the same problem and this line solved it,but not here…
                                  A Former User @costascontis
                                  @costascontis
                                  Sorry, I have no idea about it. Maybe my module would close HDMI when it doesn’t be needed. (Standalone version could open HDMI continuously by force, because there is no need to close for other’s occupation)
                                    costascontis @Guest
                                    @sean it is very annoying not to listen the first word or missing the half of it,do you have an idea to keep hdmi on all the time?
                                    edit: if i use the .asoundrc file of my other gassistant i have no delay but the voice is choppy.
                                    pcm.dsnooper {
                                        type dsnoop
                                        ipc_key 816357492
                                        ipc_key_add_uid 0
                                        ipc_perm 0666
                                        slave {
                                            pcm "hw:1,0"
                                            channels 1
                                    pcm.!default {
                                            type asym
                                            playback.pcm {
                                                    type plug
                                                    slave.pcm "hw:0,1"
                                            capture.pcm {
                                                    type plug
                                                    slave.pcm "dsnooper"
                                    if i use the default .asoundrc the voice is clear but with a start delay
                                    pcm.!default {
                                    	type hw
                                    	card 0
                                    ctl.!default {
                                    	type hw
                                    	card 0
                                    with the first .asoundrc delayless file all other sounds at the Rpi are playback just fine ,only the MMM-AssistantMk2 voice is grainy and choppy… : (
                                      @costascontis
                                      But in that case, Other modules cannot use speaker-out. I rather recommend to use other speaker instead HDMI.
                                        costascontis
                                        yes i understand,i just think that is a MMM-AssistantMk2 's problem because when i trigger MMM-Hotword it makes a ding sound to show that its listening and that sound i can always hear it so hdmi is awake ,then i make a request to MMM-AssistantMk2 and when it answers i cant hear the first word or the first letters of it anyway…
                                        • L
                                          Lowis
                                          Hello
                                          how can MMM-AssistantMk2 start a webradio stream ? i tell the Assistant to play radio 1live. Respone is “OK” but nothing will come up.
                                          I say "show me a picture from a Dog . Respone “OK” but nothing comes up.
                                          BTW : Great Module !
                                            A Former User @Lowis
                                            @lowis
                                            Those features are allowed to REAL GOOGLE HOME devices at this moment. I hope somedays it could be allowed to Assistant SDK.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 21
                                            • 22
                                            • 11 / 22
