MMM-CalendarExt2 not showing icons in calendar
14 Posts 4 Posters 5.2k Views 4 Watching
  • O Offline
    othomys
    How does the module know where to find the icons?
    ? 1 Reply Last reply Jan 17, 2019, 12:21 PM Reply Quote 0
      A Former User @othomys
      @othomys
      This module use iconify to show icons.
      You can find icons here : https://iconify.design/icon-sets/
        sworrs @Guest
        @sean
        I have many calendars inserted there, but now I will try to find the calendar causing the problem. At least I found out, that the icons sometimes are shown.
        Thanks for the hint. I will try around with the calendars and as soon as I now the right calendar I will mail you.
        Do you know any other problems with multiple calendars? Not all calendars are shown everytime I start the magic mirror and by now I have no idea whats the matter here.
        ? 1 Reply Last reply Jan 20, 2019, 9:58 PM Reply Quote 0
          A Former User @sworrs
          @sworrs
          If you have many events and many calendars, adjust maxItems in configuration.
          S 1 Reply Last reply Jan 26, 2019, 9:15 PM Reply Quote 0
            sworrs @Guest
            @Sean
            what does the maxItems mean? Does it load the next Items of the calendar? How many could be loaded, should the number be around the count of shown calendar items?
            ? 1 Reply Last reply Jan 27, 2019, 10:15 AM Reply Quote 0
              @sworrs
              ‘maxItems’ means number of events to be read per calendar. Fot performance issue, it is berrer to be limited. Some calendar could have a tons of events and it could make memory drains.
                bolish
                Hi,@Sean @sworrs
                did you solve your icon issue?
                Mine are not showing neither…Several calendars, all not showing the icons. Strange…
                ? S 2 Replies Last reply Feb 24, 2019, 11:24 AM Reply Quote 0
                  A Former User @bolish
                  @bolish
                  See the front-end log whether there is some error to prevent icon loading.
                  And test my module with other modules disabled.
                    sworrs @bolish
                    Hi @bolish,
                    I did not solve the icon completely, but I had no time trying anything, sorry.
                      bolish
                      @sworrs no problem.
                      I will try the debugging method proposed by @Sean this week and keep both of you posted.
