    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.6k Views 58 Watching
      shashank @paviro
      @paviro Hi,
      I am getting this error while running facerecognition.py0_1474901812661_upload-7d382f42-082d-4217-9aaa-2306d35ef583
      and also need to know in //Facerecognition Test Tool Readme
      In tools/facerecognition_tester/lib/config.py add add your training labels from tools/facetrainer under personen = [] ( what need to enter in this personen= [])
      R 1 Reply Last reply
        rvdgeer @shashank
        @shashank If you run the facetrainer (capture.py and train.py) first, you should know what to enter here…
          shashank @rvdgeer
          @rvdgeer hi,
          After running capture.py a folder created by name ‘sasi’ in the /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/training_data
          then by running train.py a training.xml created in the path
          and also in /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facerecognition_tester/lib i mentioned name in personen = ["sasi"]
          my config.js file as below
              module: 'MMM-Facial-Recognition',
              position: 'top_left',
                  // 1=LBPH | 2=Fisher | 3=Eigen
                  recognitionAlgorithm: 1,
                  // Threshold for the confidence of a recognized face before it's considered a
                  // positive match.  Confidence values below this threshold will be considered
                  // a positive match because the lower the confidence value, or distance, the
                  // more confident the algorithm is that the face was correctly detected.
                  lbphThreshold: 50,
                  fisherThreshold: 250,
                  eigenThreshold: 3000,
                  // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                  useUSBCam: false,
                  // Path to your training xml
                  trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
                  // recognition intervall in seconds (smaller number = faster but CPU intens!)
                  interval: 2,
                  // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                  logoutDelay: 15,
                  // Array with usernames (copy and paste from training script)
                  users: ['sasi'],
                  //Module set used for strangers and if no user is detected
                  defaultClass: "default",
                  //Set of modules which should be shown for every user
                  forAllClass: "for_all"
              module: 'clock',
              //Set your classes here seperated by a space.
              //Shown for all users
              classes: 'for_all'
          when i run pm2 start mm i am struck at below message
          0_1474984402690_upload-363493b4-6bba-4782-bab1-808bb8a3f585
          can someone help me on this error
          paviroP 1 Reply Last reply
          • Z
            zachlan
            Potentially stupid question here, apologies in advance if I’ve missed something obvious. I have the mirror and the face recognition working (Yay!) but when it’s running, on the left side of the screen it shows “MMM-Facial-Recognition” and module-10-mmm-facial-recognition underneath. I though about removing the position tag, but that’s there in the readme version so did not. How do I remove the text showing the running facial recognition module?
            Thanks!Zach
            • paviroP
              paviro @shashank
              @rvdgeer that sucks sorry about that. Recognition can be tricky sometimes :/
              @shashank check the trainingFile in your config, does it really exist at that location?
              Update: I see you figured it out, was a wrong location the problem? Just remove the position part is isn’t relevant anymore sorry :)
              S P 2 Replies Last reply
              • paviroP
                paviro @rvdgeer
                  shashank @paviro
                  @paviro
                  yes , i copied the training file from //MMM-Facial-Recognition-Tools/facetrainer
                  to // Path to your training xml
                  trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
                    s1084836
                    Hello, First of all thanks a lot for building this great module!
                    I am trying to get it to work, I’ve installed the module and it looks like It doens’t start:
                    Output when I start the NPM:
                    `pi@raspberrypi:~/MagicMirror $ npm start
                    magicmirror@2.0.0 start /home/pi/MagicMirror
                    electron js/electron.js
                    Loading config ...
                    Loading module helpers ...
                    All module helpers loaded.
                    Starting server op port 8080 ...
                    Server started ...
                    Connecting socket for: camera
                    camera helper started ...
                    Connecting socket for: MMM-Facial-Recognition
                    Staring module helper: MMM-Facial-Recognition
                    Launching application.
                    initializing nodemailer
                    It looks like its installed fine, because of the starting module helper: MMM-Facial-Recognition.
                    But I am not getting the normal output like I see by other people:
                    [MMM-Facial-Recognition] Facerecognition started...
                    [MMM-Facial-Recognition] Loading training data...
                    My Config.json file:
                    `/* Magic Mirror Config Sample
                    By Tom & Joey
                    MIT Licensed.
                    var config = {
                    port: 8080,
                    language: 'nl',
                    timeFormat: 24,
                    units: 'metric',
                                module: 'camera',
                    	    position: 'top_center',
                    		selfieInterval: 3,  // Time interval in seconds before the photo will be taken.
                    	        emailConfig: {
                    	            service: 'Hotmail', // Email provider to use to send email with a photo.
                    	            auth: {
                    	                user: '<s1084836@hotmail.com>', // Your email account
                    	                pass: '<test12345>'        // Your password for email account
                    			lbphThreshold: 50,
                    			useUSBCam: true,
                    			interval: 2,
                    			logoutDelay: 15,
                    			users: ['Tom'],
                    			everyoneClass: "everyone"
                    Is there anything I’m doing wrong ? :D
                    • A
                      awarrington
                      @paviro thanks creating such a cool module!
