    MMM-PIR-Sensor black screen
    6 Posts 3 Posters 2.7k Views 3 Watching
      Stef
      Hello everyone,
      i just found out about this module - didn’t even know this exists - and i hat to try it!
      I’m planning on saving some energy by powering off the Monitor.
      The install worked fine and the PIR Sensor is working (i have a litte .py script that’s prints a message in the shell if a movement is dedected) BUT the screen stays black!
      The Monitor is powerd on - i even see the desktop seconds bevor MM boots up, but the screens stays black and nothing is displayed.
      I noticed this before when i was trying to turn my monitor on and off again with tvservice --off / tvservice --preferred.
      If i use vcgencmd display_power 1 / vcgencmd display_power 0 my Monitor perfectly switches on and off again.
      But, i checked the “node_helper.js” on github and the helper file is using the “vcgencmd script”
      What is going here? Any ideas how i can solve this?
        sdetweil @Stef
        @Stef with the black screen and a keyboard, press ctrl-shift-i (letter I),
        to open the developers console, select the console tab, and scroll up to find errors, red text
          Stef
          @sdetweil thanks for the headsup - but this does not work… i see the mous coursor though, but that’s it.
          I even can’t “cancel” the fullscreen mode of the magic mirror by pressing F11 (usually this brings me back to the desktop) :/
            Stef
            I did a little research and stumbled over severall issues on the github page - this one catched my eye, but didn’t brought me any luck…
            So, what did i do excatly?
            1. Install:
            cd ~/MagicMirror/modules/
            git clone https://github.com/paviro/MMM-PIR-Sensor.git
            npm install
            sudo usermod -a -G gpio pi
            sudo chmod u+s /opt/vc/bin/tvservice && sudo chmod u+s /bin/chvt
            sudo reboot
            1. New wiringPI version:
            sudo apt-get purge wiringpi
            hash -r
            sudo apt-get install git-core
            cd
            git clone git://git.drogon.net/wiringPi
            cd ~/wiringPi
            git pull origin
            ./build
            sudo reboot
            1. reinstall EPOLL:
            sudo npm install --save-dev electron-rebuild ./node_modules/.bin/electron-rebuild
            1. recompile Electron:
            npm list | grep electron
            cd ~/MagicMirror/modules/MMM-PIR-Sensor
            npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
            sudo reboot
            Expectation: It Works now…
            Reality: It does not…
            my Config is:
                      module: 'MMM-PIR-Sensor',
                                   sensorPin: 23,
                                   powerSaving: true,
                                   powerSavingDelay: 120 // 2 Minutes
            I just excluded this part of my config - and my mirror displays everything again…
            Andy ideas left? :)
              Stef
              Hey all,
              turns out, that the MMM-PIR-Sensor Module is buggy - well, at least for me.
              Can’t get it to work, but i found an alternative: MagicMirror-Display-Controller
              Works like a Charme!
              Case closed :)
              Have a nice weekend!
              • wishmaster270W Offline
                wishmaster270 Module Developer @Stef
                @Stef Hi, yesterday i added two Modules to the Showcase Area. On that monitors GPIO Pins and one which controls the Monitor.
                My usecase is exactly like yours. I use an PIR sensor to detect user presence and want the screen to be turned off after a configurable timeout.
                If you want to try them:
                MMM-Screen-Powersave-Notification
                and
                MMM-GPIO-Notifications
