    MMM-MyCalendar
    109 Posts 40 Posters 166.0k Views 38 Watching
      My module does not have a configurable icon. It wouldn’t work with the calendar icon with the date inside.
      I based my modyle off the default calendar midule included wth MM. that one has a configurablenicon and perhaps I forgot to remove the instruction in my version.
      Mine never had a configurable icon. I might enable a few options that would work with the date number inside, but at the moment you just get the one.
      • H
        hnsy
        Hi @j-e-f-f , thanks a lot for your really great modules. I really appreciate the style and convenience of your modules.
        As I am using MyCalendar now for a while, I was wondering, if there is a possibility to display time-ranges? I mean the start date of a range is displayed, but when an event is taking place for, let’s say three days, currently I can only display the first day (start time).
        Is there a possibility that all (3) days would appear in the list?
        Maybe it is already integrated and I just didn’t get it.
        Once more: Thumbs up for your work!!
        Cheers, HNSY
          j.e.f.f Project Sponsor Module Developer @hnsy
          @hnsy I’m not sure… I’m using the default calendar code to retrieve the calendar data. I’ve only customized the display portion. If multi-day blocks are included in the data then it should be possible. I’ll have to take a look.
          • bdeelmanB
            bdeelman @j.e.f.f
            • N
              nagaculun
              • N
                nagaculun
                • G
                  ganget
                  • F
                    Fonfon
                    is it possible to color text ?
                    because when i you have a wallpaper sometimes text is not visible.
                    thanks for your help
                      j.e.f.f Project Sponsor Module Developer @Fonfon
                      @Fonfon No, but you can add a background colour to the module to make the text stand out better. try something like this in your custom.css file:
                      .MMM-MyCalendar .module-content {
                        background-color: rgba(0,0,0,0.5);
                      The first three parameters 0,0,0 mean black, and the fourth parameter 0.5 is the level of transparency. Specify a decimal between 0 and 1, where 0 is fully transparent, and 1 is fully opaque.
                      F 1 Reply Last reply Reply Quote 1
                      • F
                        Fonfon @j.e.f.f
                        @j-e-f-f said in MMM-MyCalendar:
                        Thanks j.e.f.f for your help !
                          charp07 @zzaidi148
                          @zzaidi148 @j-e-f-f
                          I have this same issue and haven’t had any luck in resolving the issue. I even copied the recommended config from earlier in this forum. Is there something that I am missing?
                          It will just say, “Loading…”
                          			module: "MMM-MyCalendar",
                          			classes: "default everyone",
                          			header: "Upcoming",
                          			disabled: false,
                          				colored: true,
                          				maximumNumberOfDays: 30,
                          				maximumEntries: 5,
                          				fade: false,
                          				maxTitleLength: 500,
                          				useRelativeDates: false,
                          				dayOfWeekFormat: "dddd",
                          				timeFormat: "h:mm A",
                          				dateFormat: "MMMM D",
                          				joiningWord: "at",
                          				urgency: 1,
                          					url: "https://calendar.google.com/calendar/ical path",
                          					color: "#ffb350"
                          					color: "#ff77d4"
                            charp07 @charp07
                            @charp07 figured it out! Sorry!
                              BRSQUIRRL @j.e.f.f
                              @j-e-f-f This feature (grouping by day) would be awesome! Have you had a chance to make any progress on this?
                                rookiepilot
                                Did anybody’s MMM-MyCalendar module break after daylight savings (Sunday November 3rd)? Both my “MMM-MyCalendar” AND “MMM-CalendarExt2” modules are showing events on the wrong days now. The problem seems to only occur with reoccurring events; they usually show up one day earlier. Rebooting does not correct the issue. I hope someone can figure this out soon 😞
                                  Clubjack @j.e.f.f
                                  @j-e-f-f
                                  Hey. I found your Module last days and i love it. Thanks for that.
                                  One question.
                                  I have one added calendar (holidays) that have a “description” in his calendar entry.
                                  So the Modul Shows three lines.
                                  First with the Titel (christmas),
                                  Second with date (24 Dezember)
                                  third with description (calovo.de).
                                  Is it possible to hide the description?
                                  • Alex2020A
                                    Alex2020
                                    Salve ho installato oggi il modulo MMM-MyCalendar ma per cambiare le icone o i simboli ed assegnarle una diversa come si fa ?Potreste mettermi un esempio?Grazie.Inoltre è possibile cambiare colore esempio Martedi 5 Febbario rosso e Mercoledi 6 Febbraio in verde?Grazie.
                                    • E
                                      eliah
                                      Hi @j-e-f-f,
                                      Thank you for the great module! :)
                                      I have added an option to have a calendar label displayed before the event text as it looks more intuitive and does not require to remember colors :). If you are ok to have this added to your code I can either send the updates to you or create a pull request in github.
                                      Here is the screenshot (I use MM as a picture frame, not a mirror, with bright colored image, that’s why it is black on white in my case):
                                      alt text
                                        PatrickGolfer @charp07
                                        @charp07 What was the fix to your Loading issue?
                                        • 6 / 6
