error when try to start mm
npm info it worked if it ends with ok
npm info using npm@5.0.3
npm info using node@v8.1.3
npm info lifecycle magicmirror@2.6.0~prestart: magicmirror@2.6.0
npm info lifecycle magicmirror@2.6.0~start: magicmirror@2.6.0magicmirror@2.6.0 start /opt/magic_mirror
sh run-start.shnpm info lifecycle magicmirror@2.6.0~start: Failed to exec start script
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! magicmirror@2.6.0 start:sh run-start.sh
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.6.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
npm ERR! /fakehome/root/.npm/_logs/2019-02-10T00_24_58_360Z-debug.log -
I figured out the error occured when I try to run mm from ssh if I run directly on rpi consol it works?
But I need to find solution to run mm from ssh. How?
@lpt2007
Have you read the readme of MagicMirror?Also note that:
npm start does not work via SSH. But you can use
DISPLAY=:0 nohup npm start &instead.
This starts the mirror on the remote display.AxLED
