    Testing MM modules
    7 Posts 6 Posters 4.8k Views 9 Watching
    • nwoottonN Offline
      nwootton Module Developer @arjunrao87
      @arjunrao87 I’m trying to figure this out myself - did you get anywhere?
      I can find lots of information about the MM Test Suite, but I just want to write tests against a specific module I’m developing. Normally I’d use Mocha, but that just throws error after error when I try to get it to do anything against my own module.
        roramirez Core Contributors @nwootton
        @nwootton You can use the testsuite for kickoff. A good point in the future if we can integrate the modules test can be run inside the testsuite of MM.
        S J 2 Replies Last reply Reply Quote 1
          stromwerk @roramirez
            jfisher446 @roramirez
            @roramirez Can you advise if there has been any progress made towards this in the time since your previous reply?
            • BKeyportB Offline
              BKeyport Module Developer
              I have three MM’s running. My home and work ones, and the test MM.
              That test one is regularly reinstalled down to the OS (yes, I’ve screwed things up THAT badly)
                roramirez Core Contributors @jfisher446
                @jfisher446 You can add new test inside of testsuite for own module.
