    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.0k Views 58 Watching
    • Wilco89W
      Wilco89
      Is it also possible to use with the cameramodule of raspberry?
        sarthak18593 @Wilco89
        @Wilco89 yup , just set ‘useUSBcam’ to false in the config.js file and also make sure your pi has camera module enabled via the configuration of your pi
        Wilco89W 1 Reply Last reply
        • Wilco89W
          Wilco89 @sarthak18593
          @sarthak18593 I could figure it out myself. But i knew some people already working with this module. So they would know that. Only need to activate my camera now.
          • Wilco89W
            Wilco89
            All things are working @ the moment just have to start the training but it’s a bit dark at the moment, so i will wait until tomorrow.
            • KirAsh4K
              KirAsh4 Moderator
              Turn on a light? :)
              • Wilco89W
                Wilco89 @KirAsh4
                @KirAsh4 in my coding cave it’s a bit dark :P and totally not the same condition as the kitchen (the place to hang the mirror)
                • KirAsh4K
                  KirAsh4 Moderator
                  In that case, you need to go up to the kitchen to grab a beer … and do the training. :)
                  • Wilco89W
                    Wilco89
                    then the mirror will only recognize when i’m in the kitchen with a beer:P
                    first off all we need to fix @paviro his PIR Sensor module. When everything is working I can/will create the case and hang it on the wall.
                    Otherwise my son will destroy it tomorrow morning or my grumpy old cat will play with the cables.
                    • KirAsh4K
                      KirAsh4 Moderator
                      PIR Sensor module doesn’t work? I don’t know, I don’t have one … never tried it.
                      • Wilco89W
                        Wilco89
                        When activate it gives a whit screen before startup of the mirror.
                        • KirAsh4K
                          KirAsh4 Moderator
                          Oh cool, special effects courtesy the PIR sensor … love it. :)
                          Maybe @paviro should set a delay before activating the sensor reading. I assume that’s wha tit does, like I said, I don’t have a PIR sensor to play with … figured there are enough folks out there doing that already. :)
                          • Wilco89W
                            Wilco89
                            don’t even got to the MM, after the automatic stat of MM the screen is just white :P
                            But when @paviro has some time he will defintly look into it.
                            oder ist das schwierig @paviro ?
                            paviroP 1 Reply Last reply
                            • KirAsh4K
                              KirAsh4 Moderator
                              Yeah, I don’t know that module, or where it’s actually failing. But I can imagine if MM is initializing and the sensor is also doing something, things can go wrong. That’s why I suggested a delay.
                              The touch sensor I’m playing with has a built-in 4 seconds delay before it becomes active, then it spends 5 to (no more than) 10 seconds calibrating itself. So plenty of time for MM to start up completely before the sensor starts “talking” to the rpi.
                              • paviroP
                                paviro @Wilco89
                                @Wilco89 No will do but I have so much stuff on my hand at the moment… Moving to Berlin in August etc…
                                – The Doctor
                                • Wilco89W
                                  Wilco89
                                  @paviro wir warten noch ein Moment. Viel Spaß im Berlin.
                                  I hope everything is going well with the move to Berlin. So everybody will be happy in a few weeks.
                                  • X
                                    xdker
                                    why?
                                    ^CTraceback (most recent call last):
                                      File "capture.py", line 35, in <module>
                                        capture.capture()
                                      File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 53, in capture
                                        if is_letter_input('c'):
                                      File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 23, in is_letter_input
                                        input_char = raw_input()
                                    KeyboardInterrupt
                                    Note from admin: Please use Markdown on shell snippets!
                                    • X
                                      xdker
                                      • paviroP
                                        paviro
                                        Looks like you terminated the process by pressing ctrl-C or strg-C, just press c and then enter and no other key with the c.
                                        – The Doctor
                                        X 1 Reply Last reply
                                        • X
                                          xdker @paviro
                                          @paviro
                                          Oh sorry, I’m sorry I didn’t notice.
                                          But there are the following tips.
                                          where is capture.pgm not in the name of the folder.
                                          Could not detect single face!  Check the image in capture.pgm to see what was captured and try again with only one face visible.
                                            plumcraft
                                            Hi everyone,
                                            I have the same issue.
                                            What do you want to do?
                                            [1] Capture training images from webcam
                                            [2] Convert ‘*.jpg’ pictures from other cameras to training images
                                            –> 1
                                            Enter the name of the person you want to capture or convert images for.
                                            –> olifier
                                            Images will be placed in ./training_data/olifier
                                            Starting process…
                                            Capturing positive training images.
                                            Type c (and press enter) to capture an image.
                                            Press Ctrl-C to quit.
                                            c
                                            Capturing image…
                                            Thanks a lot
                                            • 10
                                            • 11
                                            • 3 / 11
