    MMM-Hotword
    60 Posts 20 Posters 35.2k Views 17 Watching
    • T
      themc
      awesome ill try it out right away
        A Former User @themc
        @themc
        Not tested. I wrote that post by your description. So I don’t know whether it works really.
        But you can find a way how to work.
        • Cr4z33C
          Cr4z33
          Does anybody know what to edit to use custom hotwords (yes I created them in the Snowboy dashboard)?
            A Former User @Cr4z33
            @cr4z33
            Go to snowboy and signup (https://snowboy.kitt.ai).
            It’s better to do in your target device (Raspberry Pi)
            After login, you can see create Hotword button. click then follow instruction.
            After that, you can get your personal model (.pmdl)
            put that file into MMM-Hotword/resources then modify configuration.
            By example, you recorded and get abracadabra.pmdl,
            your configuration will be
             snowboy: [
                hotwords: "abracadabra",
                file: "resources/models/abracadabra.pmdl",
                sensitivity: '0.5',
            Then you can catch abracadabra by your voice.
            Cr4z33C 1 Reply Last reply Reply Quote 1
            • Cr4z33C
              Cr4z33 @Guest
              @sean
              Hmm that’s exactly what I did so either I am setting the wrong hotwords: word or there’s something more needed to edit?
              In my case I have recorded the hotwords ‘OK Google’ and ‘Ehi Google’ and apart from the proper file name and path I set hotwords: "okgoogle", and hotwords: "ehigoogle",.
              Also… can I use spaces into the quotes?
                @cr4z33
                See hotwords:okgoogle.
                okgoogle is a symbol for your voice. If MMM-Hotword detect your okgoogle.pmdl(is file name right?), It will return okgoogle as detection.
                Then, if you want ot use that symbol as AssistantMk2 profile name to activate, modify configuration of MMM-AssistantMk2 like this.
                defaultProfile: "okgoogle",
                profiles: {
                   "okgoogle" : {
                        profileFile: "default.json",
                        lang: "en-US",
                So, received “okgoogle” symbol will be used as profile name “okgoogle” with profile File “default.json”.
                • Cr4z33C
                  Cr4z33 @Guest
                  @sean
                  A-ha that’s the file name then?
                  That was my mistake because I named them ok_google.pmdl and ehi_google.pmdl!
                  Thanks.
                  • Cr4z33C
                    Cr4z33
                      Manfred
                      Can’t figure out why hotword detection stops on the 2nd run.
                      First detection is ok and GA responds as expected. I am a bit lost - any help is much appreciated
                      MagicMirror: 2.5.0
                      NodeJS: 9.11.2
                      npm: 6.4.1
                      MMM-AssistantMk2: 2.1.0
                      I am using the full detailled config from MMM-AssistantMk2
                        A Former User @Manfred
                        @manfred
                        You might missed this in your MMM-AssistantMk2 configuration
                        notifications: {
                        ASSISTANT_ACTIVATED: “HOTWORD_PAUSE”,
                        ASSISTANT_DEACTIVATED: “HOTWORD_RESUME”,
                        Or MMM-Hotword is not updated yet.
                          Manfred @Guest
                          @sean Thank you very much!! That did the trick!
                            s.monti.74
                            Hi , I can’t really use this module. I Have also done a minimal config.js with only this module but the mirror starts black (totally) and I have to reboot the RaspPi (I can’t close the Mirror)
                            What can I check ?
                            I have done correctly the installation of the module
                            Please help me
                            thanks from Italy
                              A Former User @s.monti.74
                              @s-monti-74
                              I need an error log to examine. I doubt you missed electron-rebuild step on installation.
                                s.monti.74 @Guest
                                @sean please telle me which log I have to activate and how, thanks
                                  s.monti.74
                                  OH, I missed electron-rebuild . thanks
                                  I try…
                                    cjdzombie
                                    I’m trying to install Hotword to work with the Assistant Module. I’m stuck at the install because I keep getting an error with Snowboy. What is the issue here. I’m new to this type of codind and would appreciate some help. Here are the errors.
                                    pi@raspberrypi:~ $ cd ~/MagicMirror/modules/
                                    pi@raspberrypi:~/MagicMirror/modules $ sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
                                    Reading package lists... Done
                                    Building dependency tree
                                    libatlas-base-dev is already the newest version (3.10.3-1+rpi1).
                                    libmagic-dev is already the newest version (1:5.30-1+deb9u2).
                                    libsox-fmt-all is already the newest version (14.4.1-5).
                                    sox is already the newest version (14.4.1-5).
