    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 569.5k Views 58 Watching
    • paviroP
      paviro @rvdgeer
        shashank @paviro
        @paviro
        yes , i copied the training file from //MMM-Facial-Recognition-Tools/facetrainer
        to // Path to your training xml
        trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
          s1084836
          Hello, First of all thanks a lot for building this great module!
          I am trying to get it to work, I’ve installed the module and it looks like It doens’t start:
          Output when I start the NPM:
          `pi@raspberrypi:~/MagicMirror $ npm start
          magicmirror@2.0.0 start /home/pi/MagicMirror
          electron js/electron.js
          Loading config ...
          Loading module helpers ...
          All module helpers loaded.
          Starting server op port 8080 ...
          Server started ...
          Connecting socket for: camera
          camera helper started ...
          Connecting socket for: MMM-Facial-Recognition
          Staring module helper: MMM-Facial-Recognition
          Launching application.
          initializing nodemailer
          It looks like its installed fine, because of the starting module helper: MMM-Facial-Recognition.
          But I am not getting the normal output like I see by other people:
          [MMM-Facial-Recognition] Facerecognition started...
          [MMM-Facial-Recognition] Loading training data...
          My Config.json file:
          `/* Magic Mirror Config Sample
          By Tom & Joey
          MIT Licensed.
          var config = {
          port: 8080,
          language: 'nl',
          timeFormat: 24,
          units: 'metric',
                      module: 'camera',
          	    position: 'top_center',
          		selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
          	        emailConfig: {
          	            service: 'Hotmail', // Email provider to use to send email with a photo.
          	            auth: {
          	                user: '<s1084836@hotmail.com>', // Your email account
          	                pass: '<test12345>'        // Your password for email account
          	    module: 'MMM-Facial-Recognition',
          	    position: 'top_left',
          		        // 1=LBPH | 2=Fisher | 3=Eigen
          			recognitionAlgorithm: 1,
          			// Threshold for the confidence of a recognized face before it's considered a
          			// positive match.  Confidence values below this threshold will be considered
          			// a positive match because the lower the confidence value, or distance, the
          			// more confident the algorithm is that the face was correctly detected.
          			lbphThreshold: 50,
          			fisherThreshold: 250,
          			eigenThreshold: 3000,
          			// force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
          			useUSBCam: true,
          			trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
          			// recognition intervall in seconds (smaller number = faster but CPU intens!)
          			interval: 2,
          			// Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
          			logoutDelay: 15,
          			// Array with usernames (copy and paste from training script)
          			users: ['Tom'],
          			//Module set used for strangers and if no user is detected
          			defaultClass: "default",
          			//Set of modules which should be shown for every user
          			everyoneClass: "everyone"
          Is there anything I’m doing wrong ? :D
          • A
            awarrington
            @paviro thanks creating such a cool module!
            I have followed the instructions to capture the training images and have successfully created a training.xml file :)
            When I add the MMM-Facial-Recognition module to my Magic Mirror config.js file I get “WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration” in the terminal and the Magic Mirror shows an error page saying config.js not found.
            My config.js is:
            var config = {
            	port: 8080,
            	language: 'en',
            	timeFormat: 12,
            	units: 'metric',
            			module: 'clock',
            			classes: 'everyone'
            			module: 'compliments',
            			position: 'lower_third'
            			classes: 'andy'
            				lbphThreshold: 50,
            				useUSBCam: false,
            				trainingFile: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition/training.xml',
            				interval: 3,
            				logoutDelay: 15,
            				users: ['andy'],
            If I comment out " classes: ‘everyone’ " and " classes: ‘andy’ " in the other modules the MagicMirror loads with no errors but blank black screen.
            Any ideas what’s causing this ?
            R 1 Reply Last reply
              rvdgeer @awarrington
              @awarrington It seems like you’ve missed the comma’s at the end of the line where the position is for the clock and compliments module here:
              			module: 'clock',
              			position: 'top_left', <--
              			classes: 'everyone'
              • A
                awarrington
                @rvdgeer Thank you! All works perfectly now
                  RobbieMcl
                  • tidus5T
                    tidus5
                    Hi everyone,
                    my module is working fine and i can loggin with my user
                    Module with class everyone and default are loading fine.
