    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 569.5k Views 58 Watching
      plumcraft
      After retrying couple of times to make it work, it looks like the issue was coming the raspbian distribution or python package issue.
      After reflashing my sd card with a fresh raspbian image, my camera works…
        bobbob601
        • paviroP
          paviro
          It checks every second or so but you can configure the interval.You can buy longer cables for the Pi cam :)
            bobbob601
              rajbadri
              i am having a problem that the screen remains blank after i am logged in
              (1_1473950091065_2.jpg 0_1473950091063_1.jpg image url)
              R 1 Reply Last reply
                rvdgeer
                Very nice module.
                However I keep ruinning into the same error when I try capture.py to convert them to pgm files:
                Could not detect single face!
                I’ve taken ‘selfies’ with different camera’s in different lighting conditions, but not even one is good enough to convert into a pgm file…
                Can you please give me some clues on what conditions my pictures have to meet?
                Am I doing something wrong?
                All help and advice appreciated!
                  rvdgeer @rajbadri
                  @rajbadri Have you added the classes: (with a value) to all the other modules in the config.js? If you get a plain black screen without errors it might be that no modules were loaded.
                    rvdgeer @rvdgeer
                    @rvdgeer OK, replying to my own post for future reference:
                    I got it working by doing the following:
                    • cropped the pictures to only show my face;
                    • copied the cropped pictures and transformed them to greyscale;
                    • copied the grey pictures and upped the contact;
                    • moved all pictures (originals and copies) to a direct sub folder of the facetrainer folder;
                    • started the capture.py, pressed 2, entered my name, entered the name of the sub folder (only the sub folder, not the entire path) and waited.
                    This way I got it to recognize about 10 of the pictures…
                    Not bad!
                    Getting it to recognize me is still not easy, but that because of the lighting conditions in my ManCave where I’m putting it together.
                    paviroP 1 Reply Last reply
                      shashank @paviro
                      @paviro Hi,
                      I am getting this error while running facerecognition.py0_1474901812661_upload-7d382f42-082d-4217-9aaa-2306d35ef583
                      and also need to know in //Facerecognition Test Tool Readme
                      In tools/facerecognition_tester/lib/config.py add add your training labels from tools/facetrainer under personen = [] ( what need to enter in this personen= [])
                        rvdgeer @shashank
                        @shashank If you run the facetrainer (capture.py and train.py) first, you should know what to enter here…
                          shashank @rvdgeer
                          @rvdgeer hi,
                          After running capture.py a folder created by name ‘sasi’ in the /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/training_data
                          then by running train.py a training.xml created in the path
                          and also in /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facerecognition_tester/lib i mentioned name in personen = ["sasi"]
                          my config.js file as below
                              module: 'MMM-Facial-Recognition',
                              position: 'top_left',
                                  // 1=LBPH | 2=Fisher | 3=Eigen
                                  recognitionAlgorithm: 1,
                                  // Threshold for the confidence of a recognized face before it's considered a
                                  // positive match.  Confidence values below this threshold will be considered
                                  // a positive match because the lower the confidence value, or distance, the
                                  // more confident the algorithm is that the face was correctly detected.
                                  lbphThreshold: 50,
                                  fisherThreshold: 250,
                                  eigenThreshold: 3000,
                                  // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                                  useUSBCam: false,
                                  // Path to your training xml
                                  trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
                                  // recognition intervall in seconds (smaller number = faster but CPU intens!)
                                  interval: 2,
                                  // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                                  logoutDelay: 15,
                                  // Array with usernames (copy and paste from training script)
                                  users: ['sasi'],
                                  //Module set used for strangers and if no user is detected
                                  defaultClass: "default",
                                  //Set of modules which should be shown for every user
                                  forAllClass: "for_all"
                              module: 'clock',
                              //Set your classes here seperated by a space.
                              //Shown for all users
                              classes: 'for_all'
                          when i run pm2 start mm i am struck at below message
                          0_1474984402690_upload-363493b4-6bba-4782-bab1-808bb8a3f585
                          can someone help me on this error
                          • Z
                            zachlan
                            Potentially stupid question here, apologies in advance if I’ve missed something obvious. I have the mirror and the face recognition working (Yay!) but when it’s running, on the left side of the screen it shows “MMM-Facial-Recognition” and module-10-mmm-facial-recognition underneath. I though about removing the position tag, but that’s there in the readme version so did not. How do I remove the text showing the running facial recognition module?
