Is MMM-AssistantMk2 compatible with PulseAudio?
5 Posts 4 Posters 1.4k Views 4 Watching
    jmartin1009
    I use PulseAudio with my PS3 eye camera microphone, is this program compatible with MMM-AssistantMk2? I would like to use this mic with this module if possible.
    ? 1 Reply Last reply Mar 1, 2019, 7:01 PM Reply Quote 0
      A Former User @jmartin1009
      @jmartin1009
      I’m using pulseaudio for BT external speaker in ATB, and it works well.
      The only things you should check are;
      • get a mic recording with arecord
      • output sound with aplay or other player
      J 1 Reply Last reply Mar 1, 2019, 9:27 PM Reply Quote 0
        jmartin1009 @Guest
        @sean I use PulseAudio for my microphone because the mic uses a 4 mic array and the default program doesn’t like that, I thinks it’s Alsa or something, but anyways, I use the speakers connected to the TV I am using via the HDMI output, and it works to play an MP3 I downloaded as well as using Shairport-sync. How do I use a record to check if my mic records? When I open pulse audio and speak into my mic it registers as picking up sound, is that enough? Or do I need to use arecord?
        S 1 Reply Last reply Mar 2, 2019, 4:19 PM Reply Quote 0
          audreyspency
          This is fantastic. Hope will come with full guide and instruction in each step.
            sdetweil @jmartin1009
            @jmartin1009 said in Is MMM-AssistantMk2 compatible with PulseAudio?:
            arecord somefile.wav
            then
            aplay somefile.wav
            sometimes the default device isn’t setup… so
            arecord -l (letter L)
            will give u the list of devices…
