    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 564.2k Views 58 Watching
    • K
      KirAsh4 Moderator
      Turn on a light? :)
      • W
        Wilco89 @KirAsh4
        @KirAsh4 in my coding cave it’s a bit dark :P and totally not the same condition as the kitchen (the place to hang the mirror)
        • K
          KirAsh4 Moderator
          In that case, you need to go up to the kitchen to grab a beer … and do the training. :)
          • W
            Wilco89
            then the mirror will only recognize when i’m in the kitchen with a beer:P
            first off all we need to fix @paviro his PIR Sensor module. When everything is working I can/will create the case and hang it on the wall.
            Otherwise my son will destroy it tomorrow morning or my grumpy old cat will play with the cables.
            • K
              KirAsh4 Moderator
              PIR Sensor module doesn’t work? I don’t know, I don’t have one … never tried it.
              • W
                Wilco89
                When activate it gives a whit screen before startup of the mirror.
                • K
                  KirAsh4 Moderator
                  Oh cool, special effects courtesy the PIR sensor … love it. :)
                  Maybe @paviro should set a delay before activating the sensor reading. I assume that’s wha tit does, like I said, I don’t have a PIR sensor to play with … figured there are enough folks out there doing that already. :)
                  • W
                    Wilco89
                    don’t even got to the MM, after the automatic stat of MM the screen is just white :P
                    But when @paviro has some time he will defintly look into it.
                    oder ist das schwierig @paviro ?
                    • K
                      KirAsh4 Moderator
                      Yeah, I don’t know that module, or where it’s actually failing. But I can imagine if MM is initializing and the sensor is also doing something, things can go wrong. That’s why I suggested a delay.
                      The touch sensor I’m playing with has a built-in 4 seconds delay before it becomes active, then it spends 5 to (no more than) 10 seconds calibrating itself. So plenty of time for MM to start up completely before the sensor starts “talking” to the rpi.
                        paviro @Wilco89
                        @Wilco89 No will do but I have so much stuff on my hand at the moment… Moving to Berlin in August etc…
                        – The Doctor
                        • W
                          Wilco89
                          @paviro wir warten noch ein Moment. Viel Spaß im Berlin.
                          I hope everything is going well with the move to Berlin. So everybody will be happy in a few weeks.
                          • X
                            xdker
                            why?
                            ^CTraceback (most recent call last):
                              File "capture.py", line 35, in <module>
                                capture.capture()
                              File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 53, in capture
                                if is_letter_input('c'):
                              File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 23, in is_letter_input
                                input_char = raw_input()
                            KeyboardInterrupt
                            Note from admin: Please use Markdown on shell snippets!
                            • X
                              xdker
                                paviro
                                Looks like you terminated the process by pressing ctrl-C or strg-C, just press c and then enter and no other key with the c.
                                – The Doctor
                                X 1 Reply Last reply Reply Quote 0
                                • X
                                  xdker @paviro
                                  @paviro
                                  Oh sorry, I’m sorry I didn’t notice.
                                  But there are the following tips.
                                  where is capture.pgm not in the name of the folder.
                                  Could not detect single face!  Check the image in capture.pgm to see what was captured and try again with only one face visible.
                                    plumcraft
                                    Hi everyone,
                                    I have the same issue.
                                    What do you want to do?
                                    [1] Capture training images from webcam
                                    [2] Convert ‘*.jpg’ pictures from other cameras to training images
                                    –> 1
                                    Enter the name of the person you want to capture or convert images for.
                                    –> olifier
                                    Images will be placed in ./training_data/olifier
                                    Starting process…
                                    Capturing positive training images.
                                    Type c (and press enter) to capture an image.
                                    Press Ctrl-C to quit.
                                    c
                                    Capturing image…
                                    Thanks a lot
                                      sarthak18593 @plumcraft
                                      @plumcraft Are you using the Pi camera module or a usb webcam ?
                                        plumcraft @sarthak18593
                                        @sarthak18593
                                        I’m using the pi camera module. It’s correctly enable from the raspi config tool.
                                          plumcraft
                                          I’ve tried to capture an image from my pi camera with :
                                          pi@pi:~ $ raspistill -o output.jpg
                                          the raspistill tool hang…
                                          The pi camera might be broken ? someone got the same issue ?
                                          Do you have any good usb webcam compatible with raspberry pi 3 and opencv ? I would like to use the MMM Face recognition module…
                                            plumcraft
                                            After retrying couple of times to make it work, it looks like the issue was coming the raspbian distribution or python package issue.
                                            After reflashing my sd card with a fresh raspbian image, my camera works…
                                            • 10
                                            • 11
                                            • 3 / 11
