    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.7k Views 58 Watching
    • L
      lepetitnicolas
      Thank, the training module works fine and he recognizes me…
      but now i try the module and i put all the detail in the config.js and when i launch the MagicMirror, i’v got this
      Error opening app
      The app provided is not a valid Electron app, please read the docs on how to write one:
      https://github.com/electron/electron/tree/v1.1.0/docs
      Error: Cannot find module 'python-shell'
      npm ERR! Linux 4.4.9-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
      npm ERR! node v6.2.0
      npm ERR! npm  v3.8.9
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      paviroP 1 Reply Last reply
      • paviroP
        paviro @lepetitnicolas
        @lepetitnicolas what does /home/pi/MagicMirror/npm-debug.log say? Also please use Markdown on shell snippets!
        – The Doctor
        • L
          lepetitnicolas
          thank you for your help.
          my npm-debug.log
          1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
          2 info using npm@3.8.9
          3 info using node@v6.2.0
          5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
          6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
          7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
          8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
          9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/local/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
          10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
          11 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
          12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
          13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
          14 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
          14 verbose stack Exit status 1
          14 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:245:16)
          14 verbose stack     at emitTwo (events.js:106:13)
          14 verbose stack     at EventEmitter.emit (events.js:191:7)
          14 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
          14 verbose stack     at ChildProcess.emit (events.js:191:7)
          14 verbose stack     at maybeClose (internal/child_process.js:850:16)
          14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
          15 verbose pkgid magicmirror@2.0.0
          16 verbose cwd /home/pi/MagicMirror
          17 error Linux 4.4.9-v7+
          18 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
          19 error node v6.2.0
          20 error npm  v3.8.9
          21 error code ELIFECYCLE
          22 error magicmirror@2.0.0 start: `electron js/electron.js`
          22 error Exit status 1
          23 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
          23 error Make sure you have the latest version of node.js and npm installed.
          23 error If you do, this is most likely a problem with the magicmirror package,
          23 error not with npm itself.
          23 error Tell the author that this fails on your system:
          23 error     electron js/electron.js
          23 error You can get information on how to open an issue for this project with:
          23 error     npm bugs magicmirror
          23 error Or if that isn't available, you can get their info via:
          23 error     npm owner ls magicmirror
          23 error There is likely additional logging output above.
          24 verbose exit [ 1, true ]
          • paviroP
            paviro
            Make sure to install all dependencies as stated in the README file! Use npm install for that. As you can see in you error log python-shell is missing.
            – The Doctor
            • L
              lepetitnicolas
              Sorry.
              Now, it’s work fine.
              Thank you.
              • paviroP
                paviro
                @lepetitnicolas glad it does :)
                – The Doctor
                • Wilco89W
                  Wilco89
                  Is it also possible to use with the cameramodule of raspberry?
                    sarthak18593 @Wilco89
                    @Wilco89 yup , just set ‘useUSBcam’ to false in the config.js file and also make sure your pi has camera module enabled via the configuration of your pi
                    Wilco89W 1 Reply Last reply
                    • Wilco89W
                      Wilco89 @sarthak18593
                      @sarthak18593 I could figure it out myself. But i knew some people already working with this module. So they would know that. Only need to activate my camera now.
                      • Wilco89W
                        Wilco89
                        All things are working @ the moment just have to start the training but it’s a bit dark at the moment, so i will wait until tomorrow.
                        • KirAsh4K
                          KirAsh4 Moderator
                          Turn on a light? :)
                          • Wilco89W
                            Wilco89 @KirAsh4
                            @KirAsh4 in my coding cave it’s a bit dark :P and totally not the same condition as the kitchen (the place to hang the mirror)
                            • KirAsh4K
                              KirAsh4 Moderator
                              In that case, you need to go up to the kitchen to grab a beer … and do the training. :)
                              • Wilco89W
                                Wilco89
                                then the mirror will only recognize when i’m in the kitchen with a beer:P
                                first off all we need to fix @paviro his PIR Sensor module. When everything is working I can/will create the case and hang it on the wall.
                                Otherwise my son will destroy it tomorrow morning or my grumpy old cat will play with the cables.
                                • KirAsh4K
                                  KirAsh4 Moderator
                                  PIR Sensor module doesn’t work? I don’t know, I don’t have one … never tried it.
                                  • Wilco89W
                                    Wilco89
                                    When activate it gives a whit screen before startup of the mirror.
                                    • KirAsh4K
                                      KirAsh4 Moderator
                                      Oh cool, special effects courtesy the PIR sensor … love it. :)
                                      Maybe @paviro should set a delay before activating the sensor reading. I assume that’s wha tit does, like I said, I don’t have a PIR sensor to play with … figured there are enough folks out there doing that already. :)
                                      • Wilco89W
                                        Wilco89
                                        don’t even got to the MM, after the automatic stat of MM the screen is just white :P
                                        But when @paviro has some time he will defintly look into it.
                                        oder ist das schwierig @paviro ?
                                        • KirAsh4K
                                          KirAsh4 Moderator
                                          Yeah, I don’t know that module, or where it’s actually failing. But I can imagine if MM is initializing and the sensor is also doing something, things can go wrong. That’s why I suggested a delay.
                                          The touch sensor I’m playing with has a built-in 4 seconds delay before it becomes active, then it spends 5 to (no more than) 10 seconds calibrating itself. So plenty of time for MM to start up completely before the sensor starts “talking” to the rpi.
                                          • paviroP
                                            paviro @Wilco89
                                            @Wilco89 No will do but I have so much stuff on my hand at the moment… Moving to Berlin in August etc…
                                            – The Doctor
                                            • 10
                                            • 11
                                            • 3 / 11
