    MMM-GroveGestures
    51 Posts 8 Posters 32.5k Views 12 Watching
      bolish
      @Benjaminh86
      I will be able to do it later tonight as not at home for now.
      Honestly, I clearly don’t have any knowledge at all neither, I just started MM 2 months ago and never touched to a Raspberry or Javascript or even text edit before…
      Just by reading around on MM forums + the incredible community support, I managed it by playing around myself with different modules.
      I’m still not an expert, but it works and I’m proud of myself!
      If you want to understand how it works yourself for purposes of proudness, I would recommend you to :
      • Install MMM-Pages (config in config.js is easy)
      • Install MMM-RemoteControl (appart from changing the IP adress at the top of your config.js, there is nothing else to do. This will allow you to send notification from your smartphone browser as a matter of testing. And when you will be comfortable, you will see that this will allow you to configurate your own smartphone command app for the mirror, it’s pretty powerful and simple)
      • Install MMM-NotificationTrigger (basically, it works like that : if Notification A is received, please send notification B
      Start to play with NotificationTrigger and MMM-Pages to do something like this :
      • On your smartphone browser (after ahving installed MMM-RemoteControl and configured it) : send some notification like this to MMM-Pages and see if the pages changes :
      http://YOURIP:8080/remote?action=NOTIFICATION&notification=PAGE_INCREMENT"
      "http://YOURIP:8080/remote?action=NOTIFICATION&notification=PAGE_DECREMENT"
      Try to configure MMM-NotificationTrigger so that when “PAGE_INCREMENT” is received, it will fire “PAGE_QUERY_NUMBER” (to MMM-Pages that will then respond with “PAGE_NUMBER_IS” + payload “X”, X being the page number).
      Try to configure MMM-NotificaitonTrigger so that when “PAGE_NUMBER_IS” is received (with payload), and alert is shown on the mirror with the returned Page Number as a payload.
      Once you will have done that, you will have understand how everything works (you will be able to delete the alert shown on the message which was just a test).
      If you manage to do that, the MMM-GroveGestures part in the end will be a piece of cake (and don’t worry, the above is not difficult at all if you want to learn by yourself).
      I will try to post you a working extract of my config.js this evening. If I forget, please remind me.
      Regards
      B 1 Reply Last reply
        Benjaminh86 @bolish
        @bolish
        you seem to know how to do things better than me; there are some who understand faster than others, I must be part of the 2nd categories!
        I already installed remote control that works well. I will try with all the information you give me as soon as I have time (I am not at home now).
        it may seem a little easy for me to ask you your scripts, but it allows me to understand the operation and interactions, so I want to see them when you have time.
        Thanks for your help :)
          Screech
          Hi, I’m interrested in using this module (Great job by the way).
          But in hardware I have number of choice :
          https://fr.aliexpress.com/item/Fast-Free-Ship-Based-on-PAJ7620U2-Gesture-Recognition-Sensor-9-Gesture-Recognition-Grove-Gesture-Recognition-Sensor/32796887595.html
          This one seam to be the same as yours at 22.33€
          But there other with the same "chipset’ :
          https://fr.aliexpress.com/item/PAJ7620U2-Divers-Geste-Reconnaissance-Capteur-Module-Pour-Arduino-Int-gr-9-geste-IIC-interface-reconnaissance-intelligente/32963443120.html
          At 3.52€ … The only “difference” I see is the number of pin : 5 instead of 4… there is a “INT” Pin… do you know if it’s compatible and what’s the use of this “INT” pin ?
          ? 1 Reply Last reply
            A Former User @Screech
            @Screech
            I’m not annexpert so I cannot declare, but…
            I think INT means Interrupt, It can give additional feature about interruptions to device. Anyway I think it would work when INT is not connected, but not sure. Sorry.
              Screech @Guest
              @Sean
              Thank you for the info ;) I just command one to test ;)
              Cya in about 1 month (when I receiv and test it) I give you a feedback then :D
                bolish
                @Benjaminh86
                Here is an extract of mine that should help you to understand. You just have to tweak the notification and pages based on your setup.
                			// 22
                			module: "MMM-GroveGestures",
                				autoStart: true, //When Mirror starts, recognition will start.
                				verbose:true, // If set as `true`, useful messages will be logged.
                				recognitionTimeout: 1000, //Gesture sequence will be ended after this time from last recognized gesture.
                				cancelGesture: "WAVE", //If set, You can cancel gesture sequence with this gesture.
                				visible: true, //Recognized gesture sequence will be displayed on position
                				idleTimer: "0", // `0` for disable, After this time from last gesture, onIdle will be executed.
