    Can you call a module multiple times with different parameters?
    5 Posts 2 Posters 1.3k Views 2 Watching
      stuartiannaylor
      Maybe you can, but I am using mmm-pages.
      Is there anyway to do it or do you just copy and rename modules?
        sdetweil @stuartiannaylor
        @stuartiannaylor sure, just add another { module:…} block to the config… it will have a different ID than some other instance
          stuartiannaylor
          If I am using pages which is which.
          I will give it a go and see.
            @stuartiannaylor sorry, I don’t use pages
              stuartiannaylor @sdetweil
              Yeap works just the same.
              Starting to get to grips with things Pages just suspends and restarts scripts for each page they are allocated.
              So it just needs to be referenced once in pages.
