    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.1k Views 58 Watching
      rajbadri
      i am having a problem that the screen remains blank after i am logged in
      (1_1473950091065_2.jpg 0_1473950091063_1.jpg image url)
      R 1 Reply Last reply
        rvdgeer
        Very nice module.
        However I keep ruinning into the same error when I try capture.py to convert them to pgm files:
        Could not detect single face!
        I’ve taken ‘selfies’ with different camera’s in different lighting conditions, but not even one is good enough to convert into a pgm file…
        Can you please give me some clues on what conditions my pictures have to meet?
        Am I doing something wrong?
        All help and advice appreciated!
          rvdgeer @rajbadri
          @rajbadri Have you added the classes: (with a value) to all the other modules in the config.js? If you get a plain black screen without errors it might be that no modules were loaded.
            rvdgeer @rvdgeer
            @rvdgeer OK, replying to my own post for future reference:
            I got it working by doing the following:
            • cropped the pictures to only show my face;
            • copied the cropped pictures and transformed them to greyscale;
            • copied the grey pictures and upped the contact;
            • moved all pictures (originals and copies) to a direct sub folder of the facetrainer folder;
            • started the capture.py, pressed 2, entered my name, entered the name of the sub folder (only the sub folder, not the entire path) and waited.
            This way I got it to recognize about 10 of the pictures…
            Not bad!
            Getting it to recognize me is still not easy, but that because of the lighting conditions in my ManCave where I’m putting it together.
            paviroP 1 Reply Last reply
              shashank @paviro
              @paviro Hi,
              I am getting this error while running facerecognition.py0_1474901812661_upload-7d382f42-082d-4217-9aaa-2306d35ef583
              and also need to know in //Facerecognition Test Tool Readme
              In tools/facerecognition_tester/lib/config.py add add your training labels from tools/facetrainer under personen = [] ( what need to enter in this personen= [])
                rvdgeer @shashank
                @shashank If you run the facetrainer (capture.py and train.py) first, you should know what to enter here…
                  shashank @rvdgeer
                  @rvdgeer hi,
                  After running capture.py a folder created by name ‘sasi’ in the /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/training_data
                  then by running train.py a training.xml created in the path
                  and also in /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facerecognition_tester/lib i mentioned name in personen = ["sasi"]
                  my config.js file as below
                      module: 'MMM-Facial-Recognition',
                      position: 'top_left',
                          // 1=LBPH | 2=Fisher | 3=Eigen
                          recognitionAlgorithm: 1,
                          // Threshold for the confidence of a recognized face before it's considered a
                          // positive match.  Confidence values below this threshold will be considered
                          // a positive match because the lower the confidence value, or distance, the
                          // more confident the algorithm is that the face was correctly detected.
                          lbphThreshold: 50,
                          fisherThreshold: 250,
                          eigenThreshold: 3000,
                          // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                          useUSBCam: false,
                          // Path to your training xml
                          trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
                          // recognition intervall in seconds (smaller number = faster but CPU intens!)
                          interval: 2,
                          // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                          logoutDelay: 15,
                          // Array with usernames (copy and paste from training script)
                          users: ['sasi'],
                          //Module set used for strangers and if no user is detected
                          defaultClass: "default",
                          //Set of modules which should be shown for every user
                          forAllClass: "for_all"
                      module: 'clock',
                      //Set your classes here seperated by a space.
                      //Shown for all users
                      classes: 'for_all'
                  when i run pm2 start mm i am struck at below message
                  0_1474984402690_upload-363493b4-6bba-4782-bab1-808bb8a3f585
                  can someone help me on this error
                  • Z
                    zachlan
                    Potentially stupid question here, apologies in advance if I’ve missed something obvious. I have the mirror and the face recognition working (Yay!) but when it’s running, on the left side of the screen it shows “MMM-Facial-Recognition” and module-10-mmm-facial-recognition underneath. I though about removing the position tag, but that’s there in the readme version so did not. How do I remove the text showing the running facial recognition module?
                    Thanks!Zach
                    • paviroP
                      paviro @shashank
                      @rvdgeer that sucks sorry about that. Recognition can be tricky sometimes :/
                      @shashank check the trainingFile in your config, does it really exist at that location?
                      Update: I see you figured it out, was a wrong location the problem? Just remove the position part is isn’t relevant anymore sorry :)
                      S P 2 Replies Last reply
                      • paviroP
                        paviro @rvdgeer
                          shashank @paviro
                          @paviro
                          yes , i copied the training file from //MMM-Facial-Recognition-Tools/facetrainer
                          to // Path to your training xml
                          trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
                            s1084836
                            Hello, First of all thanks a lot for building this great module!
                            I am trying to get it to work, I’ve installed the module and it looks like It doens’t start:
                            Output when I start the NPM:
                            `pi@raspberrypi:~/MagicMirror $ npm start
                            magicmirror@2.0.0 start /home/pi/MagicMirror
                            electron js/electron.js
                            Loading config ...
                            Loading module helpers ...
                            All module helpers loaded.
                            Starting server op port 8080 ...
                            Server started ...
                            Connecting socket for: camera
                            camera helper started ...
                            Connecting socket for: MMM-Facial-Recognition
                            Staring module helper: MMM-Facial-Recognition
                            Launching application.
