    MMM-AssistantMk2
    421 Posts 61 Posters 695.6k Views 57 Watching
    • citizendevpiC Offline
      citizendevpi @reddyman
      @reddyman my mirror also pops up the default weather after hide all , I got use to it
        A Former User @citizendevpi
        @citizendevpi @reddyman
        I’ll check it as soon as possible.
        • W Offline
          wearable9083 @Guest
          @sean
          Thank you always for your complete modules.
          I have some questions about YouTube. The YouTube video screen is always full. Is there a way to reduce the size of a pop-up window?
          And one more thing: can’t I stop or give another command while watching the video?
            A Former User @wearable9083
            @wearable9083
            For Resizing Video Player; add this into your css/custom.css and adjust the values;
            #ASSISTANT_YOUTUBE {
              position:fixed;
              top:20px;
              left:20px;
              width:400px;
              height:300px;
            And you can stop playing video by hotword waking with option pauseOnYoutube:false.
            W 1 Reply Last reply Reply Quote 1
            • W Offline
              wearable9083 @Guest
              @sean
              Thank you very much for your kind answer.
              But, ;(
              Detects hotword during video playback and stops video, but then fails to perform any of the following commands…
                @wearable9083 If you failed, just try again. I think it might be caused by some lack of resource performance but that might not be the fatal problem. Or, Did you mean AssistantMk2 not working after youtube playing?
                • W Offline
                  wearable9083 @Guest
                  @sean
                  After assistant-mk2 has detected hotword, no voice command has been recognized. (during video playback)
                  [Voice commands are well recognized when the video is played through without stop.]
                    @wearable9083
                    Only after closing video, you can order to assistant.
                    If command be allowed during video playing, Assistant will be activated by sounds of video. So during playing, Assistant is disabled.
                    • W Offline
                      wearable9083 @Guest
                      @sean
                      Thank you so much. ♥♥
                      I’ll make the most of the information you’ve given me. Thank you. :)
                      Have a nice day!
                        costascontis
                        @Sean at last got MMM-AssistantMk2 up and running with MMM-Hotword.I have only one little problem,when i ask something i lose the first word of the answer.It is like hdmi sound channel is down and needs 1 sec to wake so i cant hear the first word of the answer.I add to /boot/config.txt the line “force_hdmi_open=1” but didnt help.At my standalone raspberry google assistant installation i had the same problem and this line solved it,but not here…
                          A Former User @costascontis
                          @costascontis
                          Sorry, I have no idea about it. Maybe my module would close HDMI when it doesn’t be needed. (Standalone version could open HDMI continuously by force, because there is no need to close for other’s occupation)
                            costascontis @Guest
                            @sean it is very annoying not to listen the first word or missing the half of it,do you have an idea to keep hdmi on all the time?
                            edit: if i use the .asoundrc file of my other gassistant i have no delay but the voice is choppy.
                            pcm.dsnooper {
                                type dsnoop
                                ipc_key 816357492
                                ipc_key_add_uid 0
                                ipc_perm 0666
                                slave {
                                    pcm "hw:1,0"
                                    channels 1
                            pcm.!default {
                                    type asym
                                    playback.pcm {
                                            type plug
                                            slave.pcm "hw:0,1"
                                    capture.pcm {
                                            type plug
                                            slave.pcm "dsnooper"
                            if i use the default .asoundrc the voice is clear but with a start delay
                            pcm.!default {
                            	type hw
                            	card 0
                            ctl.!default {
                            	type hw
                            	card 0
                            with the first .asoundrc delayless file all other sounds at the Rpi are playback just fine ,only the MMM-AssistantMk2 voice is grainy and choppy… : (
                              @costascontis
                              But in that case, Other modules cannot use speaker-out. I rather recommend to use other speaker instead HDMI.
                                costascontis
                                yes i understand,i just think that is a MMM-AssistantMk2 's problem because when i trigger MMM-Hotword it makes a ding sound to show that its listening and that sound i can always hear it so hdmi is awake ,then i make a request to MMM-AssistantMk2 and when it answers i cant hear the first word or the first letters of it anyway…
                                • L Offline
                                  Lowis
                                  Hello
                                  how can MMM-AssistantMk2 start a webradio stream ? i tell the Assistant to play radio 1live. Respone is “OK” but nothing will come up.
                                  I say "show me a picture from a Dog . Respone “OK” but nothing comes up.
                                  BTW : Great Module !
                                    A Former User @Lowis
                                    @lowis
                                    Those features are allowed to REAL GOOGLE HOME devices at this moment. I hope somedays it could be allowed to Assistant SDK.
                                    • L Offline
                                      Lowis
                                      But a something like your youtube search and playing Should be possible for a webradio
                                        @lowis Youtube features are added by myself with Youtube API.
                                        • L Offline
                                          Lowis
                                          @Sean Yes i know. Great work ! Maybe it could expand with a webradio directory like shoutcast.com
                                            Jmh474
                                            I’m guessing that this question has been asked quite a few times so I’m sorry for the repeat.
                                            I’ve got my mirror up and running using latest resabian, MagicMirror2, modules MMM-AssistantMk2 and MMM-HOTWORD.
                                            Adding more modules soon just taking a step at a time as I’m a total beginner.
                                            Seems to be running OK apart from the Google Assistant, its running so slow when asking questions and waiting for replies, and I don’t get voice response back just like a humming sound (I’m guessing this is when Google is answering), I know sound and mic are working as I can her myself talk when testing the mic.
                                            Also what is the best setup for mic and speakers in using a USB sound card
                                            Mic is just standard 3.5mm jack type
                                            Speakers are running through a separate amp after the sound card.
                                            One more this is there a way to add an Led for when the Google Assistant is listening??
                                            Sorry for the long post I’m just so close
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 21
                                            • 22
                                            • 11 / 22
