    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.6k Views 58 Watching
    • X
      xdker @paviro
      @paviro
      Oh sorry, I’m sorry I didn’t notice.
      But there are the following tips.
      where is capture.pgm not in the name of the folder.
      Could not detect single face!  Check the image in capture.pgm to see what was captured and try again with only one face visible.
        plumcraft
        Hi everyone,
        I have the same issue.
        What do you want to do?
        [1] Capture training images from webcam
        [2] Convert ‘*.jpg’ pictures from other cameras to training images
        –> 1
        Enter the name of the person you want to capture or convert images for.
        –> olifier
        Images will be placed in ./training_data/olifier
        Starting process…
        Capturing positive training images.
        Type c (and press enter) to capture an image.
        Press Ctrl-C to quit.
        c
        Capturing image…
        Thanks a lot
          sarthak18593 @plumcraft
          @plumcraft Are you using the Pi camera module or a usb webcam ?
          P 1 Reply Last reply
            plumcraft @sarthak18593
            @sarthak18593
            I’m using the pi camera module. It’s correctly enable from the raspi config tool.
              plumcraft
              I’ve tried to capture an image from my pi camera with :
              pi@pi:~ $ raspistill -o output.jpg
              the raspistill tool hang…
              The pi camera might be broken ? someone got the same issue ?
              Do you have any good usb webcam compatible with raspberry pi 3 and opencv ? I would like to use the MMM Face recognition module…
                plumcraft
                After retrying couple of times to make it work, it looks like the issue was coming the raspbian distribution or python package issue.
                After reflashing my sd card with a fresh raspbian image, my camera works…
                  bobbob601
                  • paviroP
                    paviro
                    It checks every second or so but you can configure the interval.You can buy longer cables for the Pi cam :)
                      bobbob601
                        rajbadri
                        i am having a problem that the screen remains blank after i am logged in
                        (1_1473950091065_2.jpg 0_1473950091063_1.jpg image url)
                        R 1 Reply Last reply
                          rvdgeer
                          Very nice module.
                          However I keep ruinning into the same error when I try capture.py to convert them to pgm files:
                          I’ve taken ‘selfies’ with different camera’s in different lighting conditions, but not even one is good enough to convert into a pgm file…
                          Can you please give me some clues on what conditions my pictures have to meet?
                          Am I doing something wrong?
                          All help and advice appreciated!
                            rvdgeer @rajbadri
                            @rajbadri Have you added the classes: (with a value) to all the other modules in the config.js? If you get a plain black screen without errors it might be that no modules were loaded.
                              rvdgeer @rvdgeer
                              @rvdgeer OK, replying to my own post for future reference:
                              I got it working by doing the following:
                              • cropped the pictures to only show my face;
                              • copied the cropped pictures and transformed them to greyscale;
                              • copied the grey pictures and upped the contact;
                              • moved all pictures (originals and copies) to a direct sub folder of the facetrainer folder;
                              • started the capture.py, pressed 2, entered my name, entered the name of the sub folder (only the sub folder, not the entire path) and waited.
                              This way I got it to recognize about 10 of the pictures…
                              Not bad!
                              Getting it to recognize me is still not easy, but that because of the lighting conditions in my ManCave where I’m putting it together.
                              paviroP 1 Reply Last reply
                                shashank @paviro
                                @paviro Hi,
                                I am getting this error while running facerecognition.py0_1474901812661_upload-7d382f42-082d-4217-9aaa-2306d35ef583
                                and also need to know in //Facerecognition Test Tool Readme
                                In tools/facerecognition_tester/lib/config.py add add your training labels from tools/facetrainer under personen = [] ( what need to enter in this personen= [])
                                  rvdgeer @shashank
                                  @shashank If you run the facetrainer (capture.py and train.py) first, you should know what to enter here…
                                    shashank @rvdgeer
                                    @rvdgeer hi,
                                    After running capture.py a folder created by name ‘sasi’ in the /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/training_data
                                    then by running train.py a training.xml created in the path
                                    and also in /home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facerecognition_tester/lib i mentioned name in personen = ["sasi"]
                                    my config.js file as below
                                        module: 'MMM-Facial-Recognition',
                                        position: 'top_left',
                                            // 1=LBPH | 2=Fisher | 3=Eigen
                                            recognitionAlgorithm: 1,
                                            // Threshold for the confidence of a recognized face before it's considered a
                                            // positive match.  Confidence values below this threshold will be considered
                                            // a positive match because the lower the confidence value, or distance, the
                                            // more confident the algorithm is that the face was correctly detected.
                                            lbphThreshold: 50,
                                            fisherThreshold: 250,
                                            eigenThreshold: 3000,
                                            // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                                            useUSBCam: false,
                                            // Path to your training xml
                                            trainingFile: 'modules/MMM-Facial-Recognition/training.xml',
                                            // recognition intervall in seconds (smaller number = faster but CPU intens!)
                                            interval: 2,
                                            // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                                            logoutDelay: 15,
                                            // Array with usernames (copy and paste from training script)
                                            users: ['sasi'],
                                            //Module set used for strangers and if no user is detected
                                            defaultClass: "default",
                                            //Set of modules which should be shown for every user
                                            forAllClass: "for_all"
                                        module: 'clock',
                                        //Set your classes here seperated by a space.
                                        //Shown for all users
                                        classes: 'for_all'
                                    when i run pm2 start mm i am struck at below message
                                    0_1474984402690_upload-363493b4-6bba-4782-bab1-808bb8a3f585
                                    can someone help me on this error
                                    • Z
                                      zachlan
                                      Potentially stupid question here, apologies in advance if I’ve missed something obvious. I have the mirror and the face recognition working (Yay!) but when it’s running, on the left side of the screen it shows “MMM-Facial-Recognition” and module-10-mmm-facial-recognition underneath. I though about removing the position tag, but that’s there in the readme version so did not. How do I remove the text showing the running facial recognition module?
                                      Thanks!Zach
                                      • paviroP
                                        paviro @shashank
                                        @rvdgeer that sucks sorry about that. Recognition can be tricky sometimes :/
                                        @shashank check the trainingFile in your config, does it really exist at that location?
                                        Update: I see you figured it out, was a wrong location the problem? Just remove the position part is isn’t relevant anymore sorry :)
                                        S P 2 Replies Last reply
                                        • paviroP
                                          paviro @rvdgeer
                                            shashank @paviro
                                            @paviro
                                            yes , i copied the training file from //MMM-Facial-Recognition-Tools/facetrainer
                                            to // Path to your training xml
                                            trainingFile: ‘modules/MMM-Facial-Recognition/training.xml’,
                                            • 10
                                            • 11
                                            • 4 / 11
