    [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²
    25 Posts 15 Posters 25.6k Views 19 Watching
      bugman61
      Thanks for the great module, it has solved a lot of the issues I had when I was using carousel to organize my modules.
      Is there a way to set a default hidden/displayed for each module in the menu when starting? I have my MM set up with the clock and a photo slideshow to always be displayed, and then I have 4 ModuleToggles set to show other information when needed (calendar, weather, etc). I would like to be able to start MM with these other modules hidden as opposed to having everything open automatically and having to close each one manually. Alternatively a timer to close modules automatically after XX seconds would work as well. That would also allow us to open a module and see the info and walk away without having to close it manually.
        shbatm Module Developer @bugman61
        @bugman61 said in [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²:
        My recommendation would be to use something like MMM-Carousel w/ Navigation to put everything in different slides. You can set the timeout to 0 to keep it on the slide you have chosen, and then add menu items to jump to each slide (this is what I use on one of my mirrors, combined with MMM-KeyBindings to allow control from a bluetooth remote).
        You can look at MMM-Module-Scheduler to implement this now, or create an issue on GitHub for this module and when I get a chance, I will add the ability to allow multiple actions assigned to a single menu item. This module already has the ability to send delayed actions–multiple actions would allow you to (1) send a switch to slide X action and then a (2) delayed action–after x seconds switch back to home slide.
          bugman61 @shbatm
          @shbatm said in [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²:
          This is how I initially had by mirror set up. However I ran into issues with a php form I had in MMM-iFrame-Ping not working correctly. The form worked fine displayed on its own, but I was never able to get the submit buttons to work properly when it was a part of the Carousel. That led me to your module where the form has worked perfectly.
            robiv8
            Beginner question!
            With the module “Remote Control” you enter the address in the browser xxx:8080/remote.html
            Then you have the menu.
            How does it work with OnScreenMenu, or does not work there.
              shbatm Module Developer @robiv8
              @robiv8 OnScreenMenu puts a little floating button on your mirror (either visible always, or only visible when you hover over that corner) and gives you a menu on the mirror’s screen itself. The new version has an option to use MMM-Remote-Control and basically takes a small mini version of the “/remote.html” page and puts it in an iFrame on the MIrror’s screen.
              Basically – Remote Control is a remote (phone, another computer, etc.) and OSM is for the actual mirror, if you have a touchscreen, or use a mouse, keyboard, or physical remote (w/ MMM-KeyBindings).
                robiv8
                Thanks for the explanation
                  mrcpu55
                  I just installed Magic Mirror and still learning all the idiosyncrasies of the system. I installed the OnScreenMenu (stable) version and I just found this forum topic. I see there is a new version in the developer channel.
                  Can I install the developer version (0.2) on top of the current version? How would I completely remove the older version if I have to?
                  Thanks for all the great work!
                    Mykle1 Project Sponsor Module Developer @mrcpu55
                    @mrcpu55 said in [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²:
                    You can simply rename the current folder in the MagicMirror/modules folder. Then install the developer version. If that works well for you then you can delete the previous folder that you renamed. If the new version does not work for you then you can remove the new version folder and rename the previous version folder back to the way it was.
                      mrcpu55
                      Thanks for the quick reply! I will try this out.
                      • U Offline
                        UniqueUsername
                        Hey. I’m using TWO pages in my MM.
                        How can I set two different menus to be shown?
                        as, in my first page i want to show “restart” at menu
                        and at the second page I want to show “reboot” at menu2.
                        • L Offline
                          lovesicker
                          @shbatm
                          Firstly, thank you for providing us this fantastic module!
                          I have a position question: when I set a bottom_right position for it, your module button layout is as following:
                          When I set a bottom_right position for another module, for example, mm-hide-all, but the layout is as following:
                          If I’d like to place my another module mm-hide-all at that position, which your MMM-OnScreenMenu is on, how shall I do? Could you give me some suggestions?
                          Thanks in advance.
                          • KamiSchamiK Offline
                            KamiSchami
                            hi, how do i integrate modules. i use different classes… Tank You
                            Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                              scottial
                              It is possible to disable menu items area when mouse is not over main button or to create the items when the mouse is over then? The items are active even if hidden and it is possible to press them unintentionally.
