MMM-IFTTT - If-This-Then-That Maker Notifications
11 Posts 3 Posters 15.3k Views 3 Watching
    jc21
    Description
    This is my first module so don’t expect too much :p
    This enables realtime notifications from IFTTT to your MagicMirror install, via a JSON POST endpoint of the mirror. Full instructions in the project:
    Technically, this module could be used for any webhook service such as Zapier too.
    Download
    [card:jc21/MMM-IFTTT]
    P 1 Reply Last reply Oct 4, 2016, 3:37 PM Reply Quote 1
      paulocarrasco @jc21
      @jc21 Hi, I a fan of IFTTT and I trying to include your module on my project.
      The process isn’t working very well :-), and I decided to seek some help here.
      The problem, after installing the module like you prescribed, is that I can’t connect to the Pi (with MM) on port 8080.
      I tried, for testing purposes, the following commands on the terminal of the Pi itself:
      curl -X POST -H "Content-Type: application/json" -d '{"message": "Your pizza is ready!"}' "http://192.168.1.103:8080/IFTTT"
      or
      curl -X POST -H "Content-Type: application/json" -d '{"message": "Your pizza is ready!"}' "http://127.0.0.1:8080/IFTTT"
      with the same result:
      curl: (7) Failed to connect to 192.168.1.103 port 8080: Connection refused
      Trying from another ip (local or external) gives the same error.
      Am I forgetting something?
        jc21
        When you are running MagicMirror do you see these lines in the console output?
        All module helpers loaded.
        Starting server op port 8080 ...
        Server started ...
        P 1 Reply Last reply Oct 5, 2016, 8:25 AM Reply Quote 0
          paulocarrasco @jc21
          @jc21 I made an update to the Git modules, and now I getting those lines on my console. Everything is working 100%, thanks :-).
            jc21
            Update: Added support for my new MMM-Sounds module. Notification integration instructions are in the updated MMM-IFTTT readme.
              Great idea but am clueless on how IFTTT works… your example looks like a facebook notification which is pretty cool… but as far as getting that to work… LOL
                paulocarrasco
                Hi, since last update of MMM-IFTTT I am getting this error, when I make a notification to the MM:
                TypeError: Cannot read property &#39;debug&#39; of undefined<br> &nbsp; &nbsp;at Class.log (/home/pi/MagicMirror/modules/MMM-IFTTT/node_helper.js:116:54)<br> &nbsp; &nbsp;at expressApp.post (/home/pi/MagicMirror/modules/MMM-IFTTT/node_helper.js:57:18)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/route.js:131:13)<br> &nbsp; &nbsp;at Route.dispatch (/home/pi/MagicMirror/node_modules/express/lib/router/route.js:112:3)<br> &nbsp; &nbsp;at Layer.handle [as handle_request] (/home/pi/MagicMirror/node_modules/express/lib/router/layer.js:95:5)<br> &nbsp; &nbsp;at /home/pi/MagicMirror/node_modules/express/lib/router/index.js:277:22<br> &nbsp; &nbsp;at Function.process_params (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:330:12)<br> &nbsp; &nbsp;at next (/home/pi/MagicMirror/node_modules/express/lib/router/index.js:271:10)<br> &nbsp; &nbsp;at urlencodedParser (/home/pi/MagicMirror/modules/MMM-IFTTT/node_modules/body-parser/lib/types/urlencoded.js:82:7)
                I already installed everything from the beginning twice, and updated all but without luck. Any ideias?
                J 1 Reply Last reply Oct 9, 2016, 1:20 AM Reply Quote 0
                  jc21 @paulocarrasco
                  @paulocarrasco That was my bad. The module has been fixed now, do a git pull inside the module dir.
                  P 1 Reply Last reply Oct 9, 2016, 6:00 PM Reply Quote 0
                    paulocarrasco @jc21
                    @jc21 Thanks for your quick reply. As you mentioned I made a ‘pull’ of MMM-IFTTT new version. Unfortunately It still giving the same error for me. All te rest appears that is working. Also the server is listening fine on port 8080.
                    For testing purposes I have this minimalistic config.js
                    //* Magic Mirror Config Sample
                    • MIT Licensed.
                    var config = {
                    port: 8080,
                    language: 'en',
                    timeFormat: 24,
                    units: 'metric',
                    		module: 'alert',
                    		module: 'clock',
                    		position: 'top_left'
                      module: 'MMM-PIR-Sensor',
                    	        		sensorGpio: 4,// See 'Configuration options' for more information.
                    	  module: 'MMM-IFTTT',
                    	  position: 'lower_third',
                    if (typeof module !== ‘undefined’) {module.exports = config;}
                    This is the command I enter, followed by the error:
                    MBP:~ paulocarrasco$ curl -X POST -H “Content-Type: application/json” -d ‘{“message”: “Your pizza is ready!”}’ “http://192.168.1.69:8080/IFTTT”
                    TypeError: Cannot read property 'debug' of undefined
                    I hope this helps finding the error, because as I am a IFTTT fan your IFTTT module has main importance for me ;-).
                    J 1 Reply Last reply Oct 9, 2016, 11:46 PM Reply Quote 1
                      jc21 @paulocarrasco
                      @paulocarrasco Pull again now.
                      Made the noob mistake of not testing, I wasn’t near my mirror at the time. All good now.
                      P 1 Reply Last reply Oct 10, 2016, 4:40 PM Reply Quote 1
