Screen keeps going to black after a few minutes.
5 Posts 3 Posters 9.9k Views 3 Watching
  • T Offline
    tjop
    I followed these instructions to set up my magic mirror and turn off the screensaver and screen blanking but the screen is still going to black after a few minutes. Could someone please help me or let me know what I might be missing. Pretty much new to coding, so I am trying to find my way around.
    "Step 3
    Let’s disable the screen saver and screen blanking as well. This needs to be done in two places. First in the autostart configuration:
    sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
    And add the following to the bottom of the file:
    @xset s noblank
    @xset s off
    @xset -dpms
    Next in the X-windows manager configuration:
    sudo nano /etc/lightdm/lightdm.conf
    Scroll down to the [SeatDefaults] section and look for the xserver-command line below that. Change the line to look like this:
    xserver-command=X -s 0 -dpms (so you’re removing the # on the front, and adding the missing bits at the end.) Again, hit CTRL-X and say Y(es) to saving the file.
    C 1 Reply Last reply Sep 23, 2016, 5:51 PM Reply Quote 0
      chengstark @tjop
      @tjop true, so disable the sleeping function of the pi should work right?
        chengstark
        run
        nano /home/pi/.config/lxsession/LXDE-pi/autostart
        Comment out (put a # in front of) the lines that are already in the file and add these 4 lines.
        @xset s off
        @xset -dpms
        @xset s noblank
        @midori -e Fullscreen -a http://localhost/MagicMirror/index.php
        This will disable the screensaver and start the magic mirror on boot and skip loading the LXDE GUI.
        quoted from “https://www.reddit.com/r/raspberry_pi/comments/3oktfu/magic_mirror_how_to/”
        T 1 Reply Last reply Sep 23, 2016, 10:20 PM Reply Quote 0
        • T Offline
          tjop @chengstark
          @chengstark said in Screen keeps going to black after a few minutes.:
          I went ahead and tried what you suggested and it wasn’t successful. I couldn’t get it to auto-start or stop it from going to sleep. I wish I could give more details, but I am completely new to coding.
            An extreme measure here would be to try this:
            https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=41898&start=25
            xscreensaver can be used right off the menu… you can set/turn on/turn off functions.
