    MMM-CalendarExt2 not showing icons in calendar
    14 Posts 4 Posters 5.9k Views 4 Watching
      sworrs @Guest
      @sean
      I tried different icons and they all do not show up. And you are right, I get an error in dev mode:
      iconify.min.js:13 Uncaught TypeError: n.MutationObserver is not a constructor
          at iconify.min.js:13
          at Object.i.nextInitItem (iconify.min.js:13)
      (anonymous) @ iconify.min.js:13
      i.nextInitItem @ iconify.min.js:13
      setTimeout (async)
      What does this mean?
        A Former User @sworrs
        @sworrs
        Can I get your ics URL to examine? my email address is eouia0819@gmail.com
        I cannot represent your error on my cases So I need your ics URL.
        • O Offline
          othomys
          How does the module know where to find the icons?
            A Former User @othomys
            @othomys
            This module use iconify to show icons.
            You can find icons here : https://iconify.design/icon-sets/
              sworrs @Guest
              @sean
              I have many calendars inserted there, but now I will try to find the calendar causing the problem. At least I found out, that the icons sometimes are shown.
              Thanks for the hint. I will try around with the calendars and as soon as I now the right calendar I will mail you.
              Do you know any other problems with multiple calendars? Not all calendars are shown everytime I start the magic mirror and by now I have no idea whats the matter here.
                @sworrs
                If you have many events and many calendars, adjust maxItems in configuration.
                  sworrs @Guest
                  @Sean
                  what does the maxItems mean? Does it load the next Items of the calendar? How many could be loaded, should the number be around the count of shown calendar items?
                    @sworrs
                    ‘maxItems’ means number of events to be read per calendar. Fot performance issue, it is berrer to be limited. Some calendar could have a tons of events and it could make memory drains.
                      bolish
                      Hi,@Sean @sworrs
                      did you solve your icon issue?
                      Mine are not showing neither…Several calendars, all not showing the icons. Strange…
                      ? S 2 Replies Last reply Reply Quote 0
                        A Former User @bolish
                        @bolish
                        See the front-end log whether there is some error to prevent icon loading.
                        And test my module with other modules disabled.
                          sworrs @bolish
                          Hi @bolish,
                          I did not solve the icon completely, but I had no time trying anything, sorry.
                            bolish
                            @sworrs no problem.
                            I will try the debugging method proposed by @Sean this week and keep both of you posted.
