MMM-MyCalendar - Problem with ICON, not changing
Re: MMM-MyCalendar
Hi, I trying to figure how to change the icon of the calendar with the correct fontawesome name. But I think that the Variable “symbol” is not working. I try to change calendar by calendar, change the “defaultSymbol” but alway push the Calendar symbol and not other. How can I change the icon for each calendar?
Regards,
DP
@piedaniel your layout looks great, a couple of questions for you, how did you change the color of the headings, and is that a world clock modules?
ok, to change the color for the head an the line i used the following entries in my custom.css-File an it works.
header { color: #87cefa; border-bottom-color: #87cefa; } -
@bjoern tried it and it didn’t work for me… that’s weird. I used the exact code you have…
@piedaniel , in Worldclock module,How to separate four clock two colume
because in module have only in horizontal or vertical
Thank your hint
