    Start or not...?
    44 Posts 4 Posters 41.7k Views 4 Watching
    • E Offline
      Egnos
      Sorry guys i need your help again!
      I had to reinstall raspbian due to a module that did not work.
      Before formatting the SD, I backed up the MagicMirror folder.
      Question: can I copy the folders with the old modules (Mmm-assistantmk2, MMM-Pages, etc…) in the new MagicMirror installation?
      Thanks.
        A Former User @Egnos
        @egnos
        Some modules could be copied. But some modules couldn’t. They needs new installation for dependencies.
        • E Offline
          Egnos @Guest
          @sean Let’s take the example of the “AssistantMk2” module.
          To copy the module I should follow these steps:
          • Install the pre-dependencies: sudo apt-get install libasound2-dev sox libsox-fmt-all
          • I copy the “MMM-AssistantMk2” folder to the new “modules” folder.
          • In theory I should not follow the fourth chapter of the installation guide IV. Google Assistant Setup, because the configuration has already been implemented.
          All right?
          Thanks.
            @egnos
            I can not guarantee your copied folder might work because it is not “built/compiled” on new machine.
            • 3 / 3
