    MMM-MyCalendar
    109 Posts 40 Posters 167.3k Views 38 Watching
    • twosquirrelsT
      twosquirrels @ninjabreadman
      @ninjabreadman Page 1 contains an update where it mentions support for 2 columns:
      https://forum.magicmirror.builders/topic/2559/mmm-mycalendar?page=1
      alt text
      N 1 Reply Last reply
      • N
        ninjabreadman @himanshulotia
        @himanshulotia Yes.
        First, you can set colored: true in the config, then add color: "#d9b4b2” and color: "#a0cfe2" per the docs.
        Second, have a look at the FontAwesome 4 docs. You could likely insert them into your headings. For how to insert images, you could probably use CSS if you can find the right selectors.
        • N
          ninjabreadman @twosquirrels
          @twosquirrels It looks like you need to use the using_nunjucks branch. The default branch is still (it seems to me, on my phone) 1.0 – it doesn’t contain an .njk template file.
          twosquirrelsT 1 Reply Last reply
          • twosquirrelsT
            @ninjabreadman
            Ahh, I see. Silly question - how do I pull from that branch instead of from the master? I googled the differences but it’s not making sense to me.
            AHH! I figured it out:
            pi@magicmirror:~/MagicMirror/modules $ git clone -b using_nunjucks https://github.com/jclarke0000/MMM-MyCalendar.git
            Cloning into 'MMM-MyCalendar'...
            remote: Counting objects: 84, done.
            remote: Total 84 (delta 0), reused 0 (delta 0), pack-reused 84
            Unpacking objects: 100% (84/84), done.
            @ninjabreadman thank you for pointing this out!
              smreid
              Hi
              Just wondering if there is anyway I can use custom symbols for calendar entries in place of the ‘day of the month’ logos? Similar to the default calendar module?
              Stephen
                cola0927
                Hi, it’s really a nice module, but got a small issue here. I’m wondering how to make the event contents left-aligned. I tried to modify some parameters in MMM-MyCalendar.css, but didn’t work.
                Thanks!
                justjim1220J 1 Reply Last reply
                • justjim1220J
                  justjim1220 Module Developer @cola0927
                  @cola0927
                  change the text-align under title in the css
                  .MMM-MyCalendar .title {
                    color: #ff0;
                    font-size: 55px;
                    line-height: 115%;
                    font-weight: 600;
                    text-align: left;
                    padding-left: 0;
                    margin-bottom: 2px;
                    white-space: nowrap;
                    text-overflow: ellipsis;
                    border-radius: 15px;
                    overflow: hidden;
                    display: block;
                    margin-top: 4px;
                  Jim Hallock - 1995
                  C 1 Reply Last reply
                    cola0927 @justjim1220
                    @justjim1220 Cool! Thank you so much!
                    • H
                      hoveeman
                      This module is great! Thank you!
                      Is it possible to add a header/title for the day of the week with the items below it? Essentially you would see Monday and the corresponding items below it. Then Tuesday and it’s items, and so forth.
                      Any thoughts?
                        j.e.f.f Project Sponsor Module Developer @hoveeman
                        @hoveeman yeah should be doable. Let me take a look over the next few days.
                        H B 2 Replies Last reply
                        • H
                          hoveeman @j.e.f.f
                          @j-e-f-f Awesome, that would be great! Really appreciate it!
                          Also, I would envision if there were no items for Wednesday it would not list anything and go straight to Thursday. Thoughts?
                          • bokifideB
                            bokifide
                            Hi! Love the module :). Just wondering if there’s a way to space out the columns enough so that the titles don’t get cut off:
                            Thank you for your work!!
                            Boki
                            • MedoM
                              Medo
                              Hey there!
                              For some time now, i have the following issue:
                              My MMM-MyCalendar is showing dates wrongly (one day in the past) although they are correct in the used ics-file.
                              I moved my question over to the “troubleshooting” section (as it seems it fits better there):
                              https://forum.magicmirror.builders/topic/8963/mmm-mycalendar-showing-wrong-dates-days-one-day-in-the-past
                                j.e.f.f Project Sponsor Module Developer @bokifide
                                @bokifide You would need to write some custom CSS to adjust the width of the containing column. The module is designed to used all of the space available in its container.
                                • V
                                  VinGroot
                                  I’d like to have absolute days in my calendar, but all I see is ‘today’, Saturday (without date), etc.
                                  My config is:
                                  maximumEntries: 8,
                                  useRelativeDates: false,
                                  joiningWord: “om”,
                                  maxTitleLength: 48,
                                  dateFormat: “D MMMM YYYY”,
                                  timeFormat: “HH:mm”,
                                  urgency: 0,
                                  getRelative: 0,
                                  * secret *]
                                  Am I doing something wrong?
                                  Some things like timeFormat (HH:mm), maxTitleLength and joiningWord work fine.
                                  • V
                                    VinGroot
                                    • V
                                      VinGroot
                                      When I set maximumEntries: 8 I only see items 3 items.
                                      I did some testing and I think the reason I only see 3 items is because some items are excluded.
                                      I think the excluded items are counted as well.
                                        DolphinScientist
                                        Hi @j-e-f-f , thanks for the great module. The config indicates that the icons are customizable using Font Awesome, but the behavior and the code (line ~181) seem to indicate otherwise. Any chance we could get it back? Do you know how you would want it implement with the svg system you have?
                                          My module does not have a configurable icon. It wouldn’t work with the calendar icon with the date inside.
                                          I based my modyle off the default calendar midule included wth MM. that one has a configurablenicon and perhaps I forgot to remove the instruction in my version.
                                          Mine never had a configurable icon. I might enable a few options that would work with the date number inside, but at the moment you just get the one.
                                          • H
                                            hnsy
                                            Hi @j-e-f-f , thanks a lot for your really great modules. I really appreciate the style and convenience of your modules.
                                            As I am using MyCalendar now for a while, I was wondering, if there is a possibility to display time-ranges? I mean the start date of a range is displayed, but when an event is taking place for, let’s say three days, currently I can only display the first day (start time).
                                            Is there a possibility that all (3) days would appear in the list?
                                            Maybe it is already integrated and I just didn’t get it.
                                            Once more: Thumbs up for your work!!
                                            Cheers, HNSY
                                            • 5 / 6
