MMM-GroveGestures
51 Posts 8 Posters 19.4k Views 12 Watching
    A Former User
    MMM-GroveGestures
    MagicMirror Module - detecting 3D gesture with GroveGesture Sensor(PAJ7620u2)
    Video Clip
    2.1.0 demo
    Hardware
    • Grove Gesture Sensor (PAJ7620u2)
      • The sensor on Grove - Gesture is PAJ7620U2 that integrates gesture recognition function with general I2C interface into a single chip. It can recognize 9 basic gestures, and these gestures information can be simply accessed via the I2C bus.
      • price: $10~20USD
      • gestures : Up / Down / Left / Right / Forward / Backward / Clockwise / Count Clockwise / Wave
      • detection range : 5 ~ 10cm / non-touch
      • size : 20mm X 20mm
    Unfortunately, due to it’s short range and theory of electro-magnetic field, this sensor will not be used beneath Spymirror. But under the thin wooden, plastic or normal glass, it will work.
    It works as 3D gesture sensor similar with Skywriter or Flick!, but definitely small, flat, and non-HAT. It could fit for bezel-frame of MagicMirror. Soldering is not needed.
    Comparison
    • vs. PIR sensor, ultrasonic sensor, CAM motion detection
      • PROS: more gestures
      • CONS: short range
    • vs. Skywriter, Flick!
      • PROS: small
      • CONS: touch, tap gestures are not supported
    • vs. CAM gesture recognition
      • PROS: light, easy, low CPU
      • CONS: short range, not so COOL
    REQUIREMENT
    • 1 x Grove Gesture Sensor (or PAJ7620u2 compatible)
    • 1 x 4pin Female jumper cable
    Pin Connect (I2C 1)
    • 5V (GPIO PIN 4) : VCC
    • GND (GPIO PIN 6) : GND
    • SDA (GPIO PIN 3) : SDA
    • SCL (GPIO PIN 5) : SCL
    Install & Details
    [card:eouia/MMM-GroveGestures]
      bolish
      Hi @Sean ,
      I was wondering if the module would be able to handle 2 identical PAJ7620u2 sensors?
      Not talking about combining both (maybe an idea for later), but just giving the user the possibility to have 2 times more interactions with modules by putting one sensor on right side of the Mirror and the other on left side for example.
      I’m currently building my mm project and I’ve to be honest, I would love that!!
      Regards
      ? 1 Reply Last reply Jan 22, 2019, 10:31 AM Reply Quote -1
        A Former User @bolish
        @bolish
        I answered on github.
        Currently it couldn’t. Sorry. I’ve never imagined that situation.
          bolish
          Thanks for the answer and the additional “sequence” tip. Let’s follow up on GitHub post if needed.
            Benjaminh86
            Hello World,
            I love your module!
            I use MMM-page-selector to switch between 2 pages. I wanted to use grove gesture to change pages, but I can not adapt the script.
            I can see my gestures in the Magic Mirror when I pass my hand in front of the grove gesture; after, i do not know what to put in config.js
            Can you help me?
            For information, my english is bad, and I do not know anything about programming!
            Thank you
            BenH
            ? 1 Reply Last reply Mar 23, 2019, 3:52 PM Reply Quote 0
              A Former User @Benjaminh86
              @Benjaminh86
              Let’s assume You have page 1 and 2.
              You can assign gesture LEFT to 1, RIGHT to 2.
              At that case, you can add this to your command set(default or any other you want).
              "LEFT": {
                notificationExec: {
                  notification: "PAGE_SELECT",
                  payload: "1",
              "RIGHT": {
                notificationExec: {
                  payload: "2",
              The problem is, MMM-page-selector has no feature of “NEXT PAGE” or “PREVIOUS PAGE”. so when there be more than 2 pages, you should assign gestures per each page.
              B 1 Reply Last reply Mar 23, 2019, 5:58 PM Reply Quote 0
                Benjaminh86 @Guest
                @Sean as I said, I’m a beginner, and I do not understand everything in programming.
                In addition, I have a synthaxe error on the line “exec: (module, gestures) => {”
                it indicates a problem with the symbol =>.
                Can you help me?
                ? 2 Replies Last reply Mar 23, 2019, 6:11 PM Reply Quote 0
                  @Benjaminh86
                  Show me your configuration.
                  B 1 Reply Last reply Mar 23, 2019, 6:16 PM Reply Quote 0
                    Benjaminh86 @Guest
                    @Sean
                    here is my configuration for your module :
                    module: “MMM-GroveGestures”,
                    position: “top_right”,
                    pages: {‘all’: ‘top_right’},
                    autoStart: true, //When Mirror starts, recognition will start.
                    verbose:false, // If set as true, useful messages will be logged.
                    recognitionTimeout: 1000, //Gesture sequence will be ended after this time from last recognized gesture.
                    cancelGesture: “WAVE”, //If set, You can cancel gesture sequence with this gesture.
                    visible: true, //Recognized gesture sequence will be displayed on position
                    idleTimer: 1000*60*30, // `0` for disable, After this time from last gesture, onIdle will be executed.
                    onIdle: { // See command section
                      moduleExec: {
                        module: [],
                          module.hide(1000, null, {lockstring:"GESTURE"})
                    onDetected: {
                      notificationExec: {
                        notification: "GESTURE_DETECTED",
                      /* You can make Mirror to wake up the modules which were hidden by onIdle with any gestures.
                      moduleExec: {
                        module: [],
                        exec: (module) => {
                          module.show(1000, null, {lockstring:"GESTURE"})
                    gestureMapFromTo: { //When your sensor is installed with rotated direction, you can calibrate with this.
                      "Up": "UP",
                      "Down": "DOWN",
                      "Left": "LEFT",
                      "Right": "RIGHT",
                      "Forward": "FORWARD",
                      "Backward": "BACKWARD",
                      "Clockwise": "CLOCKWISE",
                      "anti-clockwise": "ANTICLOCKWISE",
                      "wave": "WAVE"
                    commandSet: {
                         "LEFT": {
                    	notificationExec: {
                    		payload: "main",
                          "RIGHT": {
                    	notificationExec: {
                    		payload: "2",
                    ? 1 Reply Last reply Mar 23, 2019, 6:21 PM Reply Quote 0
                      @Benjaminh86
                      Your configuration about commandSet has something wrong.
                      commandSet: {
                        "default" : {
                          "LEFT": {
                            notificationExec: {
                              payload: "main",
                          "RIGHT": {
                            notificationExec: {
                              payload: "2",
                      • 1 / 6
