    One-line switch to enable / disable modules
    Scheduled Pinned Locked Moved Feature Requests
    14 Posts 7 Posters 9.1k Views 6 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor
      Currently, I comment out all modules that I want to keep configured but don’t want to use currently line by line.
      Is there an easier way to enable / disable modules in the config.js file?
      If not, I would suggest a MM2-wide working variable (analog to header) to enable / disable modules, e.g.
      module_active: true / false
      What do you think?
        Anhalter42 @rudibarani
        @rudibarani disabled does this, doesn’t it?
        disabled 	Set disabled to true to skip creating the module. This field is optional.
        rudibaraniR 1 Reply Last reply Reply Quote 1
          rudibarani Project Sponsor @Anhalter42
          @Anhalter42 That’s what I was looking for! Thanks a lot :)
            Sebi76
            disabled: “true”, it doesnt work
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @Sebi76
              @sebi76 booleans do not have quotes. Try without
              • michael5rM Offline
                michael5r Module Developer
                I’ve done this in my config.js file:
                const DISABLED = {};
                if (RPI_DEV) { // I'm setting this value automatically based on the system
                    DISABLED.weather = false;
                    DISABLED.clock = false;
                    DISABLED.calendar = false;
                    DISABLED.tools = false;
                    DISABLED.hue = true;
                    DISABLED.newsfeed = true;
                    DISABLED.nest_cameras = true;
                    DISABLED.nest_status = true;
                    DISABLED.telegram = true;
                    DISABLED.hotword = true;
                } else {
                    DISABLED.hue = false;
                    DISABLED.newsfeed = false;
                    DISABLED.nest_cameras = false;
                    DISABLED.nest_status = false;
                    DISABLED.telegram = false;
                    DISABLED.hotword = false;
                And then for each module you can do something like this:
                    module: 'clock',
                    position: 'top_left',
                        displaySeconds: false,
                        displayType: 'digital',
                        dateFormat: 'dddd, MMM D, YYYY'
                    disabled: DISABLED.clock
                  Sebi76
                  @michael5r said in One-line switch to enable / disable modules:
                  Where do you placesd this in you config. Like this?
                  			module: "alert",
                  			classes:  'default everyone',
                  			module: "updatenotification",
                  			position: "top_bar",
                  			module: "clock",
                  michael5rM 1 Reply Last reply Reply Quote 0
                    michael5r Module Developer @Sebi76
                    @sebi76 No, it needs to be before that.
                    Place it at the top of the file, before this line:
                    var config = {
                      Sebi76
                      It’s works not :grimacing_face:
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	address: "0.0.0.0", // Address to listen on, can be:
                      	port: 8080,
                      	ipWhitelist: [], // Set [] to allow all IP addresses
                      	language: "de",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			module: "clock",
                      			//disabled: DISABLED.clock
                        @sebi76 Your syntax is wrong - you have this:
                        It should just be this:
                        It’s that last }, that’s breaking your code.
                          Sebi76
                            A Former User
                            @rudibarani @michael5r
                            Here is my version. No need to list all modules.
                            const pre_disabled = {
                              "UNLISTED": true, // default value for unlisted other modules.
                              "alert":false,
                              "clock": false,
                              "MMM-Remote-Control":false,
                            var DISABLED = new Proxy(pre_disabled, {
                              get (receiver, name) {
                                return name in receiver ? receiver[name] : receiver["UNLISTED"]
                            michael5rM 1 Reply Last reply Reply Quote 1
                              michael5r Module Developer @Guest
                              @sean said in One-line switch to enable / disable modules:
                                "alert":false,
                                "clock": false,
                              Lovely :thumbs_up_light_skin_tone:
                                jg3 @strawberry 3.141
