Module help for variable
10 Posts 2 Posters 2.2k Views 2 Watching
    rts58
    I’ve created a small module to turn my monitor off when my nest realizes I’ve left the house. This uses a notification from mmm-nest-status. Since I’m a noob I don’t understand how to keep track of a variable between notifications. I’m guessing I need something in start: ? Here is the code:
    Module.register("controlMonitor", {
    	defaults: {},
    		if (notification === 'MMM_NEST_STATUS_UPDATE') {
                this.processData(payload);
    	processData: function(data) {
    		var awayState = 'unknown'; // 'home', 'away'
    		// check for away state
    		if (data.devices && data.structures) {
    			var sId = Object.keys(data.structures)[0];
    			var sObj = data.structures[sId];
    			awayState = sObj.away;
    		var oldAwayState = this.awayState;
    		this.awayState = awayState;
    		// if state has changed and new is away then shut monitor off
    		if (!(this.oldAwayState === awayState) && (this.awayState === 'away')) {
    			//this.sendNotification("REMOTE_ACTION", {action: 'MONITOROFF'});
    				console.log(this.name + "awayState " + awayState + "oldAwayState " + oldAwayState + " " + this.datetime4log());
    		// if state has changed and new is home then turn monitor on
    		if (!(this.oldAwayState === awayState) && (this.awayState === 'home')) {
    			//this.sendNotification("REMOTE_ACTION", {action: 'MONITORON'});
    	datetime4log: function() {
    		var d = new Date();
    		return (d.getMonth()+1) + "/" + d.getDate() + "/" + d.getHours() + ":" + d.getMinutes() + ":" + d.getSeconds();
    What’s happing now is the home state is firing off every 2 minutes for every notification. I need a module level oldAwayState variable, so the when I get the update I can test against it to only fire off an update if there is a change.
    S 1 Reply Last reply Feb 5, 2019, 5:33 PM Reply Quote 0
      sdetweil @rts58
      @rts58 said in Module help for variable:
      	defaults: {},
              oldAwayState: 'unknown',
              awayState: 'unknown',
        rts58
        Thank you @sdetweil ! So that helps me to create the module level variable. Sorry for dumb question, but how to I read/write it from within my process data function? I thought using this.oldAwayState would be the module level.
        S 1 Reply Last reply Feb 5, 2019, 6:19 PM Reply Quote 0
          sdetweil @rts58
          @rts58 this should work w your code as is
            rts58
            That’s what I thought. But it still fires off every two minutes, there must be an error in the logic.
              rts58
              Is there something wrong with this:
              maybe they are both not strings or something?
              S 1 Reply Last reply Feb 5, 2019, 9:34 PM Reply Quote 0
                sdetweil @rts58
                @rts58 you can use the dev console and put stops in the code and look at the variables
                R 2 Replies Last reply Feb 5, 2019, 10:16 PM Reply Quote 1
                  rts58 @sdetweil
                  @sdetweil thanks, I’ll give that a try. I’ve been writing the variables to the consol log but it’s not quite as helpful.
                  S 1 Reply Last reply Feb 5, 2019, 10:24 PM Reply Quote 0
                    sdetweil @rts58
                    @rts58 the dev light is only for the module just file ( where getDom() is located)
                    Debugging the node helper or included scripts needs the console.log. sorry for confusion
                      rts58 @sdetweil
                      @sdetweil Thanks, I got it. I needed to get rid of “this”. So the correct test was:
                      if (!(oldAwayState === awayState) && (awayState === 'home'))
