    PIR Sensor Install Problems
    4 Posts 2 Posters 1.7k Views 2 Watching
      anhanyoung
      Hey guys,
      So I am using Cowboydude’s module for the PIR sensor to turn off and on the mirror. Following the instructions here
      https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/
      When I typed in “sudo chmod +x pir.py”, it says the directory or file cannot be found. I know it says to install it in the root folder but I do not know how to do that. So I improvised and used sudo mv after installing it into /root. I do not know if that would provide the same results. Could anyone give me some guidance?
        sdetweil @anhanyoung
        @anhanyoung said in PIR Sensor Install Problems:
        mv is move… where did you move it to? if not in root…
        installing in root is either copy (cp) from somewhere else to / (root)
        or editing there with nano, vi, gedit or whatever editor you like or use
        root is really a bad place… but easy to find ls /
          anhanyoung @sdetweil
          @sdetweil so i should use cp? i moved it to /root
            @anhanyoung move (mv) moves single instance around
            Copy(cp) make another instance in another location.
            Depends on what u want to do.
