MONITORON on does not work in schedule
6 Posts 2 Posters 1.6k Views 3 Watching
    rts58
    I’ve installed MMM-Remote-Control and MMM-ModuleScheduler. I basically want the MM to be off all night, it should then start up at 9:15, the monitor turn on at 9:30, then off at 11:30 and MM down at 11:45. The global_schedule works fine and the monitor shuts off correctly. However, the monitor does not come on in the morning. I can use the power on menu choice from the remote web page to turn the monitor on. It just won’t come on via the notification_schedule. Can someone suggest what is incorrect in my config.js entry?
    module: 'MMM-ModuleScheduler',
    	    // Show all modules at 9:15 every day and hide at 11:45
    	   global_schedule: {from: '15 9 * * *', to: '45 23 * * *'},
                notification_schedule: [
                    // TURN THE MONITOR/SCREEN ON AT 09:30 EVERY DAY
                    {notification: 'REMOTE_ACTION', schedule: '30 9 * * *', payload: {action: "MONITORON"}},
                    // TURN THE MONITOR/SCREEN OFF AT 11:30pm EVERY DAY
                    {notification: 'REMOTE_ACTION', schedule: '30 23 * * *', payload: {action: "MONITOROFF"}},
                    // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                    {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
    Thanks!
    D 2 Replies Last reply Jan 17, 2019, 6:15 PM Reply Quote 0
      dazza120 @rts58
      @rts58 ok Looking at the read me it’s these at the end from my basic understanding
        dazza120 @rts58
        @rts58 so whole code should be
                        {notification:
                        {notification:
                        {notification:
        R 1 Reply Last reply Jan 17, 2019, 6:59 PM Reply Quote 1
          rts58 @dazza120
          @dazza120 Thanks, I did not have the “,” after the last “}” because it is the last module in the config. I thought the extra “,” would cause a config error. But it does not. Hopeful for success in the morning!
            rts58
            It still did not come on this morning :frowning_face: . I just ran tail -130 ~/.pm2/logs/mm-out.log and found these results:
            MMM-ModuleScheduler is removing all scheduled jobs
            MMM-ModuleScheduler received CREATE_NOTIFICATION_SCHEDULE
            MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 9 * * *
            MMM-ModuleScheduler has scheduled REMOTE_ACTION
            MMM-ModuleScheduler will next send REMOTE_ACTION at Fri Jan 18 2019 09:30:00 GMT-0500 (EST)
            MMM-ModuleScheduler is scheduling REMOTE_ACTION using "30 23 * * *
            MMM-ModuleScheduler will next send REMOTE_ACTION at Thu Jan 17 2019 23:30:00 GMT-0500 (EST)
            MMM-ModuleScheduler is scheduling REMOTE_ACTION using "0 2 * * SUN
            MMM-ModuleScheduler will next send REMOTE_ACTION at Sun Jan 20 2019 02:00:00 GMT-0500 (EST)
            MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
            MMM-ModuleScheduler is creating a global schedule for all modules using "15 9 * * *" and "45 23 * * *" with dim level undefined
            MMM-ModuleScheduler has created the global schedule for all modules
            MMM-ModuleScheduler will next show all modules at Fri Jan 18 2019 09:15:00 GMT-0500 (EST)
            MMM-ModuleScheduler will next hide all modules at Thu Jan 17 2019 23:45:00 GMT-0500 (EST)
            Again later in the output I found:
            MMM-ModuleScheduler is sending SEND_NOTIFICATION to REMOTE_ACTION
            MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Fri Jan 18 2019 23:30:00 GMT-0500 (EST) based on "30 23 * * *"
            Powering off HDMI
            MMM-ModuleScheduler is sending HIDE_MODULES to undefined
            MMM-ModuleScheduler will next send HIDE_MODULES to undefined at Fri Jan 18 2019 23:45:00 GMT-0500 (EST) based on "45 23 * * *"
            MMM-ModuleScheduler is sending SHOW_MODULES to undefined
            MMM-ModuleScheduler will next send SHOW_MODULES to undefined at Sat Jan 19 2019 09:15:00 GMT-0500 (EST) based on "15 9 * * *"
            MMM-ModuleScheduler will next send SEND_NOTIFICATION to REMOTE_ACTION at Sat Jan 19 2019 09:30:00 GMT-0500 (EST) based on "30 9 * * *"
            Powering on HDMI with preferred settings
            So it looks like the schedule works and it is trying to turn the monitor on, it just didn’t work. (Thanks @dazza120 I don’t think the schedule was working before.) This morning when the monitor didn’t come on per the schedule, I used the remote web page, it came on fine. How can I find out why the monitor did not come on with the schedule??
              rts58
              Re: MONITORON on does not work in schedule
              So for the last two days, this has been working correctly. I think it may be a combination of @dazza120 fix to my config, not messing with the pi for a full 2 days to let it fully run through it’s schedule, and removing openGL.
