    Is MMM-AssistantMk2 compatible with PulseAudio?
    5 Posts 4 Posters 1.9k Views 4 Watching
      jmartin1009
      I use PulseAudio with my PS3 eye camera microphone, is this program compatible with MMM-AssistantMk2? I would like to use this mic with this module if possible.
        A Former User @jmartin1009
        @jmartin1009
        I’m using pulseaudio for BT external speaker in ATB, and it works well.
        The only things you should check are;
        • get a mic recording with arecord
        • output sound with aplay or other player
          jmartin1009 @Guest
          @sean I use PulseAudio for my microphone because the mic uses a 4 mic array and the default program doesn’t like that, I thinks it’s Alsa or something, but anyways, I use the speakers connected to the TV I am using via the HDMI output, and it works to play an MP3 I downloaded as well as using Shairport-sync. How do I use a record to check if my mic records? When I open pulse audio and speak into my mic it registers as picking up sound, is that enough? Or do I need to use arecord?
            audreyspency
            This is fantastic. Hope will come with full guide and instruction in each step.
              sdetweil @jmartin1009
              @jmartin1009 said in Is MMM-AssistantMk2 compatible with PulseAudio?:
              arecord somefile.wav
              then
              aplay somefile.wav
              sometimes the default device isn’t setup… so
              arecord -l (letter L)
              will give u the list of devices…
