    One-line switch to enable / disable modules
    Scheduled Pinned Locked Moved Feature Requests
    14 Posts 7 Posters 9.6k Views 6 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor @Anhalter42
      @Anhalter42 That’s what I was looking for! Thanks a lot :)
        Sebi76
        disabled: “true”, it doesnt work
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Sebi76
          @sebi76 booleans do not have quotes. Try without
          • michael5rM Offline
            michael5r Module Developer
            I’ve done this in my config.js file:
            const DISABLED = {};
            if (RPI_DEV) { // I'm setting this value automatically based on the system
                DISABLED.weather = false;
                DISABLED.clock = false;
                DISABLED.calendar = false;
                DISABLED.tools = false;
                DISABLED.hue = true;
                DISABLED.newsfeed = true;
                DISABLED.nest_cameras = true;
                DISABLED.nest_status = true;
                DISABLED.telegram = true;
                DISABLED.hotword = true;
            } else {
                DISABLED.hue = false;
                DISABLED.newsfeed = false;
                DISABLED.nest_cameras = false;
                DISABLED.nest_status = false;
                DISABLED.telegram = false;
                DISABLED.hotword = false;
            And then for each module you can do something like this:
                module: 'clock',
                position: 'top_left',
                    displaySeconds: false,
                    displayType: 'digital',
                    dateFormat: 'dddd, MMM D, YYYY'
                disabled: DISABLED.clock
              Sebi76
              @michael5r said in One-line switch to enable / disable modules:
              Where do you placesd this in you config. Like this?
              			module: "alert",
              			classes:  'default everyone',
              			module: "updatenotification",
              			position: "top_bar",
              			module: "clock",
              michael5rM 1 Reply Last reply Reply Quote 0
                michael5r Module Developer @Sebi76
                @sebi76 No, it needs to be before that.
                Place it at the top of the file, before this line:
                var config = {
                  Sebi76
                  It’s works not :grimacing_face:
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	address: "0.0.0.0", // Address to listen on, can be:
                  	port: 8080,
                  	ipWhitelist: [], // Set [] to allow all IP addresses
                  	language: "de",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			module: "clock",
                  			//disabled: DISABLED.clock
                    @sebi76 Your syntax is wrong - you have this:
                    It should just be this:
                    It’s that last }, that’s breaking your code.
                      Sebi76
                        A Former User
                        @rudibarani @michael5r
                        Here is my version. No need to list all modules.
                        const pre_disabled = {
                          "UNLISTED": true, // default value for unlisted other modules.
                          "alert":false,
                          "clock": false,
                          "MMM-Remote-Control":false,
                        var DISABLED = new Proxy(pre_disabled, {
                          get (receiver, name) {
                            return name in receiver ? receiver[name] : receiver["UNLISTED"]
                        michael5rM 1 Reply Last reply Reply Quote 1
                          michael5r Module Developer @Guest
                          @sean said in One-line switch to enable / disable modules:
                            "alert":false,
                            "clock": false,
                          Lovely :thumbs_up_light_skin_tone:
                            jg3 @strawberry 3.141