                            initializing nodemailer
                            It looks like its installed fine, because of the starting module helper: MMM-Facial-Recognition.
                            But I am not getting the normal output like I see by other people:
                            [MMM-Facial-Recognition] Facerecognition started...
                            [MMM-Facial-Recognition] Loading training data...
                            My Config.json file:
                            `/* Magic Mirror Config Sample
                            By Tom & Joey
                            MIT Licensed.
                            var config = {
                            port: 8080,
                            language: 'nl',
                            timeFormat: 24,
                            units: 'metric',
                                        module: 'camera',
                            	    position: 'top_center',
                            		selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
                            	        emailConfig: {
                            	            service: 'Hotmail', // Email provider to use to send email with a photo.
                            	            auth: {
                            	                user: '<s1084836@hotmail.com>', // Your email account
                            	                pass: '<test12345>'        // Your password for email account
                            			lbphThreshold: 50,
                            			useUSBCam: true,
                            			interval: 2,
                            			logoutDelay: 15,
                            			users: ['Tom'],
                            			everyoneClass: "everyone"
                            Is there anything I’m doing wrong ? :D
                            • A
                              awarrington
                              @paviro thanks creating such a cool module!
                              I have followed the instructions to capture the training images and have successfully created a training.xml file :)
                              When I add the MMM-Facial-Recognition module to my Magic Mirror config.js file I get “WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration” in the terminal and the Magic Mirror shows an error page saying config.js not found.
                              My config.js is:
                              var config = {
                              	port: 8080,
                              	language: 'en',
                              	timeFormat: 12,
                              	units: 'metric',
                              			module: 'clock',
                              			classes: 'everyone'
                              			module: 'compliments',
                              			position: 'lower_third'
                              			classes: 'andy'
                              				lbphThreshold: 50,
                              				useUSBCam: false,
                              				trainingFile: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition/training.xml',
                              				interval: 3,
                              				logoutDelay: 15,
                              				users: ['andy'],
                              If I comment out " classes: ‘everyone’ " and " classes: ‘andy’ " in the other modules the MagicMirror loads with no errors but blank black screen.
                              Any ideas what’s causing this ?
                                rvdgeer @awarrington
                                @awarrington It seems like you’ve missed the comma’s at the end of the line where the position is for the clock and compliments module here:
                                			module: 'clock',
                                			position: 'top_left', <--
                                			classes: 'everyone'
                                • A
                                  awarrington
                                  @rvdgeer Thank you! All works perfectly now
                                    RobbieMcl
                                    • tidus5T
                                      tidus5
                                      Hi everyone,
                                      my module is working fine and i can loggin with my user
                                      Module with class everyone and default are loading fine.
                                      But for module with my class 'Kevin" it doesnt work.
                                      i have this error "ught TypeError: Cannot read property ‘toLowerCase’ of undefined
                                      my ame class is the same as my user (copy paste)
                                      did i miss something ?
                                      thanksssss
                                      • tidus5T
                                        tidus5
                                        Hey :D
                                        little UP - im becoming crazy.
                                        i read and read an read again - add… inside config.js (mirror module) or config.py (model tester)
                                        so users : [‘kevin’]… and the config.py is needed if i want to test with the recognition-tools
                                        right ?
                                        i see if the MMM-Facial use “everyone” or “kevin” that doesnt work
                                        • E
                                          Escenda
                                          I got this problem as well. I had it working but just got a spy cam and had to rpi-update today. Now only “everyone” and “default” classes work. Starting a module with a custom class doesnt work anymore for some reason?
                                          • A
                                            Aly
                                            Hey everyone,
                                            I have also followed the instructions referring taking pics and creating the training file.
                                            If I “start” the MagicMirror nothing happened - only white screen.
                                            If I “start” it without the MMM module (commented it out) everything is working.
                                            Here my config.js:
                                            var config = {
                                            	port: 8080,
                                            	language: 'de',
                                            	timeFormat: 24,
                                            	units: 'metric',
                                            			module: 'alert',
                                            			module: 'clock',
                                            			classes: 'everyone'
                                            			module: 'calendar',
                                            			header: 'Österreich Feiertage',
                                            						symbol: 'calendar-check-o ',
                                            						url: 'webcal://www.calendarlabs.com/templates/ical/Germany-Holidays.ics'
                                            			position: 'lower_third',
                                            			classes: 'Markus'
                                            			module: 'currentweather',
                                            			position: 'top_right',
                                            				locationID: '2781520',  //ID from http://www.openweathermap.org
                                            				appid: '021e48dc7c378757c1fb021bf373d56c'
                                            			module: 'weatherforecast',
                                            			header: 'Weather Forecast',
                                            			module: 'newsfeed',
                                            			position: 'bottom_bar',
                                            				feeds: [
                                            						title: "Tagesschau",
                                            						url: "http://www.tagesschau.de/xml/rss2"
                                            				showSourceTitle: true,
                                            				showPublishDate: true
                                            			lbphThreshold: 50,
                                            			useUSBCam: true,
                                            			interval: 2,
                                            			logoutDelay: 15,
                                            			users: ['Markus'],
                                            bheplerB tidus5T 2 Replies Last reply
                                            • 10
                                            • 11
                                            • 4 / 11
