    Module help for variable
    10 Posts 2 Posters 3.0k Views 2 Watching
      rts58
      That’s what I thought. But it still fires off every two minutes, there must be an error in the logic.
        rts58
        Is there something wrong with this:
        if (!(this.oldAwayState === awayState) && (this.awayState === 'home'))
        maybe they are both not strings or something?
          sdetweil @rts58
          @rts58 you can use the dev console and put stops in the code and look at the variables
          R 2 Replies Last reply Reply Quote 1
            rts58 @sdetweil
            @sdetweil thanks, I’ll give that a try. I’ve been writing the variables to the consol log but it’s not quite as helpful.
              sdetweil @rts58
              @rts58 the dev light is only for the module just file ( where getDom() is located)
              Debugging the node helper or included scripts needs the console.log. sorry for confusion
                rts58 @sdetweil
                @sdetweil Thanks, I got it. I needed to get rid of “this”. So the correct test was:
                if (!(oldAwayState === awayState) && (awayState === 'home'))
