    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.1k Views 58 Watching
    • KirAsh4K
      KirAsh4 Moderator
      PIR Sensor module doesn’t work? I don’t know, I don’t have one … never tried it.
      • Wilco89W
        Wilco89
        When activate it gives a whit screen before startup of the mirror.
        • KirAsh4K
          KirAsh4 Moderator
          Oh cool, special effects courtesy the PIR sensor … love it. :)
          Maybe @paviro should set a delay before activating the sensor reading. I assume that’s wha tit does, like I said, I don’t have a PIR sensor to play with … figured there are enough folks out there doing that already. :)
          • Wilco89W
            Wilco89
            don’t even got to the MM, after the automatic stat of MM the screen is just white :P
            But when @paviro has some time he will defintly look into it.
            oder ist das schwierig @paviro ?
            paviroP 1 Reply Last reply
            • KirAsh4K
              KirAsh4 Moderator
              Yeah, I don’t know that module, or where it’s actually failing. But I can imagine if MM is initializing and the sensor is also doing something, things can go wrong. That’s why I suggested a delay.
              The touch sensor I’m playing with has a built-in 4 seconds delay before it becomes active, then it spends 5 to (no more than) 10 seconds calibrating itself. So plenty of time for MM to start up completely before the sensor starts “talking” to the rpi.
              • paviroP
                paviro @Wilco89
                @Wilco89 No will do but I have so much stuff on my hand at the moment… Moving to Berlin in August etc…
                – The Doctor
                • Wilco89W
                  Wilco89
                  @paviro wir warten noch ein Moment. Viel Spaß im Berlin.
                  I hope everything is going well with the move to Berlin. So everybody will be happy in a few weeks.
                  • X
                    xdker
                    why?
                    ^CTraceback (most recent call last):
                      File "capture.py", line 35, in <module>
                        capture.capture()
                      File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 53, in capture
                        if is_letter_input('c'):
                      File "/home/pi/MagicMirror/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 23, in is_letter_input
                        input_char = raw_input()
                    KeyboardInterrupt
                    Note from admin: Please use Markdown on shell snippets!
                    • X
                      xdker
                      • paviroP
                        paviro
                        Looks like you terminated the process by pressing ctrl-C or strg-C, just press c and then enter and no other key with the c.
                        – The Doctor
                        X 1 Reply Last reply
                        • X
                          xdker @paviro
                          @paviro
                          Oh sorry, I’m sorry I didn’t notice.
                          But there are the following tips.
                          where is capture.pgm not in the name of the folder.
                          Could not detect single face!  Check the image in capture.pgm to see what was captured and try again with only one face visible.
                            plumcraft
                            Hi everyone,
                            I have the same issue.
                            What do you want to do?
                            [1] Capture training images from webcam
                            [2] Convert ‘*.jpg’ pictures from other cameras to training images
                            –> 1
                            Enter the name of the person you want to capture or convert images for.
                            –> olifier
                            Images will be placed in ./training_data/olifier
                            Starting process…
                            Capturing positive training images.
                            Type c (and press enter) to capture an image.
                            Press Ctrl-C to quit.
                            c
                            Capturing image…
                            Thanks a lot
                              sarthak18593 @plumcraft
                              @plumcraft Are you using the Pi camera module or a usb webcam ?
                                plumcraft @sarthak18593
                                @sarthak18593
                                I’m using the pi camera module. It’s correctly enable from the raspi config tool.
                                  plumcraft
                                  I’ve tried to capture an image from my pi camera with :
                                  pi@pi:~ $ raspistill -o output.jpg
                                  the raspistill tool hang…
                                  The pi camera might be broken ? someone got the same issue ?
                                  Do you have any good usb webcam compatible with raspberry pi 3 and opencv ? I would like to use the MMM Face recognition module…
                                    plumcraft
                                    After retrying couple of times to make it work, it looks like the issue was coming the raspbian distribution or python package issue.
                                    After reflashing my sd card with a fresh raspbian image, my camera works…
                                      bobbob601
                                      • paviroP
                                        paviro
                                        It checks every second or so but you can configure the interval.You can buy longer cables for the Pi cam :)
                                        – The Doctor
                                          bobbob601
                                            rajbadri
                                            i am having a problem that the screen remains blank after i am logged in
                                            (1_1473950091065_2.jpg 0_1473950091063_1.jpg image url)
                                            R 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 3 / 11