                      I have followed the instructions to capture the training images and have successfully created a training.xml file :)
                      When I add the MMM-Facial-Recognition module to my Magic Mirror config.js file I get “WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration” in the terminal and the Magic Mirror shows an error page saying config.js not found.
                      My config.js is:
                      var config = {
                      	port: 8080,
                      	language: 'en',
                      	timeFormat: 12,
                      	units: 'metric',
                      			module: 'clock',
                      			classes: 'everyone'
                      			module: 'compliments',
                      			position: 'lower_third'
                      			classes: 'andy'
                      				lbphThreshold: 50,
                      				useUSBCam: false,
                      				trainingFile: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition/training.xml',
                      				interval: 3,
                      				logoutDelay: 15,
                      				users: ['andy'],
                      If I comment out " classes: ‘everyone’ " and " classes: ‘andy’ " in the other modules the MagicMirror loads with no errors but blank black screen.
                      Any ideas what’s causing this ?
                        rvdgeer @awarrington
                        @awarrington It seems like you’ve missed the comma’s at the end of the line where the position is for the clock and compliments module here:
                        			module: 'clock',
                        			position: 'top_left', <--
                        			classes: 'everyone'
                        • A
                          awarrington
                          @rvdgeer Thank you! All works perfectly now
                            RobbieMcl
                            • tidus5T
                              tidus5
                              Hi everyone,
                              my module is working fine and i can loggin with my user
                              Module with class everyone and default are loading fine.
                              But for module with my class 'Kevin" it doesnt work.
                              i have this error "ught TypeError: Cannot read property ‘toLowerCase’ of undefined
                              my ame class is the same as my user (copy paste)
                              did i miss something ?
                              thanksssss
                              • tidus5T
                                tidus5
                                Hey :D
                                little UP - im becoming crazy.
                                i read and read an read again - add… inside config.js (mirror module) or config.py (model tester)
                                so users : [‘kevin’]… and the config.py is needed if i want to test with the recognition-tools
                                right ?
                                i see if the MMM-Facial use “everyone” or “kevin” that doesnt work
                                • E
                                  Escenda
                                  I got this problem as well. I had it working but just got a spy cam and had to rpi-update today. Now only “everyone” and “default” classes work. Starting a module with a custom class doesnt work anymore for some reason?
                                  • A
                                    Aly
                                    Hey everyone,
                                    I have also followed the instructions referring taking pics and creating the training file.
                                    If I “start” the MagicMirror nothing happened - only white screen.
                                    If I “start” it without the MMM module (commented it out) everything is working.
                                    Here my config.js:
                                    var config = {
                                    	port: 8080,
                                    	language: 'de',
                                    	timeFormat: 24,
                                    	units: 'metric',
                                    			module: 'alert',
                                    			module: 'clock',
                                    			classes: 'everyone'
                                    			module: 'calendar',
                                    			header: 'Österreich Feiertage',
                                    						symbol: 'calendar-check-o ',
                                    						url: 'webcal://www.calendarlabs.com/templates/ical/Germany-Holidays.ics'
                                    			position: 'lower_third',
                                    			classes: 'Markus'
                                    			module: 'currentweather',
                                    			position: 'top_right',
                                    				locationID: '2781520',  //ID from http://www.openweathermap.org
                                    				appid: '021e48dc7c378757c1fb021bf373d56c'
                                    			module: 'weatherforecast',
                                    			header: 'Weather Forecast',
                                    			module: 'newsfeed',
                                    			position: 'bottom_bar',
                                    				feeds: [
                                    						title: "Tagesschau",
                                    						url: "http://www.tagesschau.de/xml/rss2"
                                    				showSourceTitle: true,
                                    				showPublishDate: true
                                    			lbphThreshold: 50,
                                    			useUSBCam: true,
                                    			interval: 2,
                                    			logoutDelay: 15,
                                    			users: ['Markus'],
                                    bheplerB tidus5T 2 Replies Last reply
                                    • bheplerB
                                      bhepler Module Developer @Aly
                                      • tidus5T
                                        tidus5 @Aly
                                        @Aly
                                        try with classes : ‘default’
                                        You have the same problem as me and @Escenda
                                        custom’s classes doesnt work and everyone’s classes neither
                                        im on it since 6 days and… it cant found the solution
                                        tidus5T 1 Reply Last reply
                                        • tidus5T
                                          tidus5 @tidus5
                                          @Aly @Escenda
                                          i found the problem - the localtransport module :-)
                                          do you use this module too ? if you remove the module on the config.js its work :D
                                          A 1 Reply Last reply
                                          • A
                                            Aly @tidus5
                                            @tidus5 No i don’t use this module :/
                                            • 10
                                            • 11
                                            • 4 / 11
