    Infrared Touch Frame - rotate?
    7 Posts 3 Posters 3.4k Views 4 Watching
    • peemoellerP Offline
      peemoeller
      Hi there! I have my MagicMirror up and running in portrait mode and works well. I have just added a 42" Infrared Touch Frame Overlay but the touch cursor moves the wrong direction (ie. the touch cursor stuck to landscape)
      How does one calibrate the touch cursor to portrait mode? I slide my finger up the mirror and the cursor moves right ~ lol.
      I have installed xinput but not sure how or where to adjust the settings.
      Any help appreciated!
      • yawnsY Offline
        yawns Moderator
        Did you install xinput_calibrator?
        https://github.com/tias/xinput_calibrator/
        peemoellerP 1 Reply Last reply Reply Quote 0
          peemoeller @yawns
          @yawns Hello, yes and just finished running the xinput touch calibrator program under preferences (it had me touch the 4 red crosses). No issues there but I don’t know how or where to change the touch programming to “portrait” mode. I slide my finger up the monitor and the curser moves left.
          Would you have any instructions? Thanks again!
            sdetweil @peemoeller
            @peemoeller see here
            https://askubuntu.com/questions/368317/rotate-touch-input-with-touchscreen-and-or-touchpad
              peemoeller @sdetweil
              @sdetweil Awesome thanks!
              In his website link I created the portrait.sh file but don’t wuite understand this 2nd part in his instructions:
              “Afterwards, I also made launchers to automatically run each shell script when I tapped on them (this is possible in Xubuntu, Ubuntu MATE, and many other Ubuntu flavours). To do so, go to your panel, right-click, click on “add to panel” (or equivalent, for all these subsequent commands, too), create a custom application launcher. For portrait’s launcher, put in this command:
              sh /home/username/Scripts/portrait”
              Are you able to elaborate? I am somewhat new to this :)
              Appreciate the guidance!
              ~ Eric.
                @peemoeller he made apps(launcher) in the ubuntu graphical interface. So he could switch orientations just from a menu.
                If u are doing just once, u won’t need that.
                But he may have left out a step.
                From the command shell, where your little script is located, do
                chmod +x portrait.sh
                To make the script executable
                  @sdetweil That worked! Nice :)
                  In Terminal I entered: chmod +x portrait.sh
                  Then executed the portrait.sh file I made
                  and the touch IR is now set to portrait.
                  So happy, thanks for your help buddy!
                  I’ve re-ran the “Calibrate Touchscreen” in Preferences again too. It reads:
                  < Calibrating standard Xorg driver “Multi touch overlay device” current calibration values: min_x=0, max_x=65535 and min_y=0, max_y=65535
                  If these values are estimating wrong, either supply it manually with the - -precalib option, or run the ‘get_precalib.sh’ script to automatically get it (through HAL). >
                  I find the touch curser doesn’t reach the the edges of my monitor. Example I can’t simply click on the Raspberry Icon in the corner. The curser is diaginally 2 inches away?
                  Where can I set or adjust this? Any thoughts?
                  Fun!
