    [MMM-Rainbow] Animated text color transition
    34 Posts 8 Posters 24.2k Views 8 Watching
    • G
      ganget @Seann
      @seann I took a different approach to this, mainly because I only wanted to have it for only one module. I have changed my custom.css and one line in the clock.js, so it grabs a different style.
      My code makes a gradient background which I clip to the text. Then to make it move across the text i use webkit-animation. I’m not totally satisfied with the result of the animation yet but i will keep tweaking that.
      the animation moves way too fast now and when I make the animation duration longer it doesn’t feature all the colors of the gradient.
      the only line i needed to change in the clock.js file
      timeWrapper.className = "time clock-time-only-color large light";
      Custom.css (lines i added)
      .clock-time-only-color {
      	background-image: linear-gradient(to right, #ff0000,#ff4000,#ff8000,#ffbf00,#ffff00,#bfff00,#80ff00,#40ff00,#00ff00,#00ff40,#00ff80,#00ffbf,#00ffff,#00bfff,#0080ff,#0040ff,#0000ff,#4000ff,#8000ff,#bf00ff,#ff00ff,#ff00bf,#ff0080,#ff0040,#ff0000);
      	-webkit-background-clip:  text;
      	-webkit-animation: animate 3s linear infinite;
      	background-size: 500%;
      	color: transparent;
      @-webkit-keyframes animate{
      	0%	{background-position: 0% 500%;}
      	50%	{background-position: 100% 0%;}
      	100%    {background-position: 0% 100%;}
      Do you have any idea on how I can make the animation duration way longer like 10 min and still show all the colors in the gradient?
      Thank you for the initial idea and for inspiring me!
      S justjim1220J 2 Replies Last reply Reply Quote 0
        Seann Module Developer @ganget
        @ganget I’m not really that good with css animations but from what I can see,
        should have something to do with it right? maybe if you make that 10 minutes instead.
        • G
          ganget @Seann
          @seann yeah i tried increasing the number to like 20 sec up to 6000. But the problem i get then is that it shows me only the first 2 colors in the gradient. Dunno but will try and work on it tomorrow
          • justjim1220J
            justjim1220 Module Developer @ganget
            @ganget
            change your background size to 20% instead of 500%
            Only other issue I find is that it refreshes itself every second, would be better if it were more fluid-like that the refresh isn’t so notice-able.
            Jim Hallock - 1995
            • justjim1220J
              @ganget & @BKeyport
              So, I modified my MMM-DigClock with your rainbow css with some other tweaks…
              .MMM-DigClock .time {
                font-size: 300px;
                text-align: center;
                line-height: 85%;
                letter-spacing: 5px;
                font-weight: 900;
                font-family: DS-Digital;
                background: -webkit-linear-gradient(left, red,orange,yellow,green,blue,purple);
                background: -moz-linear-gradient(left, red,orange,yellow,green,blue,purple);
                background: -o-linear-gradient(left, red,orange,yellow,green,blue,purple);
                background: linear-gradient(to left, red,orange,yellow,green,blue,purple);
                -moz-background-clip: text;
                -webkit-animation: animate 10s linear infinite;
                -moz-animation: animate 10s linear infinite;
                -o-animation: animate 10s linear infinite;
                background-size: 25%;
                -webkit-text-fill-color: transparent;
              And it seems to work fairly decent.
              But I had to change the update interval within the clock code to update every minute instead of every second, by placing the following within the start: function() …
              // Schedule update interval.
              		var self = this;
              		setInterval(function() {
              			self.updateDom();
              		}, 60000);
              Jim Hallock - 1995
              • justjim1220J
                justjim1220 Module Developer @Seann
                @seann
                you can change the update interval within the clock code to update every minute instead of every second, by placing the following within the start: function() …
                    var self = this;
                	self.updateDom();
                    }, 60000);
                Jim Hallock - 1995
                G S 2 Replies Last reply Reply Quote 0
                • G
                  ganget @justjim1220
                  @justjim1220 Good tip man! I will change the update interval and look at the difference.
                  • G
                    ganget @ganget
                    @justjim1220 I changed the update interval to 60 sec and that makes it work allot better. I kept the background size at 500% so the color gradient won’t repeat.
                    	background-image: linear-gradient(to left, red,orange,yellow,green,blue,purple);
                    	-webkit-animation: animate 60s linear infinite;
                    	color: transparent;
                    	100%	{background-position: 500% 0%;}
                    The result
                    Thanks for your help!
                      Seann Module Developer @justjim1220
                      @justjim1220 Say if you start your mirror at 30 seconds past the minute, the clock on the mirror wont update until 30 seconds past the next minute, that’s why I created my own clock
                      • justjim1220J
                        @seann was you able to get past the every second update?
                        Jim Hallock - 1995
                        • justjim1220J
                          @ganget Does it show every color?
                          Jim Hallock - 1995
                            @justjim1220 Do you mean for the clock?
                            • G
                              ganget @justjim1220
                              @justjim1220. Yeah it shows every color atm before the minute updates and the loop starts again.
                                @ganget Have a look at the js Here
                                This is how I made my clock update every minute, on the minute. Could be done better i’m sure but this works.
                                • justjim1220J
                                  @seann Yes, and I really like how you coded your iClock to work that way!
                                  Jim Hallock - 1995
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @Seann
                                    @seann
                                    I don’t know if it matters to you but your Github readme for MMM-iClock starts like this:
                                    MMM-Showtimes - Local Cinema Showtimes for MagicMirror²
                                    cowboysdudeC S 2 Replies Last reply Reply Quote 0
                                    • cowboysdudeC
                                      cowboysdude Module Developer @ganget
                                      @ganget said in [MMM-Rainbow] Animated text color transition:
                                      I really like the idea of this module, I’m searching for the possibility to make only my clock have this effect and maybe a gradient kind of color shift. Can you help me with this idea?
                                      Gradients can be a done something like this… of course you’ll be using different selectors but this is the idea:
                                        background-image: linear-gradient(to right, #E0AC00, #E0D100, #CAE000, #A5E000, #7FE000,
                                        #5AE000);
                                           background-size: 24em 0.25em;
                                      I used that gradient in the bars on the right hand side of the picture…from yellow to green.
                                      • cowboysdudeC
                                        @mykle1 said in [MMM-Rainbow] Animated text color transition:
                                        @seann
                                        Hahhhaha come on @Seann :)
                                          Seann Module Developer @Mykle1
                                          @mykle1 LMFAO, as you can see I literally use the same thing as a template for my modules. Thanks for the heads up, i’ll change it now.
                                          • blake_northrupB
                                            blake_northrup
                                            Very cool mod man! Works well with all of my Hue lighting. Thanks!
