    Anyone know how to use MMM-ShairportMetadata?
    16 Posts 4 Posters 6.5k Views 4 Watching
      jmartin1009
      I have Shairport-Sync working, but i can’t find a good guide on how to install the ShairportMetadata module. The GitHub page doesn’t seem to give much of a guide, unless literally all you have to do is copy the code into the array and it works. All help is appreciated, thanks!
      ? 1 Reply Last reply
        A Former User @jmartin1009
        @jmartin1009
        Open Shairport Sync configuration file at /etc/shairport-sync.conf (note that in FreeBSD it will be at /usr/local/etc/shairport-sync.conf).
        Then modify content by sample of MMM-ShairprtMetadata instruction. There aren’t so many things to do…
          jmartin1009
          so all i have to do is modify that file in the way it is on the Github page and then copy the code for the module into the module array and that’s it?
            @jmartin1009
            Yes, that is all. Basically this module’s purpose is showing album art and song title of current playing via Shairport. That’s all, so there be not so many things to do.
            J A 2 Replies Last reply
              jmartin1009 @Guest
              @sean i went into the .conf file and i changed the values for the metadata section, but when i try to save it says “permission denied”. What do i have to do to let it let me save the file?
                @jmartin1009
                Open it with ‘sudo’
                J 2 Replies Last reply
                  jmartin1009 @Guest
                  @sean got it, thank you so much! Very new to this so not always sure what to do even for the “easy” stuff haha :smiling_face_with_open_mouth_cold_sweat:
                    jmartin1009 @Guest
                    @sean Well, unfortunately i edited to metadata stuff and i put the code in the modules array in config.js, but the module isn’t appearing on the screen when i have music playing. Is there something i am missing?
                      @jmartin1009
                      is a song been playing on default iphone “Music” app with AirPlay? You can set output stream to your shairport device name on the music app of iphone Then song will be played on MM via shairport.
                      If just cover or title is not shown but song is played, check pipe and address.
                        jmartin1009 @Guest
                        @sean the pipe names/adresses match up, but what about the address? how does that come into play? I have it set to the default value that it came with and also says on Github, but if it needs to be changed what do i change it to? Thanks.
                        M 1 Reply Last reply
                          jmartin1009 @Guest
                          @sean also, it is playing music due to the shairport-sync i set up, but nothing at all is displayed on screen when music is played.
                            @jmartin1009
                            Hmmm… .with my previous experience, If you set pipe properly (both of module and Shairport) there might not be so much thing to do. Weird…
                            J 1 Reply Last reply
                              jmartin1009 @Guest
                              @sean do I have to have anything to receive the metadata or anything? I know that’s a thing but I don’t know if it applys to this module, all I have is shairport-sync set up and then I set up mmm-shairportmetadata and idk if I need anything else. I can’t seem to find much on the module itself so idk what’s going wrong :/
                                jmartin1009
                                Can anyone help? I did
                                cat /tmp/shairport-sync-metadata
                                And it still isn’t working, could use help from anyone! Thanks!
                                • A
                                  amaralia @Guest
                                  @Sean Hello, and thank you for this module.
                                  I need your help because I don’t really understand how to add the code “metadata”
                                  Regards,
                                    monkeyjb123 @jmartin1009
                                    @jmartin1009 did you ever figure this out? Running into some trouble as well
