    MMM-Hotword
    60 Posts 20 Posters 35.2k Views 17 Watching
      A Former User @Cr4z33
      @cr4z33
      See hotwords:okgoogle.
      okgoogle is a symbol for your voice. If MMM-Hotword detect your okgoogle.pmdl(is file name right?), It will return okgoogle as detection.
      Then, if you want ot use that symbol as AssistantMk2 profile name to activate, modify configuration of MMM-AssistantMk2 like this.
      defaultProfile: "okgoogle",
      profiles: {
         "okgoogle" : {
              profileFile: "default.json",
              lang: "en-US",
      So, received “okgoogle” symbol will be used as profile name “okgoogle” with profile File “default.json”.
      • Cr4z33C
        Cr4z33 @Guest
        @sean
        A-ha that’s the file name then?
        That was my mistake because I named them ok_google.pmdl and ehi_google.pmdl!
        Thanks.
        • Cr4z33C
          Cr4z33
            Manfred
            Can’t figure out why hotword detection stops on the 2nd run.
            First detection is ok and GA responds as expected. I am a bit lost - any help is much appreciated
            MagicMirror: 2.5.0
            NodeJS: 9.11.2
            npm: 6.4.1
            MMM-AssistantMk2: 2.1.0
            I am using the full detailled config from MMM-AssistantMk2
              A Former User @Manfred
              @manfred
              You might missed this in your MMM-AssistantMk2 configuration
              notifications: {
              ASSISTANT_ACTIVATED: “HOTWORD_PAUSE”,
              ASSISTANT_DEACTIVATED: “HOTWORD_RESUME”,
              Or MMM-Hotword is not updated yet.
                Manfred @Guest
                @sean Thank you very much!! That did the trick!
                  s.monti.74
                  Hi , I can’t really use this module. I Have also done a minimal config.js with only this module but the mirror starts black (totally) and I have to reboot the RaspPi (I can’t close the Mirror)
                  What can I check ?
                  I have done correctly the installation of the module
                  Please help me
                  thanks from Italy
                    A Former User @s.monti.74
                    @s-monti-74
                    I need an error log to examine. I doubt you missed electron-rebuild step on installation.
                      s.monti.74 @Guest
                      @sean please telle me which log I have to activate and how, thanks
                        s.monti.74
                        OH, I missed electron-rebuild . thanks
                        I try…
                          cjdzombie
                          I’m trying to install Hotword to work with the Assistant Module. I’m stuck at the install because I keep getting an error with Snowboy. What is the issue here. I’m new to this type of codind and would appreciate some help. Here are the errors.
                          pi@raspberrypi:~ $ cd ~/MagicMirror/modules/
                          pi@raspberrypi:~/MagicMirror/modules $ sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
                          Reading package lists... Done
                          Building dependency tree
                          libatlas-base-dev is already the newest version (3.10.3-1+rpi1).
                          libmagic-dev is already the newest version (1:5.30-1+deb9u2).
                          libsox-fmt-all is already the newest version (14.4.1-5).
                          sox is already the newest version (14.4.1-5).
                            erlang-base erlang-crypto erlang-syntax-tools fonts-lato
                            libboost-thread1.62.0 libc-ares2 libhttp-parser2.8 libqt5opengl5
                            libqt5scintilla2-12v5 libqt5scintilla2-l10n libqwt-qt5-6 libruby2.3
                            libscsynth1 libsctp1 libuv1 libyaml-0-2 nodejs-doc rake realpath ruby
                            ruby-did-you-mean ruby-minitest ruby-net-telnet ruby-power-assert
                            ruby-test-unit ruby2.3 rubygems-integration
                          Use 'sudo apt autoremove' to remove them.
                          0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/eouia/MMM-Hotword.git
                          Cloning into 'MMM-Hotword'...
                          remote: Enumerating objects: 3, done.
                          remote: Counting objects: 100% (3/3), done.
                          remote: Compressing objects: 100% (3/3), done.
                          remote: Total 116 (delta 0), reused 0 (delta 0), pack-reused 113
                          Receiving objects: 100% (116/116), 7.93 MiB | 4.19 MiB/s, done.
                          Resolving deltas: 100% (64/64), done.