                            Thanks!Zach
                            • paviroP
                              paviro @shashank
                              @rvdgeer that sucks sorry about that. Recognition can be tricky sometimes :/
                              @shashank check the trainingFile in your config, does it really exist at that location?
                              Update: I see you figured it out, was a wrong location the problem? Just remove the position part is isn’t relevant anymore sorry :)
                              S P 2 Replies Last reply
                              • paviroP
                                paviro @rvdgeer
                                  shashank @paviro
                                  @paviro
                                  yes , i copied the training file from //MMM-Facial-Recognition-Tools/facetrainer
                                  to // Path to your training xml
                                  trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
                                    s1084836
                                    Hello, First of all thanks a lot for building this great module!
                                    I am trying to get it to work, I’ve installed the module and it looks like It doens’t start:
                                    Output when I start the NPM:
                                    `pi@raspberrypi:~/MagicMirror $ npm start
                                    magicmirror@2.0.0 start /home/pi/MagicMirror
                                    electron js/electron.js
                                    Loading config ...
                                    Loading module helpers ...
                                    All module helpers loaded.
                                    Starting server op port 8080 ...
                                    Server started ...
                                    Connecting socket for: camera
                                    camera helper started ...
                                    Connecting socket for: MMM-Facial-Recognition
                                    Staring module helper: MMM-Facial-Recognition
                                    Launching application.
                                    initializing nodemailer
                                    It looks like its installed fine, because of the starting module helper: MMM-Facial-Recognition.
                                    But I am not getting the normal output like I see by other people:
                                    [MMM-Facial-Recognition] Facerecognition started...
                                    [MMM-Facial-Recognition] Loading training data...
                                    My Config.json file:
                                    `/* Magic Mirror Config Sample
                                    By Tom & Joey
                                    MIT Licensed.
                                    var config = {
                                    port: 8080,
                                    language: 'nl',
                                    timeFormat: 24,
                                    units: 'metric',
                                                module: 'camera',
                                    	    position: 'top_center',
                                    		selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
                                    	        emailConfig: {
                                    	            service: 'Hotmail', // Email provider to use to send email with a photo.
                                    	            auth: {
                                    	                user: '<s1084836@hotmail.com>', // Your email account
                                    	                pass: '<test12345>'        // Your password for email account
                                    			lbphThreshold: 50,
                                    			useUSBCam: true,
                                    			interval: 2,
                                    			logoutDelay: 15,
                                    			users: ['Tom'],
                                    			everyoneClass: "everyone"
                                    Is there anything I’m doing wrong ? :D
                                    • A
                                      awarrington
                                      @paviro thanks creating such a cool module!
                                      I have followed the instructions to capture the training images and have successfully created a training.xml file :)
                                      When I add the MMM-Facial-Recognition module to my Magic Mirror config.js file I get “WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration” in the terminal and the Magic Mirror shows an error page saying config.js not found.
                                      My config.js is:
                                      var config = {
                                      	port: 8080,
                                      	language: 'en',
                                      	timeFormat: 12,
                                      	units: 'metric',
                                      			module: 'clock',
                                      			classes: 'everyone'
                                      			module: 'compliments',
                                      			position: 'lower_third'
                                      			classes: 'andy'
                                      				lbphThreshold: 50,
                                      				useUSBCam: false,
                                      				trainingFile: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition/training.xml',
                                      				interval: 3,
                                      				logoutDelay: 15,
                                      				users: ['andy'],
                                      If I comment out " classes: ‘everyone’ " and " classes: ‘andy’ " in the other modules the MagicMirror loads with no errors but blank black screen.
                                      Any ideas what’s causing this ?
                                        rvdgeer @awarrington
                                        @awarrington It seems like you’ve missed the comma’s at the end of the line where the position is for the clock and compliments module here:
                                        			module: 'clock',
                                        			position: 'top_left', <--
                                        			classes: 'everyone'
                                        • A
                                          awarrington
                                          @rvdgeer Thank you! All works perfectly now
                                            RobbieMcl
                                            • 10
                                            • 11
                                            • 4 / 11
