    Module help for variable
    10 Posts 2 Posters 2.9k Views 2 Watching
      rts58
      I’ve created a small module to turn my monitor off when my nest realizes I’ve left the house. This uses a notification from mmm-nest-status. Since I’m a noob I don’t understand how to keep track of a variable between notifications. I’m guessing I need something in start: ? Here is the code:
      Module.register("controlMonitor", {
      	defaults: {},
      		if (notification === 'MMM_NEST_STATUS_UPDATE') {
                  this.processData(payload);
      	processData: function(data) {
      		var awayState = 'unknown'; // 'home', 'away'
      		// check for away state
      		if (data.devices && data.structures) {
      			var sId = Object.keys(data.structures)[0];
      			var sObj = data.structures[sId];
      			awayState = sObj.away;
      		var oldAwayState = this.awayState;
      		this.awayState = awayState;
      		// if state has changed and new is away then shut monitor off
      		if (!(this.oldAwayState === awayState) && (this.awayState === 'away')) {
      			//this.sendNotification("REMOTE_ACTION", {action: 'MONITOROFF'});
      				console.log(this.name + "awayState " + awayState + "oldAwayState " + oldAwayState + " " + this.datetime4log());
      		// if state has changed and new is home then turn monitor on
      		if (!(this.oldAwayState === awayState) && (this.awayState === 'home')) {
      			//this.sendNotification("REMOTE_ACTION", {action: 'MONITORON'});
      	datetime4log: function() {
      		var d = new Date();
      		return (d.getMonth()+1) + "/" + d.getDate() + "/" + d.getHours() + ":" + d.getMinutes() + ":" + d.getSeconds();
      What’s happing now is the home state is firing off every 2 minutes for every notification. I need a module level oldAwayState variable, so the when I get the update I can test against it to only fire off an update if there is a change.
        sdetweil @rts58
        @rts58 said in Module help for variable:
        	defaults: {},
                oldAwayState: 'unknown',
                awayState: 'unknown',
          rts58
          Thank you @sdetweil ! So that helps me to create the module level variable. Sorry for dumb question, but how to I read/write it from within my process data function? I thought using this.oldAwayState would be the module level.
            sdetweil @rts58
            @rts58 this should work w your code as is
              rts58
              That’s what I thought. But it still fires off every two minutes, there must be an error in the logic.
                rts58
                Is there something wrong with this:
                maybe they are both not strings or something?
                  sdetweil @rts58
                  @rts58 you can use the dev console and put stops in the code and look at the variables
                  R 2 Replies Last reply Reply Quote 1
                    rts58 @sdetweil
                    @sdetweil thanks, I’ll give that a try. I’ve been writing the variables to the consol log but it’s not quite as helpful.
                      sdetweil @rts58
                      @rts58 the dev light is only for the module just file ( where getDom() is located)
                      Debugging the node helper or included scripts needs the console.log. sorry for confusion
                        rts58 @sdetweil
                        @sdetweil Thanks, I got it. I needed to get rid of “this”. So the correct test was:
                        if (!(oldAwayState === awayState) && (awayState === 'home'))