                    But for module with my class 'Kevin" it doesnt work.
                    i have this error "ught TypeError: Cannot read property ‘toLowerCase’ of undefined
                    my ame class is the same as my user (copy paste)
                    did i miss something ?
                    thanksssss
                    • tidus5T
                      tidus5
                      Hey :D
                      little UP - im becoming crazy.
                      i read and read an read again - add… inside config.js (mirror module) or config.py (model tester)
                      so users : [‘kevin’]… and the config.py is needed if i want to test with the recognition-tools
                      right ?
                      i see if the MMM-Facial use “everyone” or “kevin” that doesnt work
                      • E
                        Escenda
                        I got this problem as well. I had it working but just got a spy cam and had to rpi-update today. Now only “everyone” and “default” classes work. Starting a module with a custom class doesnt work anymore for some reason?
                        • A
                          Aly
                          Hey everyone,
                          I have also followed the instructions referring taking pics and creating the training file.
                          If I “start” the MagicMirror nothing happened - only white screen.
                          If I “start” it without the MMM module (commented it out) everything is working.
                          Here my config.js:
                          var config = {
                          	port: 8080,
                          	language: 'de',
                          	timeFormat: 24,
                          	units: 'metric',
                          			module: 'alert',
                          			module: 'clock',
                          			classes: 'everyone'
                          			module: 'calendar',
                          			header: 'Österreich Feiertage',
                          						symbol: 'calendar-check-o ',
                          						url: 'webcal://www.calendarlabs.com/templates/ical/Germany-Holidays.ics'
                          			position: 'lower_third',
                          			classes: 'Markus'
                          			module: 'currentweather',
                          			position: 'top_right',
                          				locationID: '2781520',  //ID from http://www.openweathermap.org
                          				appid: '021e48dc7c378757c1fb021bf373d56c'
                          			module: 'weatherforecast',
                          			header: 'Weather Forecast',
                          			module: 'newsfeed',
                          			position: 'bottom_bar',
                          				feeds: [
                          						title: "Tagesschau",
                          						url: "http://www.tagesschau.de/xml/rss2"
                          				showSourceTitle: true,
                          				showPublishDate: true
                          			lbphThreshold: 50,
                          			useUSBCam: true,
                          			interval: 2,
                          			logoutDelay: 15,
                          			users: ['Markus'],
                          bheplerB tidus5T 2 Replies Last reply
                          • bheplerB
                            bhepler Module Developer @Aly
                            • tidus5T
                              tidus5 @Aly
                              @Aly
                              try with classes : ‘default’
                              You have the same problem as me and @Escenda
                              custom’s classes doesnt work and everyone’s classes neither
                              im on it since 6 days and… it cant found the solution
                              tidus5T 1 Reply Last reply
                              • tidus5T
                                tidus5 @tidus5
                                @Aly @Escenda
                                i found the problem - the localtransport module :-)
                                do you use this module too ? if you remove the module on the config.js its work :D
                                A 1 Reply Last reply
                                • A
                                  Aly @tidus5
                                  @tidus5 No i don’t use this module :/
                                  • tidus5T
                                    tidus5 @Aly
                                    @Aly
                                    could you try to found the module who make the bug by active one by one ?
                                    i found like that
                                    • A
                                      Aly @tidus5
                                      @tidus5 So it looks like that i have problems with the module itself - not with other modules.
                                      • tidus5T
                                        tidus5 @Aly
                                        @Aly if you use the option “DISPLAY=:0 npm start dev”
                                        do you see the error ?
                                        • paviroP
                                          paviro
                                          I will have a look at that.
                                          Update: I just tried to recent version of my module with the current MM version and everything seems to work as expected even custom classes. Please try to use the training tool again and update your users:[] config with the output provided :) Also make sure you use the latest version from GitHub.
                                          In case this does not help please try to install the module from scratch and let me now how it goes.
                                          • A
                                            Aly @tidus5
                                            @tidus5
                                            Hey :)
                                            I received this error :
                                            Thank you in advance! tidus5 & paviro
                                            Great module paviro :)
                                            Happy and peaceful christmas holidays!!
                                            App threw an error during load
                                            Error: Cannot find module 'python-shell'
                                                at Module._resolveFilename (module.js:455:15)
                                                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                                at Function.Module._load (module.js:403:25)
                                                at Module.require (module.js:483:17)
                                                at require (internal/module.js:20:19)
                                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:4:21)
                                                at Module._compile (module.js:556:32)
                                                at Object.Module._extensions..js (module.js:565:10)
                                                at Module.load (module.js:473:32)
                                                at tryModuleLoad (module.js:432:12)
                                            { Error: Cannot find module 'python-shell'
                                                at tryModuleLoad (module.js:432:12) code: 'MODULE_NOT_FOUND' }
                                            • 10
                                            • 11
                                            • 5 / 11
