    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 554.7k Views 58 Watching
    • K Offline
      KirAsh4 Moderator
      Yeah, I don’t know that module, or where it’s actually failing. But I can imagine if MM is initializing and the sensor is also doing something, things can go wrong. That’s why I suggested a delay.
      The touch sensor I’m playing with has a built-in 4 seconds delay before it becomes active, then it spends 5 to (no more than) 10 seconds calibrating itself. So plenty of time for MM to start up completely before the sensor starts “talking” to the rpi.
        paviro @Wilco89
        @Wilco89 No will do but I have so much stuff on my hand at the moment… Moving to Berlin in August etc…
        – The Doctor
        • W Offline
          Wilco89
          @paviro wir warten noch ein Moment. Viel Spaß im Berlin.
          I hope everything is going well with the move to Berlin. So everybody will be happy in a few weeks.
          • X Offline
            xdker
            why?
            ^CTraceback (most recent call last):
              File "capture.py", line 35, in <module>
                capture.capture()
              File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 53, in capture
                if is_letter_input('c'):
              File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 23, in is_letter_input
                input_char = raw_input()
            KeyboardInterrupt
            Note from admin: Please use Markdown on shell snippets!
            • X Offline
              xdker
                paviro
                Looks like you terminated the process by pressing ctrl-C or strg-C, just press c and then enter and no other key with the c.
                – The Doctor
                X 1 Reply Last reply Reply Quote 0
                • X Offline
                  xdker @paviro
                  @paviro
                  Oh sorry, I’m sorry I didn’t notice.
                  But there are the following tips.
                  where is capture.pgm not in the name of the folder.
                  Could not detect single face!  Check the image in capture.pgm to see what was captured and try again with only one face visible.
                    plumcraft
                    Hi everyone,
                    I have the same issue.
                    What do you want to do?
                    [1] Capture training images from webcam
                    [2] Convert ‘*.jpg’ pictures from other cameras to training images
                    –> 1
                    Enter the name of the person you want to capture or convert images for.
                    –> olifier
                    Images will be placed in ./training_data/olifier
                    Starting process…
                    Capturing positive training images.
                    Type c (and press enter) to capture an image.
                    Press Ctrl-C to quit.
                    c
                    Capturing image…
                    Thanks a lot
                      sarthak18593 @plumcraft
                      @plumcraft Are you using the Pi camera module or a usb webcam ?
                        plumcraft @sarthak18593
                        @sarthak18593
                        I’m using the pi camera module. It’s correctly enable from the raspi config tool.
                          plumcraft
                          I’ve tried to capture an image from my pi camera with :
                          pi@pi:~ $ raspistill -o output.jpg
                          the raspistill tool hang…
                          The pi camera might be broken ? someone got the same issue ?
                          Do you have any good usb webcam compatible with raspberry pi 3 and opencv ? I would like to use the MMM Face recognition module…
                            plumcraft
                            After retrying couple of times to make it work, it looks like the issue was coming the raspbian distribution or python package issue.
                            After reflashing my sd card with a fresh raspbian image, my camera works…
                              bobbob601
                                paviro
                                It checks every second or so but you can configure the interval.You can buy longer cables for the Pi cam :)
                                – The Doctor
                                  bobbob601
                                    rajbadri
                                    i am having a problem that the screen remains blank after i am logged in
                                    (1_1473950091065_2.jpg 0_1473950091063_1.jpg image url)
                                      rvdgeer
                                      Very nice module.
                                      However I keep ruinning into the same error when I try capture.py to convert them to pgm files:
                                      I’ve taken ‘selfies’ with different camera’s in different lighting conditions, but not even one is good enough to convert into a pgm file…
                                      Can you please give me some clues on what conditions my pictures have to meet?
                                      Am I doing something wrong?
                                      All help and advice appreciated!
                                        rvdgeer @rajbadri
                                        @rajbadri Have you added the classes: (with a value) to all the other modules in the config.js? If you get a plain black screen without errors it might be that no modules were loaded.
                                          rvdgeer @rvdgeer
                                          @rvdgeer OK, replying to my own post for future reference:
                                          I got it working by doing the following:
                                          • cropped the pictures to only show my face;
                                          • copied the cropped pictures and transformed them to greyscale;
                                          • copied the grey pictures and upped the contact;
                                          • moved all pictures (originals and copies) to a direct sub folder of the facetrainer folder;
                                          • started the capture.py, pressed 2, entered my name, entered the name of the sub folder (only the sub folder, not the entire path) and waited.
                                          This way I got it to recognize about 10 of the pictures…
                                          Not bad!
                                          Getting it to recognize me is still not easy, but that because of the lighting conditions in my ManCave where I’m putting it together.
                                            shashank @paviro
                                            @paviro Hi,
                                            I am getting this error while running facerecognition.py0_1474901812661_upload-7d382f42-082d-4217-9aaa-2306d35ef583
                                            and also need to know in //Facerecognition Test Tool Readme
                                            In tools/facerecognition_tester/lib/config.py add add your training labels from tools/facetrainer under personen = [] ( what need to enter in this personen= [])
                                            • 10
                                            • 11
                                            • 3 / 11