                          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Hotword
                          pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
                          npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                          npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                          npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                          > snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                          > node-pre-gyp install --fallback-to-build
                          node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
                          node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@11.8.0 (node-v67 ABI, glibc) (falling back to source compile with node-gyp)
                          node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
                          internal/modules/cjs/loader.js:613
                              throw err;
                          Error: Cannot find module 'nan'
                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:611:15)
                              at Function.Module._load (internal/modules/cjs/loader.js:537:25)
                              at Module.require (internal/modules/cjs/loader.js:665:17)
                              at require (internal/modules/cjs/helpers.js:20:18)
                              at [eval]:1:1
                              at Script.runInThisContext (vm.js:123:20)
                              at Object.runInThisContext (vm.js:312:38)
                              at Object.<anonymous> ([eval]-wrapper:6:22)
                              at Module._compile (internal/modules/cjs/loader.js:736:30)
                              at evalScript (internal/process/execution.js:56:25)
                              throw err;
                              at [eval]:1:1
                          gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                          gypgyp  ERR!ERR!  configure error
                          configure error
                          gypgyp  ERR!ERR! stack  Error: `gyp` failed with exit code: 1
                          stackgyp Error: `gyp` failed with exit code: 1
                           ERR!gyp  stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
                          ERR!gyp  stackERR!      at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
                          stack     at ChildProcess.emit (events.js:197:13)
                          gypgyp  ERR!ERR!  stackstack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                          gyp ERR! stackgyp      at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                          ERR! System Linux 4.14.79-v7+
                          gypgyp  ERR! ERR!command  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
                          gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                          gypgyp ERR!  node -vERR! v11.8.0
                           commandgyp  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
                          ERR! node-gyp -v v3.8.0
                          gyp gyp ERR!ERR!  not okcwd
                          gyp ERR! node -v v11.8.0
                          gyp ERR! node-gyp -v v3.8.0
                          gyp ERR! not ok
                          node-pre-gyp ERR! build error
                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm' (1)
                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
                          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:978:16)
                          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:265:5)
                          node-pre-gyp ERR! System Linux 4.14.79-v7+
                          node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                          node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                          node-pre-gyp ERR! node -v v11.8.0
                          node-pre-gyp ERR! node-pre-gyp -v v0.6.39
                          node-pre-gyp ERR! not ok
                          npm WARN MMM-Hotword@1.1.0 No repository field.
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the snowboy@1.3.1 install script.
                          npm ERR!     /home/pi/.npm/_logs/2019-01-29T21_16_15_265Z-debug.log
                            A Former User @cjdzombie
                            @cjdzombie
                            ‘npm install nan’ then do ‘npm install’ again
                              cjdzombie @Guest
                              @sean said in MMM-Hotword:
                              npm install
                              Thanks for your reply. I ran the suggested commands.
                              pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install nan
                              and then
                              Unfortunately I got the same result. It seems that Snowboy is the issue. It just wont install in the process. When I try the next command in the process I get this result.
                              cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                              I get the reply
                              pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                              bash: cd: /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: No such file or directory
                              I’ve been at this since last weekend. It’s fun , but frustrating. Any other help would be awesome.
                              Thanks!
                              ? S 3 Replies Last reply Reply Quote 0
                                @cjdzombie
                                and then
                                Same result? Your prior issue Error: Cannot find module 'nan' should be solved by npm install nan. If not so, that is an issue of another level. It means your npm is not valid. So check again same result.
                                  @cjdzombie
                                  You can contact me with mail : eouia0819@gmail.com or Telegram: @eouia for the details.
                                    costascontis
                                    @Sean i nicely use assistantmk2 with Hotword and i noticed that if i trigger assistant with hotword and for some reason get “conversation error” then hotword stops triggering but assistant works fine if i press the icon with the mouse.I have to restart MM to get hotword working again.Its not happening all the time but 1 maybe 2 times in the day.Any advice?
                                      A Former User @costascontis
                                      @costascontis
                                      I need error logs and configurations for details.
                                        sdetweil @cjdzombie
                                        @cjdzombie i just installed MMM-Hotword, and had the errors documented in the install.
                                        I followed the steps exactly, cutting and pasting, and those issues were resolved… MMM-Hotword works perfectly now
                                        • A
                                          Artech
                                          @Sean at first thank you for your module however I have some difficulties in installing the snowboy library if you or someone else has a procedure I will follow it
                                            berne
                                            mmm i notis i have a update, how do i get it?
                                            • 2 / 3
