    MMM-CalendarExt2 not showing icons in calendar
    14 Posts 4 Posters 4.9k Views 4 Watching
      sworrs
      I tried to insert icons into my calendar, but they are not been shown:
      it seems the space for the icons have been added. Here is my config.
      			module: "MMM-CalendarExt2",
      					views: [
      							mode: "week",
      							position: "middle_center",
      							type: "row",
      							slotCount: 2,
      							slotTitleFormat: "DD.MM.",
      							slotAltTitleFormat: "DD.MM.",
      							weeksFormat: "[KW] WW",
      							calendars: ["Abfall"],
      					scenes: [
      							views: ["weeks"],
      							icon: "noto-soccer-ball",
                                  url: 'https://calendar.google.com/calendar/ical/.../basic.ics',
      							auth: {
      								user: '...',
      								pass: '...',
      								method: 'basic'
      Any idea, why they are not showing up?
      BR
      sworrs
        A Former User @sworrs
        @sworrs
        Have you tried othe icons?
        If all icons are not shown, you might have front-end error to disrupt loading iconify script. Check it with “npm start dev” or opening dev-console of MM screen.
          sworrs @Guest
          @sean
          I tried different icons and they all do not show up. And you are right, I get an error in dev mode:
          iconify.min.js:13 Uncaught TypeError: n.MutationObserver is not a constructor
              at iconify.min.js:13
              at Object.i.nextInitItem (iconify.min.js:13)
          (anonymous) @ iconify.min.js:13
          i.nextInitItem @ iconify.min.js:13
          setTimeout (async)
          What does this mean?
            @sworrs
            Can I get your ics URL to examine? my email address is eouia0819@gmail.com
            I cannot represent your error on my cases So I need your ics URL.
            • O Offline
              othomys
              How does the module know where to find the icons?
                A Former User @othomys
                @othomys
                This module use iconify to show icons.
                You can find icons here : https://iconify.design/icon-sets/
                  sworrs @Guest
                  @sean
                  I have many calendars inserted there, but now I will try to find the calendar causing the problem. At least I found out, that the icons sometimes are shown.
                  Thanks for the hint. I will try around with the calendars and as soon as I now the right calendar I will mail you.
                  Do you know any other problems with multiple calendars? Not all calendars are shown everytime I start the magic mirror and by now I have no idea whats the matter here.
                    @sworrs
                    If you have many events and many calendars, adjust maxItems in configuration.
                      sworrs @Guest
                      @Sean
                      what does the maxItems mean? Does it load the next Items of the calendar? How many could be loaded, should the number be around the count of shown calendar items?
                        @sworrs
                        ‘maxItems’ means number of events to be read per calendar. Fot performance issue, it is berrer to be limited. Some calendar could have a tons of events and it could make memory drains.