                                      erlang-base erlang-crypto erlang-syntax-tools fonts-lato
                                      libboost-thread1.62.0 libc-ares2 libhttp-parser2.8 libqt5opengl5
                                      libqt5scintilla2-12v5 libqt5scintilla2-l10n libqwt-qt5-6 libruby2.3
                                      libscsynth1 libsctp1 libuv1 libyaml-0-2 nodejs-doc rake realpath ruby
                                      ruby-did-you-mean ruby-minitest ruby-net-telnet ruby-power-assert
                                      ruby-test-unit ruby2.3 rubygems-integration
                                    Use 'sudo apt autoremove' to remove them.
                                    0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                                    pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/eouia/MMM-Hotword.git
                                    Cloning into 'MMM-Hotword'...
                                    remote: Enumerating objects: 3, done.
                                    remote: Counting objects: 100% (3/3), done.
                                    remote: Compressing objects: 100% (3/3), done.
                                    remote: Total 116 (delta 0), reused 0 (delta 0), pack-reused 113
                                    Receiving objects: 100% (116/116), 7.93 MiB | 4.19 MiB/s, done.
                                    Resolving deltas: 100% (64/64), done.
                                    pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Hotword
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
                                    npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                                    npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                                    npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                                    > snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                                    > node-pre-gyp install --fallback-to-build
                                    node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
                                    node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@11.8.0 (node-v67 ABI, glibc) (falling back to source compile with node-gyp)
                                    node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
                                    internal/modules/cjs/loader.js:613
                                        throw err;
                                    Error: Cannot find module 'nan'
                                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:611:15)
                                        at Function.Module._load (internal/modules/cjs/loader.js:537:25)
                                        at Module.require (internal/modules/cjs/loader.js:665:17)
                                        at require (internal/modules/cjs/helpers.js:20:18)
                                        at [eval]:1:1
                                        at Script.runInThisContext (vm.js:123:20)
                                        at Object.runInThisContext (vm.js:312:38)
                                        at Object.<anonymous> ([eval]-wrapper:6:22)
                                        at Module._compile (internal/modules/cjs/loader.js:736:30)
                                        at evalScript (internal/process/execution.js:56:25)
                                        throw err;
                                        at [eval]:1:1
                                    gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                    gypgyp  ERR!ERR!  configure error
                                    configure error
                                    gypgyp  ERR!ERR! stack  Error: `gyp` failed with exit code: 1
                                    stackgyp Error: `gyp` failed with exit code: 1
                                     ERR!gyp  stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
                                    ERR!gyp  stackERR!      at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
                                    stack     at ChildProcess.emit (events.js:197:13)
                                    gypgyp  ERR!ERR!  stackstack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                                    gyp ERR! stackgyp      at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                                    ERR! System Linux 4.14.79-v7+
                                    gypgyp  ERR! ERR!command  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
                                    gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                                    gypgyp ERR!  node -vERR! v11.8.0
                                     commandgyp  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
                                    ERR! node-gyp -v v3.8.0
                                    gyp gyp ERR!ERR!  not okcwd
                                    gyp ERR! node -v v11.8.0
                                    gyp ERR! node-gyp -v v3.8.0
                                    gyp ERR! not ok
                                    node-pre-gyp ERR! build error
                                    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm' (1)
                                    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
                                    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:978:16)
                                    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:265:5)
                                    node-pre-gyp ERR! System Linux 4.14.79-v7+
                                    node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                    node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                                    node-pre-gyp ERR! node -v v11.8.0
                                    node-pre-gyp ERR! node-pre-gyp -v v0.6.39
                                    node-pre-gyp ERR! not ok
                                    npm WARN MMM-Hotword@1.1.0 No repository field.
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the snowboy@1.3.1 install script.
                                    npm ERR!     /home/pi/.npm/_logs/2019-01-29T21_16_15_265Z-debug.log
                                      A Former User @cjdzombie
                                      @cjdzombie
                                      ‘npm install nan’ then do ‘npm install’ again
                                        cjdzombie @Guest
                                        @sean said in MMM-Hotword:
                                        npm install
                                        Thanks for your reply. I ran the suggested commands.
                                        pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install nan
                                        and then
                                        Unfortunately I got the same result. It seems that Snowboy is the issue. It just wont install in the process. When I try the next command in the process I get this result.
                                        cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                                        I get the reply
                                        pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                                        bash: cd: /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: No such file or directory
                                        I’ve been at this since last weekend. It’s fun , but frustrating. Any other help would be awesome.
                                        Thanks!
                                        ? S 3 Replies Last reply Reply Quote 0
                                          @cjdzombie
                                          and then
                                          Same result? Your prior issue Error: Cannot find module 'nan' should be solved by npm install nan. If not so, that is an issue of another level. It means your npm is not valid. So check again same result.
                                            @cjdzombie
                                            You can contact me with mail : eouia0819@gmail.com or Telegram: @eouia for the details.
                                            • 2 / 3