                				defaultCommandSet: "DEFAULT_MODE",
                				commandSet: {
                					"DEFAULT_MODE": {
                							"LEFT": {
                						        notificationExec: {
                						          notification: "PAGE_INCREMENT",
                							"RIGHT": {
                						        notificationExec: {
                						          notification: "PAGE_DECREMENT",
                					"0": { // this corresponds to the page N° sent back by MMM-Pages
                							"LEFT": {
                						        notificationExec: {
                							"RIGHT": {
                						        notificationExec: {
                							"UP": {
                						        notificationExec: {
                						          notification: "CALEXT2_SCENE_NEXT",
                      						              payload: null,
                							"DOWN": {
                						        notificationExec: {
                						          notification: "CALEXT2_SCENE_PREVIOUS",
                      						              payload: null,
                					"1": {
                						        "LEFT-RIGHT-LEFT": {
                						        notificationExec: {
                						          notification: "REMOTE_ACTION",
                							    payload: {
                							  	action: "SHOW",
                							  	module: "module_13_MMM-BackgroundSlideshow",
                						        "RIGHT-LEFT-RIGHT": {
                						        notificationExec: {
                							    payload: {
                							  	action: "HIDE",
                						        "UP-DOWN-UP": {
                						        notificationExec: {
                							    payload: {
                							  	action: "SHOW",
                							  	module: "module_14_MMM-BackgroundSlideshowInfo",
                		        				"DOWN-UP-DOWN": {
                						        notificationExec: {
                							    payload: {
                							  	action: "HIDE",
                							"LEFT": {
                						        notificationExec: {
                							"RIGHT": {
                						        notificationExec: {
                							"UP": {
                						        notificationExec: {
                						          notification: "ARTICLE_MORE_DETAILS",
                							"DOWN": {
                						        notificationExec: {
                						          notification: "ARTICLE_LESS_DETAILS",
                							"CLOCKWISE": {
                						        notificationExec: {
                						          notification: "BACKGROUNDSLIDESHOW_NEXT",
                							"ANTICLOCKWISE": {
                						        notificationExec: {
                						          notification: "ARTICLE_PREVIOUS",
                					"2": {
                							"LEFT": {
                						        notificationExec: {
                							"RIGHT": {
                						        notificationExec: {
                							"UP": {
                						        notificationExec: {
                						          notification: "SWD_NEXT",
                							"DOWN": {
                						        notificationExec: {
                						          notification: "SWD_PREV",
                							"FORWARD-BACKWARD": {
                						        notificationExec: {
                						          notification: "SWD_PAUSE",
                							"BACKWARD-FORWARD": {
                						        notificationExec: {
                						          notification: "SWD_PLAY",
                					commandSetTrigger: {
                					  "DEFAULT_MODE": "DEFAULT_MODE",
                  					  "PAGE_NUMBER_IS": (payload) => { return payload } // this is what set the right command set based on MMM-Pages feedback "PAGE_NUMBER_IS"
                			//22
                			module: "MMM-NotificationTrigger",
                				useWebhook: false,
                				triggers: [
                						// Is hiding the compliments module when newsfeed article is toggled fullscreen
                						trigger: "ARTICLE_MORE_DETAILS",
                						fires: [
                								fire: "REMOTE_ACTION",
                								  payload: {
                    									action: "HIDE",
                    									module: "module_6_compliments",
                						// Is showing the compliments module again when newsfeed is minimized.
                						trigger: "ARTICLE_LESS_DETAILS",
                						fires: [
                								  payload: {
                    									action: "SHOW",
                						// Is triggering PAGE NUMBER NOTIFICATION when pages is changing
                						trigger: "PAGE_DECREMENT",
                						fires: [
                								fire: "QUERY_PAGE_NUMBER",
                						trigger: "PAGE_INCREMENT",
                						fires: [
                						// Slideshow_Show.
                						trigger: "SLIDESHOW_SHOW",
                						fires: [
                								  payload: {
                    									action: "SHOW",
                						// Slideshow_Hide.
                						trigger: "SLIDESHOW_HIDE",
                						fires: [
                								  payload: {
                    									action: "HIDE",
                						// SlideshowInfo_Show.
                						trigger: "SLIDESHOWINFO_SHOW",
                						fires: [
                								  payload: {
                    									action: "SHOW",
                						// SlideshowInfo_Hide.
                						trigger: "SLIDESHOWINFO_HIDE",
                						fires: [
                								  payload: {
                    									action: "HIDE",
                						fires: [
                								  payload: {
                    									action: "SHOW",
                						// AT START - Is hiding MMM-ImageSlideshow at start.
                						trigger: "ALL_MODULES_STARTED",
                						fires: [
                								  payload: {
                    									action: "HIDE",
                								  payload: {
                    									action: "HIDE",
                								fire: "PAGE_INCREMENT",
                						// SHUTDONW - turns screen off and shutdown pi
                						trigger: "SCREENOFFSHUTDOWN",
                						fires: [
                								  payload: {
                    									action: "MONITOROFF",
                								  payload: {
                    									action: "SHUTDOWN",
                B 2 Replies Last reply
                  Benjaminh86 @bolish
                  Hello @bolish,
                  thanks for sharing the script. I will watch this carefully ;)
                  BenH
                    Benjaminh86 @bolish
                    @bolish
                    I see in your MMM-notificationtrigger module that you have a MONITOROFF action.
