    MMM-Hotword
    60 Posts 20 Posters 29.4k Views 17 Watching
      A Former User @s.monti.74
      @s-monti-74
      I need an error log to examine. I doubt you missed electron-rebuild step on installation.
        s.monti.74 @Guest
        @sean please telle me which log I have to activate and how, thanks
          s.monti.74
          OH, I missed electron-rebuild . thanks
          I try…
            cjdzombie
            I’m trying to install Hotword to work with the Assistant Module. I’m stuck at the install because I keep getting an error with Snowboy. What is the issue here. I’m new to this type of codind and would appreciate some help. Here are the errors.
            pi@raspberrypi:~ $ cd ~/MagicMirror/modules/
            pi@raspberrypi:~/MagicMirror/modules $ sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
            Reading package lists... Done
            Building dependency tree
            libatlas-base-dev is already the newest version (3.10.3-1+rpi1).
            libmagic-dev is already the newest version (1:5.30-1+deb9u2).
            libsox-fmt-all is already the newest version (14.4.1-5).
            sox is already the newest version (14.4.1-5).
              erlang-base erlang-crypto erlang-syntax-tools fonts-lato
              libboost-thread1.62.0 libc-ares2 libhttp-parser2.8 libqt5opengl5
              libqt5scintilla2-12v5 libqt5scintilla2-l10n libqwt-qt5-6 libruby2.3
              libscsynth1 libsctp1 libuv1 libyaml-0-2 nodejs-doc rake realpath ruby
              ruby-did-you-mean ruby-minitest ruby-net-telnet ruby-power-assert
              ruby-test-unit ruby2.3 rubygems-integration
            Use 'sudo apt autoremove' to remove them.
            0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
            pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/eouia/MMM-Hotword.git
            Cloning into 'MMM-Hotword'...
            remote: Enumerating objects: 3, done.
            remote: Counting objects: 100% (3/3), done.
            remote: Compressing objects: 100% (3/3), done.
            remote: Total 116 (delta 0), reused 0 (delta 0), pack-reused 113
            Receiving objects: 100% (116/116), 7.93 MiB | 4.19 MiB/s, done.
            Resolving deltas: 100% (64/64), done.
            pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Hotword
            pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
            npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
            npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
            npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
            > snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
            > node-pre-gyp install --fallback-to-build
            node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
            node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@11.8.0 (node-v67 ABI, glibc) (falling back to source compile with node-gyp)
            node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
            internal/modules/cjs/loader.js:613
                throw err;
            Error: Cannot find module 'nan'
                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:611:15)
                at Function.Module._load (internal/modules/cjs/loader.js:537:25)
                at Module.require (internal/modules/cjs/loader.js:665:17)
                at require (internal/modules/cjs/helpers.js:20:18)
                at [eval]:1:1
                at Script.runInThisContext (vm.js:123:20)
                at Object.runInThisContext (vm.js:312:38)
                at Object.<anonymous> ([eval]-wrapper:6:22)
                at Module._compile (internal/modules/cjs/loader.js:736:30)
                at evalScript (internal/process/execution.js:56:25)
                throw err;
                at [eval]:1:1
            gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
            gypgyp  ERR!ERR!  configure error
            configure error
            gypgyp  ERR!ERR! stack  Error: `gyp` failed with exit code: 1
            stackgyp Error: `gyp` failed with exit code: 1
             ERR!gyp  stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
            ERR!gyp  stackERR!      at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
            stack     at ChildProcess.emit (events.js:197:13)
            gypgyp  ERR!ERR!  stackstack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
            gyp ERR! stackgyp      at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
            ERR! System Linux 4.14.79-v7+
            gypgyp  ERR! ERR!command  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
            gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
            gypgyp ERR!  node -vERR! v11.8.0
             commandgyp  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
            ERR! node-gyp -v v3.8.0
            gyp gyp ERR!ERR!  not okcwd
            gyp ERR! node -v v11.8.0
            gyp ERR! node-gyp -v v3.8.0
            gyp ERR! not ok
            node-pre-gyp ERR! build error
            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm' (1)
            node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:978:16)
            node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:265:5)
            node-pre-gyp ERR! System Linux 4.14.79-v7+
            node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
            node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
            node-pre-gyp ERR! node -v v11.8.0
            node-pre-gyp ERR! node-pre-gyp -v v0.6.39
            node-pre-gyp ERR! not ok
            npm WARN MMM-Hotword@1.1.0 No repository field.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the snowboy@1.3.1 install script.
            npm ERR!     /home/pi/.npm/_logs/2019-01-29T21_16_15_265Z-debug.log
              A Former User @cjdzombie
              @cjdzombie
              ‘npm install nan’ then do ‘npm install’ again
                cjdzombie @Guest
                @sean said in MMM-Hotword:
                npm install
                Thanks for your reply. I ran the suggested commands.
                pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install nan
                and then
                Unfortunately I got the same result. It seems that Snowboy is the issue. It just wont install in the process. When I try the next command in the process I get this result.
                cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                I get the reply
                pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                bash: cd: /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: No such file or directory
                I’ve been at this since last weekend. It’s fun , but frustrating. Any other help would be awesome.
                Thanks!
                ? S 3 Replies Last reply Reply Quote 0
                  @cjdzombie
                  and then
                  Same result? Your prior issue Error: Cannot find module 'nan' should be solved by npm install nan. If not so, that is an issue of another level. It means your npm is not valid. So check again same result.
                    @cjdzombie
                    You can contact me with mail : eouia0819@gmail.com or Telegram: @eouia for the details.
                      costascontis
                      @Sean i nicely use assistantmk2 with Hotword and i noticed that if i trigger assistant with hotword and for some reason get “conversation error” then hotword stops triggering but assistant works fine if i press the icon with the mouse.I have to restart MM to get hotword working again.Its not happening all the time but 1 maybe 2 times in the day.Any advice?
                        A Former User @costascontis
                        @costascontis
                        I need error logs and configurations for details.
                        • 3 / 6