                    I imagine that we can associate a gesture command in Grove Gestures, for example: I make the gesture high, it turns on the screen.
                    I would like to do that but I do not understand how to integrate it into Grove Gestures …
                    If I do :
                    “UP”: {
                    notificationExec: {
                    notification: “REMOTE_ACTION”,
                    payload: {
                    action: “MONITORON”,
                    module: “MMM-Remote-Control”,
                    And in MMM-notificationtrigger:
                    // MONITOR_ON - turns screen on
                    trigger: “MONITOR_ON”,
                    fires: [
                    fire: “REMOTE_ACTION”,
                    payload: {
                    is it good?..
                      bolish
                      @Benjaminh86
                      Not really…
                      “MONITORON” is already an action which is managed by MMM-REMOTECONTROL so you don’t need MMM-Notificationtrigger for that.
                      You just need MMM-GroveGesture to send it :
                      		        				"UP": {
                      						        notificationExec: {
                      							    payload: {
                      							  	action: "MONITORON",
                      								     },	 // you don't need to refer to a module name for the MONITORONN action (only necessary for HIDE and SHOW)
                      But you need to make sure that MMM-REMOTEControl is configured in the right way so that when it receives “MONITORON” it sends the right command (depending if you use HDMI, CEC, etc…)
                      Regards
                        Benjaminh86 @bolish
                        @bolish
                        thank you
                        when you say: “But you need to make sure that MMM-REMOTEControl is configured in the right way”, when I send the request http://192.168.xxx.xxx:8080…MONITOROFF, it works.
                        is that enough, or do I have to add something to the MMM-Remote-Control script?
                          bolish
                          No, if it’s works by sending the request, it should work with Gesture also!
                            Benjaminh86 @bolish
                            @bolish
                            Great!
                            I will try tonight the adaptation I made of your script.
                            I put the action “MONITOROFF” in the “Default_Mode” part of Grove Gestures, that’s it?
                              Benjaminh86 @bolish
                              Hello @bolish,
                              thanks to you! everything is working!
                              however, I thought Grove Gestures would activate automatically, but I have to make the command line for the sensor to be active:
                              cd ~ / MagicMirror / modules / MMM-GroveGestures / py
                              cp grove_gesture_sensor.py.RPI grove_gesture_sensor.py
                              Is this normal?
                              Another question about MMM-Pages; I would like to display the Google Calendar calendar on page 1 and the holiday calendar on page 2, but I do not know how to differentiate and name them on MMM-Pages …
                              Do you have an idea?
                                A Former User @Benjaminh86
                                @Benjaminh86 said in MMM-GroveGestures:
                                It is described on instruction for installation. And that command is not for activation. I provide 2 scripts for each of Raspberry Pi and Asus TinkerBoard. you need to select one for your device. You don’t need to do that job again after once you did.
                                The real activation would be performed in the module itself on every running of MM.
                                  bolish
                                  @Benjaminh86
                                  You have to search a bit on the forum.
                                  One idea could be to create 2 calendars instances.
                                  See below post extract :
                                  well… I believe it’s far from being perfect…but at least it seems to do the job…
                                  I created a “new” module which does exactly same / has the same code as the one I want to use, but has a different name (folder named “MMM-Calendar2” -> file named “MMM-Calendar2.js” -> within the line Module.register(‘MMM_Calendar2’)).
                                  Not in the default module folder but into the 3rd party module folder…
                                  And put instance 1 on page 1 and isntance 2 on page 2.
                                    Benjaminh86 @Guest
                                    Hello @Sean,
                                    I will look at this in more detail in the module.
                                    Thank you again for your work.
                                      Benjaminh86 @bolish
                                      @bolish
                                      I will explore this track.
                                      Thanks to you ; you already helped me a lot!
                                        Benjaminh86 @Guest
                                        @Sean
                                        it’s weird; the sensor is not active if I do not order:
                                        would not it come from “chmod + x * .sh” where I hurt something? …
                                          Benjaminh86 @bolish
                                          @bolish
                                          it works!
                                          thanks for your help
                                            @Benjaminh86
                                            Can’t understand.
                                            Do you need to do that shell command per every execution of MM? Have you reinstalled it?
                                            That commands just need to be done once when you install this module.
                                            And that command isn’t related with chmod + x .sh at all.
                                            Check this.
                                            ls ~/MagicMirror/modules/MMM-GroveGestures/py
                                            There should be grove_gesture_sensor.py besides grove_gesture_sensor.py.RPI and grove_gesture_sensor.py.ATB.
                                            Are those files there?
                                            • 2 / 3
